can you tell me the reason?
Question asked by binghe on Jun 26, 2017
Latest reply on Jun 27, 2017 by rejeesh
hello,everybody ,i'm using the matlab 2017a's  HDL Workflow advisor  to creat vivado.And my vivado
vision is 2015.2.1.The simulink project is the ModeS_ADI_Codegen.slx  provided by analog.Now i meet a problem which make me failed to creat a vivado project.I choose the "zc706+fmcomms5 rx".
the information is below:
Failed Create Project.
Task "Create Project" unsuccessful. See log for details.
Generated logfile: E:\PROJECT\weixin\MathWorks_tools-master\MathWorks_tools-master\targeting_models\ADSB\hdl_prj_ss5\hdlsrc\ModeS_ADI_Codegen\workflow_task_CreateProject.log
****** Vivado v2015.2.1 (64-bit)
**** SW Build 1302555 on Wed Aug 5 13:06:02 MDT 2015
**** IP Build 1291990 on Mon Jul 27 03:18:52 MDT 2015
** Copyright 1986-2015 Xilinx, Inc. All Rights Reserved.
source vivado_create_prj.tcl
# create_project vivado_prj {} -part xc7z045ffg900-2 -force
INFO: [ProjectBase 1-489] The host OS only allows 260 characters in a normal path. The project is stored in a path with more than 80 characters. If you experience issues with IP, Block Designs, or files not being found, please consider moving the project to a location with a shorter path. Alternately consider using the OS subst command to map part of the path to a drive letter.
Current project path is 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj'
# set_property target_language Verilog [current_project]
# set defaultRepoPath {./ipcore}
# set_property ip_repo_paths $defaultRepoPath [current_fileset]
# update_ip_catalog
INFO: [IP_Flow 19-234] Refreshing IP repositories
INFO: [IP_Flow 19-1700] Loaded user IP repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/ipcore'.
INFO: [IP_Flow 19-2313] Loaded Vivado IP repository 'C:/Xilinx/Vivado/2015.2/data/ip'.
# set ipList [glob -nocomplain -directory $defaultRepoPath *.zip]
# foreach ipCore $ipList {
# set folderList [glob -nocomplain -directory $defaultRepoPath -type d *]
# if {[lsearch -exact $folderList [file rootname $ipCore]] == -1} {
# catch {update_ip_catalog -add_ip $ipCore -repo_path $defaultRepoPath}
# update_ip_catalog
INFO: [IP_Flow 19-1839] IP Catalog is up to date.
# source vivado_custom_block_design.tcl
## set ad_hdl_dir [pwd]
## set ad_phdl_dir [pwd]
## set proj_dir $ad_hdl_dir/projects/fmcomms5/zc706
## source $ad_hdl_dir/projects/scripts/adi_project.tcl
### variable p_board
### variable p_device
### variable sys_zynq
### variable p_prcfg_init
### variable p_prcfg_list
### variable p_prcfg_status
### if {![info exists REQUIRED_VIVADO_VERSION]} {
### set REQUIRED_VIVADO_VERSION "2015.2.1"
### if {[info exists ::env(ADI_IGNORE_VERSION_CHECK)]} {
### set IGNORE_VERSION_CHECK 1
### } elseif {![info exists IGNORE_VERSION_CHECK]} {
### set IGNORE_VERSION_CHECK 0
### proc adi_project_create {project_name project_dir update_tcl {mode 0}} {
### global ad_hdl_dir
### global ad_phdl_dir
### global p_board
### global p_device
### global sys_zynq
### global REQUIRED_VIVADO_VERSION
### global IGNORE_VERSION_CHECK
### set p_device "none"
### set p_board "none"
### set sys_zynq 0
### if [regexp "_ac701$" $project_name] {
### set p_device "xc7a200tfbg676-2"
### set p_board "xilinx.com:ac701:part0:1.0"
### set sys_zynq 0
### if [regexp "_kc705$" $project_name] {
### set p_device "xc7k325tffg900-2"
### set p_board "xilinx.com:kc705:part0:1.1"
### set sys_zynq 0
### if [regexp "_vc707$" $project_name] {
### set p_device "xc7vx485tffg1761-2"
### set p_board "xilinx.com:vc707:part0:1.1"
### set sys_zynq 0
### if [regexp "_kcu105$" $project_name] {
### set p_device "xcku040-ffva1156-2-e"
### set p_board "xilinx.com:kcu105:part0:1.0"
### set sys_zynq 0
### if [regexp "_zed$" $project_name] {
### set p_device "xc7z020clg484-1"
### set p_board "em.avnet.com:zed:part0:1.3"
### set sys_zynq 1
### if [regexp "_zc702$" $project_name] {
### set p_board "xilinx.com:zc702:part0:1.2"
### set sys_zynq 1
### if [regexp "_zc706$" $project_name] {
### set p_device "xc7z045ffg900-2"
### set p_board "xilinx.com:zc706:part0:1.2"
### set sys_zynq 1
### if [regexp "_mitx045$" $project_name] {
### set p_board "not-applicable"
### set sys_zynq 1
### if [regexp "_pzsdr$" $project_name] {
### set p_device "xc7z035ifbg676-2L"
### set sys_zynq 1
### #Added
### set project_name vivado_prj
### if {!