Interface AD5790 evaluation board and RPi 3
Question asked by dasalam on Jul 6, 2017
Latest reply on Jul 13, 2017 by dasalam
Hello.
I would like to write my driver for control the AD5790 DAC with Raspberry Pi 3 (RPi).
I have an evaluation board (eval board) AD5790. The schematic is (see the photo below):
voltage from external power supply:
VDD = +11.67 V, AGND = to analog ground, VSS = -5.1 V
VCC = +5.15 V, DGND = to digital ground (also connected to RPi GND)
eval board pins | RPi pins (other pins does not use)
SYNC -> GPIO12 (I use it as chip select manually)
SCLK -> SPI_CLK
SDIN -> MOSI
SDO -> MISO
Links' config:
LK1 = B position
LK2 = B position
LK3 = A position
LK4 = removed
LK5 = removed
LK6 = removed
LK7 = inserted
LK8 = C position
LK9 = inserted
LK11 = inserted
I am using the following SPI configuration (I also tried many others):
mode: SPI MODE1
bit order: MSBFIRST
clock: 390.625kHz
In first I send "reset" command (0b 0100 0000 0000 0000 0000 01000) and then I send read control register command (0b 1010 0000 0000 0000 0000 0000). In last I send "readback" command through MOSI (0b 0000 ... 0000 i.e. all zeros) and try to read MISO, but the always result is 3 zero bits.
Could you help me? May be I did something wrong with hardware configuration or while programming.
schematic eval board ad5790 + Raspberry Pi 3
