How to change input clock refernce to 15.36MHz for AD9528  in ADRV9371 Eval board?
Question asked by amdakwar12 on Jul 19, 2017
Latest reply on Aug 4, 2017 by gverma
I am working with zc706 and ad9371 eval board.
Now my application I need  to change reference clock to 15.36 MHz for ad9371 eval board from default value of 30.72 MHz.
For this I had change dts file as follows
                         ad9528-1@0 {
                #address-cells = <0x1>;
                #size-cells = <0x0>;
                #clock-cells = <0x1>;
                compatible = "ad9528";
                spi-cpol;
                spi-cpha;
                spi-max-frequency = <0x989680>;
                reg = <0x0>;
                clock-output-names = "ad9528-1_out0", "ad9528-1_out1", "ad9528-1_out2", "ad9528-1_out3", "ad9528-1_out4", "ad9528-1_out5", "ad9528-1_out6", "ad9528-1_out7", "ad9528-1_out8", "ad9528-1_out9", "ad9528-1_out10", "ad9528-1_out11", "ad9528-1_out12", "ad9528-1_out13";
                adi,vcxo-freq = <0x7530000>;
                adi,refa-enable;
                adi,refa-diff-rcv-enable;
                adi,refa-r-div = <0x1>;
                adi,osc-in-cmos-neg-inp-enable;
                adi,pll1-feedback-div = <0x8>;
                adi,pll1-charge-pump-current-nA = <0x1388>;
                adi,pll2-ndiv-a-cnt = <0x2>;
                adi,pll2-ndiv-b-cnt = <0x7>;
                adi,pll2-vco-diff-m1 = <0x3>;
                adi,pll2-n2-div = <0xa>;
                adi,pll2-r1-div = <0x1>;
                adi,pll2-charge-pump-current-nA = <0xc4888>;
                adi,sysref-src = <0x2>;
                adi,sysref-pattern-mode = <0x1>;
                adi,sysref-k-div = <0x200>;
                adi,sysref-request-enable;
                adi,sysref-nshot-mode = <0x3>;
                adi,sysref-request-trigger-mode = <0x0>;
                adi,rpole2 = <0x0>;
                adi,rzero = <0x7>;
                adi,cpole1 = <0x2>;
                adi,status-mon-pin0-function-select = <0x1>;
                adi,status-mon-pin1-function-select = <0x7>;
                reset-gpios = <0x4 0x71 0x0>;
                linux,phandle = <0x8>;
                phandle = <0x8>;
                channel@13 {
                    reg = <0xd>;
                    adi,extended-name = "DEV_CLK";
                    adi,driver-mode = <0x0>;
                    adi,divider-phase = <0x0>;
                    adi,channel-divider = <0xa>;
                    adi,signal-source = <0x0>;
                channel@1 {
                    reg = <0x1>;
                    adi,extended-name = "FMC_CLK";
                    adi,channel-divider = <0x5>;
                               channel@2 {
                    reg = <0x2>;
                    adi,extended-name = "FMC_AUX_CLK";
                channel@12 {
                    reg = <0xc>;
                    adi,extended-name = "DEV_SYSREF";
                    adi,signal-source = <0x2>;
                channel@3 {
                    reg = <0x3>;
                    adi,extended-name = "FMC_SYSREF";
but is not locking to 15.36 MHz reference clock.
Please suggest any thing I am missing?
Regards
ARVIND
