Using with M2K
Question asked by dmercer Employee on Jul 15, 2017
Latest reply on Jul 17, 2017 by dmercer
I'm trying to test out some of the Python bindings on M2K.
As a first experiment I'm attempting to turn on and adjust the outputs of the User Power Supplies.
I know that the M2K iio device will be ad5627 which has two output channels.
I can find the device in the context by:
contexts = iio.scan_contexts()
uri = next(iter(contexts), None)
ctx = iio.Context(uri)
ad5627 = ctx.find_device("ad5627")
To test if this works I do:
I can find the first voltage0 channel with:
for chan in ad5627.channels:
    if == "voltage0" and chan.output:
        print "channel id " + str(
        print "channel direction " + str(chan.output)
From here on I'm not getting very much farther. I can print out the power down state but don't know exactly how to change it to False. Or how to set the DAC value.
In the C++ code for Scopy I found these calls to iio but I don't see the equivalent in
/* Power down DACs by default */
iio_channel_attr_write_bool(ch1w, "powerdown", true);
iio_channel_attr_write_bool(ch2w, "powerdown", true);
/* Set the default values */
iio_channel_attr_write_longlong(ch1w, "raw", 0LL);
iio_channel_attr_write_longlong(ch2w, "raw", 0LL);
and this to set the DAC value:
void PowerController::dac1_set_value(double value)
    long long val = value * 4095.0 / (5.02 * 1.2);
    iio_channel_attr_write_longlong(ch1w, "raw", val);
    if (in_sync) {
        value = -value * ui->trackingRatio->value() / 100.0;
Any help in reproducing this in Python would be a huge help! I'm sure there will be more things I don't understand as well.