$IGNORE_VERSION_CHECK && [string compare [version -short] $REQUIRED_VIVADO_VERSION] != 0} {
### return -code error [format "ERROR: This project requires Vivado %s." $REQUIRED_VIVADO_VERSION]
### #Added
### adi_setup_libs
### if {$mode == 0} {
### set project_system_dir "./$project_name.srcs/sources_1/bd/system"
### #Removed
### #create_project $project_name . -part $p_device -force
### } else {
### set project_system_dir ".srcs/sources_1/bd/system"
### #Removed
### #create_project -in_memory -part $p_device
### if {$mode == 1} {
### file mkdir $project_name.data
### if {$p_board ne "not-applicable"} {
### set_property board_part $p_board [current_project]
### #Removed
### #set lib_dirs $ad_hdl_dir/library
### #if {$ad_hdl_dir ne $ad_phdl_dir} {
### # lappend lib_dirs $ad_phdl_dir/library
### #set_property ip_repo_paths $lib_dirs [current_fileset]
### #update_ip_catalog
### set_msg_config -id {BD 41-1348} -new_severity info
### set_msg_config -id {BD 41-1343} -new_severity info
### set_msg_config -id {BD 41-1306} -new_severity info
### set_msg_config -id {IP_Flow 19-1687} -new_severity info
### set_msg_config -id {filemgmt 20-1763} -new_severity info
### set_msg_config -severity {CRITICAL WARNING} -quiet -id {BD 41-1276} -new_severity error
### #Added
### create_bd_design "system"
### source $project_dir/system_bd.tcl
### source $project_dir/$update_tcl
### regenerate_bd_layout
### save_bd_design
### validate_bd_design
### generate_target {synthesis implementation} [get_files $project_system_dir/system.bd]
### make_wrapper -files [get_files $project_system_dir/system.bd] -top
### import_files -force -norecurse -fileset sources_1 $project_system_dir/hdl/system_wrapper.v
### } else {
### write_hwdef -file "$project_name.data/$project_name.hwdef"
### proc adi_setup_libs {} {
### set lib_dirs [get_property ip_repo_paths [current_fileset]]
### lappend lib_dirs $ad_hdl_dir/library
### if {$ad_hdl_dir ne $ad_phdl_dir} {
### lappend lib_dirs $ad_phdl_dir/library
### set_property ip_repo_paths $lib_dirs [current_fileset]
### update_ip_catalog
### adi_add_archive_ip $lib_dirs
### proc adi_add_archive_ip {lib_dirs} {
### foreach libDir $lib_dirs {
### set ipList [glob -nocomplain -directory $libDir *.zip]
### foreach ipCore $ipList {
### catch {update_ip_catalog -add_ip $ipCore -repo_path $libDir}
### file delete -force $ipCore
### proc adi_project_files {project_name project_files} {
### global proj_dir
### #Added
### cd $proj_dir
### add_files -norecurse -fileset sources_1 $project_files
### set_property top system_top [current_fileset]
### #Added
### cd $ad_hdl_dir
### proc adi_project_run {project_name} {
### #Removed
## source $ad_hdl_dir/projects/scripts/adi_board.tcl
### variable sys_cpu_interconnect_index
### variable sys_hp0_interconnect_index
### variable sys_hp1_interconnect_index
### variable sys_hp2_interconnect_index
### variable sys_hp3_interconnect_index
### variable sys_mem_interconnect_index
### set sys_cpu_interconnect_index 0
### set sys_hp0_interconnect_index -1
### set sys_hp1_interconnect_index -1
### set sys_hp2_interconnect_index -1
### set sys_hp3_interconnect_index -1
### set sys_mem_interconnect_index -1
### proc ad_connect_type {p_name} {
### set m_name ""
### if {$m_name eq ""} {set m_name [get_bd_intf_pins -quiet $p_name]}
### if {$m_name eq ""} {set m_name [get_bd_pins -quiet $p_name]}
### if {$m_name eq ""} {set m_name [get_bd_intf_ports -quiet $p_name]}
### if {$m_name eq ""} {set m_name [get_bd_ports -quiet $p_name]}
### if {$m_name eq ""} {set m_name [get_bd_intf_nets -quiet $p_name]}
### if {$m_name eq ""} {set m_name [get_bd_nets -quiet $p_name]}
### return $m_name
### proc ad_connect {p_name_1 p_name_2} {
### if {($p_name_2 eq "GND") || ($p_name_2 eq "VCC")} {
### set p_size 1
### set p_msb [get_property left [get_bd_pins $p_name_1]]
### set p_lsb [get_property right [get_bd_pins $p_name_1]]
### if {($p_msb ne "") && ($p_lsb ne "")} {
### set p_size [expr (($p_msb + 1) - $p_lsb)]
### set p_cell_name [regsub -all {/} $p_name_1 "_"]
### set p_cell_name "${p_cell_name}_${p_name_2}"
### if {$p_name_2 eq "VCC"} {
### set p_value -1
### } else {
### set p_value 0
### puts "create_bd_cell(xlconstant) size($p_size) value($p_value) name($p_cell_name)"
### create_bd_cell -type ip -vlnv xilinx.com:ip:xlconstant:1.1 $p_cell_name
### set_property CONFIG.CONST_WIDTH $p_size [get_bd_cells $p_cell_name]
### set_property CONFIG.CONST_VAL $p_value [get_bd_cells $p_cell_name]
### puts "connect_bd_net $p_cell_name/dout $p_name_1"
### connect_bd_net [get_bd_pins $p_cell_name/dout] [get_bd_pins $p_name_1]
### return
### set m_name_1 [ad_connect_type $p_name_1]
### set m_name_2 [ad_connect_type $p_name_2]
### if {$m_name_1 eq ""} {
### if {[get_property CLASS $m_name_2] eq "bd_intf_pin"} {
### puts "create_bd_intf_net $p_name_1"
### create_bd_intf_net $p_name_1
### if {[get_property CLASS $m_name_2] eq "bd_pin"} {
### puts "create_bd_net $p_name_1"
### create_bd_net $p_name_1
### if {[get_property CLASS $m_name_1] eq "bd_intf_pin"} {
### puts "connect_bd_intf_net $m_name_1 $m_name_2"
### connect_bd_intf_net $m_name_1 $m_name_2
### return
### if {[get_property CLASS $m_name_1] eq "bd_pin"} {
### puts "connect_bd_net $m_name_1 $m_name_2"
### connect_bd_net $m_name_1 $m_name_2
### return
### if {[get_property CLASS $m_name_1] eq "bd_net"} {
### puts "connect_bd_net -net $m_name_1 $m_name_2"
### connect_bd_net -net $m_name_1 $m_name_2
### return
### proc ad_mem_hp0_interconnect {p_clk p_name} {
### global sys_zynq
### if {($sys_zynq == 0) && ($p_name eq "sys_ps7/S_AXI_HP0")} {return}
