HMC629ALP4E
Question asked by satya247 on Jul 26, 2017
Latest reply on Jul 28, 2017 by s.ilke
Dear Sir/Madam,
I am using HMC629ALP4E RF Digital step attenuator.
When I am controlling this via SPI protocol, It is setting up for different attenuation rather than a single value.
For example
I am using a Tactile Switch to send SPI command
uint8_t Spi_DAdata[2] = {0x0F,0x00}; // E0 = 3dB, D0 = 6dB, B0 = 12dB, 70 = 24dB.
uint8_t Spi_DAdata1[2] = {0x0D,0x00};
uint8_t Spi_DAdata2[2] = {0x0B,0x00};
while(1)
   if (switch == 1)
   write_spi(&Spi_DAdata2,1,1);
   else{
         led_toggle(led0);
void write_spi(uint8_t *data_out, int len, uint8_t CS)
         if (CS == 1)
               struct spi_device device ={
               .id = IOPORT_CREATE_PIN(PORTD,1)
            spi_select_device(&SPIC, &device);   // setting Latch Enable LOW
           delay_us(10);
            for (i = 0; i < len; i++)
               spi_put(&SPIC, data_out[i]);
               while(!spi_is_tx_ok(&SPIC)){
spi_deselect_device(&SPIC, &device);    // setting Latch Enable HIGH
delay_us(100);
I checked the scope which is giving me correct data.
but I couldn't understand when I press a button HMC629ALP4E behave wiredly
When I press the switch/ button first time it will set to -45 db attenuation
second press  -24dB
third press       -12dB
fourth press     - 6 dB
Fifth press      -3dB
I couldn't understand this behavior of HMC629ALP4E attenuator.
Can any one please help me out ?
