adv212 compress 16bit mono still picture
Question asked by jaguarxk on Jul 11, 2017
Latest reply on Jul 12, 2017 by JeyasudhaMuthuPerumal
We use adv212 compressing 16bit monochrome still image, the compressed image encountered fuzzy problem, 512 * 512 size image compression ratio is set to about 60: 1, but the jp2 filesize only 1kB, the actual compression ratio is 512: 1
Source image pixel value is small, of about the lower 10 bit. we suspect and stepsize set up, when using kakadu software ,reault is much better (set qstep to 1/256 or 1/10000).
we failed setting adv212 stepsize paramter .after the soft-rebooting, stepsize recovery to default value.if we do not enablesoft-rebooting, the loadss will not be cleared,Adv212 can not start encoding. The situation does not match the description of the programing guide.
need help!