### if {$sys_zynq == 0} {ad_mem_hpx_interconnect "MEM" $p_clk $p_name}
### if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP0" $p_clk $p_name}
### proc ad_mem_hp1_interconnect {p_clk p_name} {
### global sys_zynq
### if {($sys_zynq == 0) && ($p_name eq "sys_ps7/S_AXI_HP1")} {return}
### if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP1" $p_clk $p_name}
### proc ad_mem_hp2_interconnect {p_clk p_name} {
### global sys_zynq
### if {($sys_zynq == 0) && ($p_name eq "sys_ps7/S_AXI_HP2")} {return}
### if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP2" $p_clk $p_name}
### proc ad_mem_hp3_interconnect {p_clk p_name} {
### global sys_zynq
### if {($sys_zynq == 0) && ($p_name eq "sys_ps7/S_AXI_HP3")} {return}
### if {$sys_zynq == 1} {ad_mem_hpx_interconnect "HP3" $p_clk $p_name}
### proc ad_mem_hpx_interconnect {p_sel p_clk p_name} {
### global sys_zynq
### global sys_ddr_addr_seg
### global sys_hp0_interconnect_index
### global sys_hp1_interconnect_index
### global sys_hp2_interconnect_index
### global sys_hp3_interconnect_index
### global sys_mem_interconnect_index
### set p_clk_source [get_bd_pins -filter {DIR == O} -of_objects [get_bd_nets $p_clk]]
### if {$p_sel eq "MEM"} {
### if {$sys_mem_interconnect_index < 0} {
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_mem_interconnect
### set m_interconnect_index $sys_mem_interconnect_index
### set m_interconnect_cell [get_bd_cells axi_mem_interconnect]
### set m_addr_seg [get_bd_addr_segs -of_objects [get_bd_cells axi_ddr_cntrl]]
### if {$p_sel eq "HP0"} {
### if {$sys_hp0_interconnect_index < 0} {
### set_property CONFIG.PCW_USE_S_AXI_HP0 {1} [get_bd_cells sys_ps7]
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_hp0_interconnect
### set m_interconnect_index $sys_hp0_interconnect_index
### set m_interconnect_cell [get_bd_cells axi_hp0_interconnect]
### set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP0/HP0_DDR_LOWOCM]
### if {$p_sel eq "HP1"} {
### if {$sys_hp1_interconnect_index < 0} {
### set_property CONFIG.PCW_USE_S_AXI_HP1 {1} [get_bd_cells sys_ps7]
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_hp1_interconnect
### set m_interconnect_index $sys_hp1_interconnect_index
### set m_interconnect_cell [get_bd_cells axi_hp1_interconnect]
### set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP1/HP1_DDR_LOWOCM]
### if {$p_sel eq "HP2"} {
### if {$sys_hp2_interconnect_index < 0} {
### set_property CONFIG.PCW_USE_S_AXI_HP2 {1} [get_bd_cells sys_ps7]
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_hp2_interconnect
### set m_interconnect_index $sys_hp2_interconnect_index
### set m_interconnect_cell [get_bd_cells axi_hp2_interconnect]
### set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP2/HP2_DDR_LOWOCM]
### if {$p_sel eq "HP3"} {
### if {$sys_hp3_interconnect_index < 0} {
### set_property CONFIG.PCW_USE_S_AXI_HP3 {1} [get_bd_cells sys_ps7]
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_hp3_interconnect
### set m_interconnect_index $sys_hp3_interconnect_index
### set m_interconnect_cell [get_bd_cells axi_hp3_interconnect]
### set m_addr_seg [get_bd_addr_segs sys_ps7/S_AXI_HP3/HP3_DDR_LOWOCM]
### set i_str "S$m_interconnect_index"
### if {$m_interconnect_index < 10} {
### set i_str "S0$m_interconnect_index"
### set m_interconnect_index [expr $m_interconnect_index + 1]
### set p_intf_name [lrange [split $p_name "/"] end end]
### set p_cell_name [lrange [split $p_name "/"] 0 0]
### set p_intf_clock [get_bd_pins -filter "TYPE == clk && (CONFIG.ASSOCIATED_BUSIF == ${p_intf_name} || \
### CONFIG.ASSOCIATED_BUSIF =~ ${p_intf_name}:* || CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name} || \
### CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name}:*)" -quiet -of_objects [get_bd_cells $p_cell_name]]
### if {[find_bd_objs -quiet -relation connected_to $p_intf_clock] ne "" ||
### $p_intf_clock eq $p_clk_source} {
### set p_intf_clock ""
### if {$m_interconnect_index == 0} {
### set_property CONFIG.NUM_MI 1 $m_interconnect_cell
### set_property CONFIG.NUM_SI 1 $m_interconnect_cell
### ad_connect sys_cpu_resetn $m_interconnect_cell/ARESETN
### ad_connect $p_clk $m_interconnect_cell/ACLK
### ad_connect sys_cpu_resetn $m_interconnect_cell/M00_ARESETN
### ad_connect $p_clk $m_interconnect_cell/M00_ACLK
### ad_connect $m_interconnect_cell/M00_AXI $p_name
### if {$p_intf_clock ne ""} {
### ad_connect $p_clk $p_intf_clock
### } else {
### set_property CONFIG.NUM_SI $m_interconnect_index $m_interconnect_cell
### ad_connect sys_cpu_resetn $m_interconnect_cell/${i_str}_ARESETN
### ad_connect $p_clk $m_interconnect_cell/${i_str}_ACLK
### ad_connect $m_interconnect_cell/${i_str}_AXI $p_name
### assign_bd_address $m_addr_seg
### if {$m_interconnect_index == 3} {
### set_property CONFIG.STRATEGY {2} $m_interconnect_cell
### if {$p_sel eq "MEM"} {set sys_mem_interconnect_index $m_interconnect_index}
### if {$p_sel eq "HP0"} {set sys_hp0_interconnect_index $m_interconnect_index}
