ADSP-215xx Linker_log and MAP File issue
Question asked by S@Tech on Jul 13, 2017
Latest reply on Jul 21, 2017 by Kader.M
Hi Kader.M, walkercc, Harshit.Gaharwar, DaveThib
I have found issues in the linker_log.xml generated after successful build of my executable project in CCES 2.6.0:
The following input section(s) were excluded
library_1.dlb[a.obj](seg_dmda)
library_1.dlb[b.obj](seg_dmda)
library_2.dlb[s.obj](seg_dmda)
And in the MAP file, code and data memory was not mapped to external memory (I'm using only Core1 of ADSP-21573)
MemoryStart AddressEnd AddressTypeQualifierWidthUsed wordsUnused words
mem_DMC0_SDRAM_A40x80a000000x80cfffffBWRAM0x80x00x300000
mem_DMC0_SDRAM_A60x810000000x885fffffBWRAM0x80x76000000x0
I have used the standard .ldf file available in the CCES installation path.
L1 cache - 64 KB for Instruction, DM and PM cache size.
L2 and L3 default cache size.
I have customized the system Stack in L1 cahce and system Heap in L3 cache.
When I debug the Code in Functional Simulator, I get invalid fetch request while the following line in disassembly is executed : cjump (pc,__setup_heaps.)(db);
What can be the reason for these issues ?
