To connect  ADF5901 Aux outputs to ADF4195 REF-IN inputs.
Question asked by lux on Aug 20, 2017
Latest reply on Aug 21, 2017 by Ruairí
Need some help with the ADF5901 AUX/AUX BAR outputs to drive the ADF4195 REF-IN A/REFIN-B inputs.
Questions:
When the ADF5901 AUX/AUX BAR outputs to drive the ADF4195 REF-IN A/REFIN-B inputs diffrentially on a PCB
 at 12GHz rate by DC-cutting with two 22pf caps,
Q1:   Should a  200 ohm micro-strip line technique be used on the PCB?
( "200 ohm" comes from the data sheet  electrical specification for the ADF5901 AUX/AUX BAR output imepedance.)
Q2: Is 22pf proper value for the DC-cutting caps?   If not , what would be a  better value?
Q3:  If the answer to Q1 is "yes", what would be the limitation for the length of the PCB traces?
Thanks!
Best Regards,
Lux