### if {$p_sel eq "HP1"} {set sys_hp1_interconnect_index $m_interconnect_index}
### if {$p_sel eq "HP2"} {set sys_hp2_interconnect_index $m_interconnect_index}
### if {$p_sel eq "HP3"} {set sys_hp3_interconnect_index $m_interconnect_index}
### proc ad_cpu_interconnect {p_address p_name} {
### global sys_zynq
### global sys_cpu_interconnect_index
### set i_str "M$sys_cpu_interconnect_index"
### if {$sys_cpu_interconnect_index < 10} {
### set i_str "M0$sys_cpu_interconnect_index"
### if {$sys_cpu_interconnect_index == 0} {
### create_bd_cell -type ip -vlnv xilinx.com:ip:axi_interconnect:2.1 axi_cpu_interconnect
### ad_connect sys_cpu_clk sys_ps7/M_AXI_GP0_ACLK
### ad_connect sys_cpu_clk axi_cpu_interconnect/ACLK
### ad_connect sys_cpu_clk axi_cpu_interconnect/S00_ACLK
### ad_connect sys_cpu_resetn axi_cpu_interconnect/ARESETN
### ad_connect sys_cpu_resetn axi_cpu_interconnect/S00_ARESETN
### ad_connect axi_cpu_interconnect/S00_AXI sys_ps7/M_AXI_GP0
### } else {
### ad_connect axi_cpu_interconnect/S00_AXI sys_mb/M_AXI_DP
### set sys_addr_cntrl_space [get_bd_addr_spaces sys_ps7/Data]
### } else {
### set sys_addr_cntrl_space [get_bd_addr_spaces sys_mb/Data]
### set sys_cpu_interconnect_index [expr $sys_cpu_interconnect_index + 1]
### set p_intf [get_bd_intf_pins -filter "MODE == Slave && VLNV == xilinx.com:interface:aximm_rtl:1.0"\
### -of_objects [get_bd_cells $p_name]]
### set p_intf_name [lrange [split $p_intf "/"] end end]
### CONFIG.ASSOCIATED_BUSIF =~ *:${p_intf_name}:*)" -quiet -of_objects [get_bd_cells $p_name]]
### set p_intf_reset [get_bd_pins -filter "TYPE == rst && (CONFIG.ASSOCIATED_BUSIF == ${p_intf_name} || \
### if {($p_intf_clock ne "") && ($p_intf_reset eq "")} {
### set p_intf_reset [get_property CONFIG.ASSOCIATED_RESET [get_bd_pins ${p_intf_clock}]]
### if {$p_intf_reset ne ""} {
### set p_intf_reset [get_bd_pins $p_name/$p_intf_reset]
### if {[find_bd_objs -quiet -relation connected_to $p_intf_clock] ne ""} {
### if {[find_bd_objs -quiet -relation connected_to $p_intf_reset] ne ""} {
### set p_intf_reset ""
### set_property CONFIG.NUM_MI $sys_cpu_interconnect_index [get_bd_cells axi_cpu_interconnect]
### ad_connect sys_cpu_clk axi_cpu_interconnect/${i_str}_ACLK
### ad_connect sys_cpu_clk ${p_intf_clock}
### ad_connect sys_cpu_resetn axi_cpu_interconnect/${i_str}_ARESETN
### ad_connect sys_cpu_resetn ${p_intf_reset}
### ad_connect axi_cpu_interconnect/${i_str}_AXI ${p_intf}
### set p_seg [get_bd_addr_segs -of_objects [get_bd_cells $p_name]]
### set p_index 0
### foreach p_seg_name $p_seg {
### if {$p_index == 0} {
### set p_seg_range [get_property range $p_seg_name]
### create_bd_addr_seg -range $p_seg_range \
### -offset $p_address $sys_addr_cntrl_space \
### $p_seg_name "SEG_data_${p_name}"
### } else {
### assign_bd_address $p_seg_name
### incr p_index
### proc ad_cpu_interrupt {p_ps_index p_mb_index p_name} {
### global sys_zynq
### set p_index [regsub -all {[^0-9]} $p_ps_index ""]
### } else {
### set p_index [regsub -all {[^0-9]} $p_mb_index ""]
### set p_net [get_bd_nets -of_objects [get_bd_pins sys_concat_intc/In$p_index]]
### set p_pin [find_bd_objs -relation connected_to [get_bd_pins sys_concat_intc/In$p_index]]
### puts "delete_bd_objs $p_net $p_pin"
### delete_bd_objs $p_net $p_pin
### ad_connect sys_concat_intc/In$p_index $p_name
## adi_project_create fmcomms5_zc706 $proj_dir config_rx.tcl
INFO: [IP_Flow 19-1700] Loaded user IP repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:cordic_demod:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_cordic_demod_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_interfaces_1.0
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad6676_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-725] Reloaded user IP repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad6676:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad6676_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad6676_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9122_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9122:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9122_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9122_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9144_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9144:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9144_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9144_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9152_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9152:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9152_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9152_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9234_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9234:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9234_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9234_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9250_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