AD5933 Gain factor in real Resistance and Reactance
Question asked by ValterF on Aug 5, 2017
Latest reply on Aug 7, 2017 by musach
I'm trying to develop a system for bioimpedance measurement with the IC AD5933.
The AD5933 is a high precision impedance converter system that combines a frequency generator with a 12-bit, 1 MSPS, Analog-to-Digital converter. The frequency generator allows an external complex impedance to be excited with a known frequency. The signal in response from the impedance is sampled by the on -board ADC and a discrete Fourier transform (DFT) is done by an on-board DSP engine.
The DFT algorithm returns both a real (R) and imaginary (I) data-word at each frequency point along the sweep. The impedance magnitude and phase are easily calculated using equations.
enter image description here
To convert this number into impedance, it must be multiplied by a scaling factor called the gain factor. The gain factor is calculated during the calibration of the system with a known impedance connected between the VOUT and VIN pins.
The measured impedance at the frequency point is given by:
My problem is that I need to use only the real (Resistance) and imaginary (Reactance) information, rather than the Impedance Magnitude.
Because the equations of body composition require, for example:
So, my question is: How do I apply the gain factor only in real (Resistance) and imaginary (Reactance) values?
Another thing, this doubt is very simple:
Is it possible to program the AD5933 to work with a fixed frequency of 50K?
Tks!
