Porting AD9371 to ZCU102 Board
Question asked by sm7102 on Jun 29, 2017
Latest reply on Aug 1, 2017 by gverma
I am trying to port the AD9371 RF card to ZCU102 board. I understand that, ZCU102 board does not support AD9371, so I followed "https://wiki.analog.com/resources/tools-software/linux-drivers/iio-transceiver/ad9371" link to port. I am able to compile. But after it booted up, it does not create the device under /dev. So in order to debug I tried to follow a simpler approach, where I just want to detect if the spi slave is present in the system. So I modified the device tree as follows,
    spi@ff040000 {
      compatible = "cdns,spi-r1p6";
      status = "okay";
      interrupt-parent = <0x2>;
      interrupts = <0x0 0x13 0x4>;
      reg = <0x0 0xff040000 0x0 0x1000>;
      clock-names = "ref_clk", "pclk";
      #address-cells = <0x1>;
      #size-cells = <0x0>;
      power-domains = <0x39>;
      clocks = <0x1d 0x1d>;
      is-decoded-cs = <0x0>;
      num-cs = <0x2>;
      spidev@0 {
        compatible = "spidev";
        spi-max-frequency = <0x27bc86c>;
        reg = <0x0>;
      spidev@1 {
        reg = <0x1>;
I see the driver instances under /sys/bus/spi/devices as below,
root@plnx_aarch64:/sys/bus/spi/devices# ls
spi0.0 spi32766.0 spi32766.1
But I do not see any device under /dev/ directory (should I expect spidev0 and spidev1).
Is there a user space driver I can use without making kernel modification, if yes, could you please point to the right document or link.
Thanks in advance.