9250:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9250_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9250_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9265_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9265:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9265_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9265_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9361_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9361:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9361_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9361_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9434_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9434:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9434_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9434_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9467_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9467:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9467_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9467_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9625_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9625:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9625_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9625_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9643_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
CRITICAL WARNING: [IP_Flow 19-1663] Duplicate IP found for 'analog.com:user:axi_ad9643:1.0'. The one found in IP location 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9643_1.0' will take precedence over the same IP in location e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9643_1.0_1
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9652_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [Common 17-14] Message 'IP_Flow 19-1663' appears 100 times and further instances of the messages will be disabled. Use the Tcl command set_msg_config to change the current settings.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9671_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9680_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_ad9739a_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_adcfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_clkgen_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_dmac_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_generic_adc_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_gpreg_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_hdmi_rx_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_hdmi_tx_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_i2s_adi_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
WARNING: [IP_Flow 19-1694] Ignoring duplicate Bus Definition IP file 'analog.com:interface:i2s:1.0' found within IP repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
WARNING: [IP_Flow 19-1694] Ignoring duplicate Bus Abstraction IP file 'analog.com:interface:i2s_rtl:1.0' found within IP repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_jesd_gt_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_spdif_rx_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_spdif_tx_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_axi_usb_fx3_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_cordic_demod_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_interfaces_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_adcfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_adc_pack_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_axis_fifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_axis_resize_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_bsplit_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_ccat_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_clkdiv_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_cpack_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_dacfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_dac_unpack_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_gmii_to_rgmii_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_gtlb_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_i2c_mixer_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_jesd_gt_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_mfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_pmod_adc_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_pmod_fmeter_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_rfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_sigma_delta_spi_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_tdd_sync_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_upack_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
INFO: [IP_Flow 19-949] Unzipped 'E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library/analog.com_user_util_wfifo_1.0.zip' into repository 'e:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/library'.
