xwf72
ADV7393 CVBS Chroma level problem
Discussion created by xwf72 on Jul 16, 2017
Latest reply on Jul 17, 2017 by GuenterL
1. Design goals
I am using FPGA and ADV7393 design a CVBS generator, FPGA output 8bit YCbCr + Hs + Vs signal to the ADV7393.
The generator output a CVBS signal, the format is PAL-D, the content is 100% color bar picture.
The generator is required to comply with the Chinese video standard(GB-3174-1995 PAL-D), which is required to be measured using the NI PXI-2172 after the completion of the design. The metering item is the brightness level and chroma level of each color signal, The standard value is as follows, the error range is less than -3% to + 3%.
WHITEYELLOWCYANGREENMAGENTAREDBLUEBLACK
brightness level(mv)700620490410289290790
chroma level(mv)6278858278278856270
2. My Design
FPGA produces 576I video timing and color RGB data, RGB data range is 16 ~ 235, FPGA internal design has a RGB to YCbCr module, conversion formula is as follows. And then YCbCr conversion 422 format, and finally the YCbCr422 data along with the video timing output to the ADV7393,
2.1 RGB to YCbCr
 Y = 0.299R + 0.587G + 0.114B
 Cb = -0.168736R - 0.331246G + 0.5B + 128
 Cr = 0.5R - 0.418688G - 0.081312B + 128
RGB = 16~235
2.2 VIDEO timming
Hs = 63   Hbp = 69   Hfp = 12  HdNum = 720      HsPOL=0
Vs  = 3     Vbp= 19    Vfp = 2     VdNum = 576     VsPOL=0
Interlace
2.3 ADV7393 config
REG0x17 = 0x02          // software reset
REG0x00 = 0x1C         // all DAC on, PLL on
REG0x01 = 0x00          // SD input
REG0x87 = 0x20           // SD input standard autodetection
REG0x80 = 0x11           //  SD standard: PAL B, PAL D, PAL G, PAL H, PAL I
REG0x82 = 0xC3
REG0x88 = 0x00            // 8-bit YCbCr input
REG0x8A = 0x0C           // slave mode    SD timing mode=mode2
REG0x8C = 0xCB           // Subcarrier Frequency
REG0x8D = 0x8A
REG0x8E = 0x09
REG0x8F = 0x2A
3. The problem
CVBS output connected to the TV, the TV normal recognition of the PAL signal, and the display of the color bar picture looks completely normal, but when use NI PXI-2172 to measure the chroma level found that the overall low tens of mv (red font number). The result of brightness level is normal (the number of the blue font).
700
698
620
617
490
485
410
405
289
287
290
207
79
76.3
0
0
chroma level(mv)
627
566
885
801
827
755
827
748
885
804
627
570
0
4. Problem analysis
I think the problem is likely to be RGB to YCbCr formula, especially the Cr formula and Cb formula.
GB-3174-1995
Does anyone help me analyze where my problem is?
