(ADV7181D)To detect unlock analog input.
Question asked by donadona999s on Aug 9, 2017
Latest reply on Sep 6, 2017 by donadona999s
Hi !
I already read this but something is wrong.
Can ADV7181D indicate the "in_lock" status to CPU via INT pin?
I'm trying to detect unlock status using INT pin.
I am using ADV7181D eval board.
Experimental procedure is as follows:
1) Run script
2) Input CVBS
3) Un mask SD_UNLOCK
   *Mask every other status bit.
4) Clear SD_UNLOCK.
5) Set clear bit to "0".
6) Disconnect CVBS
But INT pin don't goes to low.
Why does this happen? Do you have any idea?
I read the status bit and status bit was changed.
(Connect CVBS)
    *Red INT
     Yellow I2C clk
     Blue    I2C data
(Disconnect CVBS)
But INT pin output don't change.
Can you help about this?
Best regards
Kawa