Wrote : <E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/vivado_prj.srcs/sources_1/bd/system/system.bd>
### source $ad_hdl_dir/projects/common/zc706/zc706_system_bd.tcl
#### create_bd_intf_port -mode Master -vlnv xilinx.com:interface:ddrx_rtl:1.0 ddr
#### create_bd_intf_port -mode Master -vlnv xilinx.com:interface:iic_rtl:1.0 iic_main
#### create_bd_intf_port -mode Master -vlnv xilinx.com:display_processing_system7:fixedio_rtl:1.0 fixed_io
#### create_bd_port -dir O spi0_csn_2_o
#### create_bd_port -dir O spi0_csn_1_o
#### create_bd_port -dir O spi0_csn_0_o
#### create_bd_port -dir I spi0_csn_i
#### create_bd_port -dir I spi0_clk_i
#### create_bd_port -dir O spi0_clk_o
#### create_bd_port -dir I spi0_sdo_i
#### create_bd_port -dir O spi0_sdo_o
#### create_bd_port -dir I spi0_sdi_i
#### create_bd_port -dir O spi1_csn_2_o
#### create_bd_port -dir O spi1_csn_1_o
#### create_bd_port -dir O spi1_csn_0_o
#### create_bd_port -dir I spi1_csn_i
#### create_bd_port -dir I spi1_clk_i
#### create_bd_port -dir O spi1_clk_o
#### create_bd_port -dir I spi1_sdo_i
#### create_bd_port -dir O spi1_sdo_o
#### create_bd_port -dir I spi1_sdi_i
#### create_bd_port -dir I -from 63 -to 0 gpio_i
#### create_bd_port -dir O -from 63 -to 0 gpio_o
#### create_bd_port -dir O -from 63 -to 0 gpio_t
#### create_bd_port -dir O hdmi_out_clk
#### create_bd_port -dir O hdmi_hsync
#### create_bd_port -dir O hdmi_vsync
#### create_bd_port -dir O hdmi_data_e
#### create_bd_port -dir O -from 23 -to 0 hdmi_data
#### create_bd_port -dir O spdif
#### create_bd_port -dir I -type intr ps_intr_00
#### create_bd_port -dir I -type intr ps_intr_01
#### create_bd_port -dir I -type intr ps_intr_02
#### create_bd_port -dir I -type intr ps_intr_03
#### create_bd_port -dir I -type intr ps_intr_04
#### create_bd_port -dir I -type intr ps_intr_05
#### create_bd_port -dir I -type intr ps_intr_06
#### create_bd_port -dir I -type intr ps_intr_07
#### create_bd_port -dir I -type intr ps_intr_08
#### create_bd_port -dir I -type intr ps_intr_09
#### create_bd_port -dir I -type intr ps_intr_10
#### create_bd_port -dir I -type intr ps_intr_11
#### create_bd_port -dir I -type intr ps_intr_12
#### create_bd_port -dir I -type intr ps_intr_13
#### set sys_ps7 [create_bd_cell -type ip -vlnv xilinx.com:ip:processing_system7:5.5 sys_ps7]
#### set_property -dict [list CONFIG.preset {ZC706}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_TTC0_PERIPHERAL_ENABLE {0}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_EN_CLK1_PORT {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_EN_RST1_PORT {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_EN_CLK2_PORT {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_EN_RST2_PORT {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_FPGA0_PERIPHERAL_FREQMHZ {100.0}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_FPGA1_PERIPHERAL_FREQMHZ {200.0}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_USE_FABRIC_INTERRUPT {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_IRQ_F2P_INTR {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_GPIO_EMIO_GPIO_ENABLE {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_GPIO_EMIO_GPIO_IO {64}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_USE_DMA0 {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_IRQ_F2P_MODE {REVERSE}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_SPI0_PERIPHERAL_ENABLE {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_SPI0_SPI0_IO {EMIO}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_SPI1_PERIPHERAL_ENABLE {1}] $sys_ps7
#### set_property -dict [list CONFIG.PCW_SPI1_SPI1_IO {EMIO}] $sys_ps7
#### set axi_iic_main [create_bd_cell -type ip -vlnv xilinx.com:ip:axi_iic:2.0 axi_iic_main]
#### set_property -dict [list CONFIG.USE_BOARD_FLOW {true}] $axi_iic_main
#### set_property -dict [list CONFIG.IIC_BOARD_INTERFACE {Custom}] $axi_iic_main
#### set sys_concat_intc [create_bd_cell -type ip -vlnv xilinx.com:ip:xlconcat:2.1 sys_concat_intc]
#### set_property -dict [list CONFIG.NUM_PORTS {16}] $sys_concat_intc
#### set sys_rstgen [create_bd_cell -type ip -vlnv xilinx.com:ip:proc_sys_reset:5.0 sys_rstgen]
#### set_property -dict [list CONFIG.C_EXT_RST_WIDTH {1}] $sys_rstgen
#### set axi_hdmi_clkgen [create_bd_cell -type ip -vlnv analog.com:user:axi_clkgen:1.0 axi_hdmi_clkgen]
#### set axi_hdmi_core [create_bd_cell -type ip -vlnv analog.com:user:axi_hdmi_tx:1.0 axi_hdmi_core]
#### set axi_hdmi_dma [create_bd_cell -type ip -vlnv xilinx.com:ip:axi_vdma:6.2 axi_hdmi_dma]
#### set_property -dict [list CONFIG.C_M_AXIS_MM2S_TDATA_WIDTH {64}] $axi_hdmi_dma
#### set_property -dict [list CONFIG.C_USE_MM2S_FSYNC {1}] $axi_hdmi_dma
#### set_property -dict [list CONFIG.C_INCLUDE_S2MM {0}] $axi_hdmi_dma
#### set sys_audio_clkgen [create_bd_cell -type ip -vlnv xilinx.com:ip:clk_wiz:5.1 sys_audio_clkgen]
#### set_property -dict [list CONFIG.PRIM_IN_FREQ {200.000}] $sys_audio_clkgen
#### set_property -dict [list CONFIG.CLKOUT1_REQUESTED_OUT_FREQ {12.288}] $sys_audio_clkgen
#### set_property -dict [list CONFIG.USE_LOCKED {false}] $sys_audio_clkgen
#### set_property -dict [list CONFIG.USE_RESET {true} CONFIG.RESET_TYPE {ACTIVE_LOW}] $sys_audio_clkgen
#### set axi_spdif_tx_core [create_bd_cell -type ip -vlnv analog.com:user:axi_spdif_tx:1.0 axi_spdif_tx_core]
#### set_property -dict [list CONFIG.DMA_TYPE {1}] $axi_spdif_tx_core
#### set_property -dict [list CONFIG.S_AXI_ADDRESS_WIDTH {16}] $axi_spdif_tx_core
#### ad_connect sys_cpu_clk sys_ps7/FCLK_CLK0
create_bd_net sys_cpu_clk
connect_bd_net -net /sys_cpu_clk /sys_ps7/FCLK_CLK0
#### ad_connect sys_200m_clk sys_ps7/FCLK_CLK1
create_bd_net sys_200m_clk
connect_bd_net -net /sys_200m_clk /sys_ps7/FCLK_CLK1
#### ad_connect sys_cpu_reset sys_rstgen/peripheral_reset
create_bd_net sys_cpu_reset
connect_bd_net -net /sys_cpu_reset /sys_rstgen/peripheral_reset
#### ad_connect sys_cpu_resetn sys_rstgen/peripheral_aresetn
create_bd_net sys_cpu_resetn
connect_bd_net -net /sys_cpu_resetn /sys_rstgen/peripheral_aresetn
#### ad_connect sys_cpu_clk sys_rstgen/slowest_sync_clk
connect_bd_net -net /sys_cpu_clk /sys_rstgen/slowest_sync_clk
#### ad_connect sys_rstgen/ext_reset_in sys_ps7/FCLK_RESET0_N
connect_bd_net /sys_rstgen/ext_reset_in /sys_ps7/FCLK_RESET0_N
#### ad_connect ddr sys_ps7/DDR
connect_bd_intf_net /ddr /sys_ps7/DDR
#### ad_connect gpio_i sys_ps7/GPIO_I
connect_bd_net /gpio_i /sys_ps7/GPIO_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/GPIO_I is being overridden by the user. This pin will not be connected as a part of interface connection GPIO_0
#### ad_connect gpio_o sys_ps7/GPIO_O
connect_bd_net /gpio_o /sys_ps7/GPIO_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/GPIO_O is being overridden by the user. This pin will not be connected as a part of interface connection GPIO_0
#### ad_connect gpio_t sys_ps7/GPIO_T
connect_bd_net /gpio_t /sys_ps7/GPIO_T
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/GPIO_T is being overridden by the user. This pin will not be connected as a part of interface connection GPIO_0
#### ad_connect fixed_io sys_ps7/FIXED_IO
connect_bd_intf_net /fixed_io /sys_ps7/FIXED_IO
#### ad_connect iic_main axi_iic_main/iic
connect_bd_intf_net /iic_main /axi_iic_main/IIC
#### ad_connect sys_200m_clk axi_hdmi_clkgen/clk
connect_bd_net -net /sys_200m_clk /axi_hdmi_clkgen/clk
#### ad_connect spi0_csn_2_o sys_ps7/SPI0_SS2_O
connect_bd_net /spi0_csn_2_o /sys_ps7/SPI0_SS2_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SS2_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_csn_1_o sys_ps7/SPI0_SS1_O
connect_bd_net /spi0_csn_1_o /sys_ps7/SPI0_SS1_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SS1_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_csn_0_o sys_ps7/SPI0_SS_O
connect_bd_net /spi0_csn_0_o /sys_ps7/SPI0_SS_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SS_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_csn_i sys_ps7/SPI0_SS_I
connect_bd_net /spi0_csn_i /sys_ps7/SPI0_SS_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SS_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_clk_i sys_ps7/SPI0_SCLK_I
connect_bd_net /spi0_clk_i /sys_ps7/SPI0_SCLK_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SCLK_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_clk_o sys_ps7/SPI0_SCLK_O
connect_bd_net /spi0_clk_o /sys_ps7/SPI0_SCLK_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_SCLK_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_sdo_i sys_ps7/SPI0_MOSI_I
connect_bd_net /spi0_sdo_i /sys_ps7/SPI0_MOSI_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_MOSI_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_sdo_o sys_ps7/SPI0_MOSI_O
connect_bd_net /spi0_sdo_o /sys_ps7/SPI0_MOSI_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_MOSI_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi0_sdi_i sys_ps7/SPI0_MISO_I
connect_bd_net /spi0_sdi_i /sys_ps7/SPI0_MISO_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI0_MISO_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_0
#### ad_connect spi1_csn_2_o sys_ps7/SPI1_SS2_O
connect_bd_net /spi1_csn_2_o /sys_ps7/SPI1_SS2_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SS2_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_csn_1_o sys_ps7/SPI1_SS1_O
connect_bd_net /spi1_csn_1_o /sys_ps7/SPI1_SS1_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SS1_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_csn_0_o sys_ps7/SPI1_SS_O
connect_bd_net /spi1_csn_0_o /sys_ps7/SPI1_SS_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SS_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_csn_i sys_ps7/SPI1_SS_I
connect_bd_net /spi1_csn_i /sys_ps7/SPI1_SS_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SS_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_clk_i sys_ps7/SPI1_SCLK_I
connect_bd_net /spi1_clk_i /sys_ps7/SPI1_SCLK_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SCLK_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_clk_o sys_ps7/SPI1_SCLK_O
connect_bd_net /spi1_clk_o /sys_ps7/SPI1_SCLK_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_SCLK_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_sdo_i sys_ps7/SPI1_MOSI_I
connect_bd_net /spi1_sdo_i /sys_ps7/SPI1_MOSI_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_MOSI_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_sdo_o sys_ps7/SPI1_MOSI_O
connect_bd_net /spi1_sdo_o /sys_ps7/SPI1_MOSI_O
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_MOSI_O is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect spi1_sdi_i sys_ps7/SPI1_MISO_I
connect_bd_net /spi1_sdi_i /sys_ps7/SPI1_MISO_I
INFO: [BD 41-1306] The connection to interface pin /sys_ps7/SPI1_MISO_I is being overridden by the user. This pin will not be connected as a part of interface connection SPI_1
#### ad_connect sys_cpu_clk axi_hdmi_core/vdma_clk
connect_bd_net -net /sys_cpu_clk /axi_hdmi_core/vdma_clk
#### ad_connect sys_cpu_clk axi_hdmi_dma/m_axis_mm2s_aclk
connect_bd_net -net /sys_cpu_clk /axi_hdmi_dma/m_axis_mm2s_aclk
#### ad_connect axi_hdmi_core/hdmi_clk axi_hdmi_clkgen/clk_0
connect_bd_net /axi_hdmi_core/hdmi_clk /axi_hdmi_clkgen/clk_0
#### ad_connect axi_hdmi_core/hdmi_out_clk hdmi_out_clk
connect_bd_net /axi_hdmi_core/hdmi_out_clk /hdmi_out_clk
#### ad_connect axi_hdmi_core/hdmi_24_hsync hdmi_hsync
connect_bd_net /axi_hdmi_core/hdmi_24_hsync /hdmi_hsync
#### ad_connect axi_hdmi_core/hdmi_24_vsync hdmi_vsync
connect_bd_net /axi_hdmi_core/hdmi_24_vsync /hdmi_vsync
#### ad_connect axi_hdmi_core/hdmi_24_data_e hdmi_data_e
connect_bd_net /axi_hdmi_core/hdmi_24_data_e /hdmi_data_e
#### ad_connect axi_hdmi_core/hdmi_24_data hdmi_data
connect_bd_net /axi_hdmi_core/hdmi_24_data /hdmi_data
#### ad_connect axi_hdmi_core/vdma_valid axi_hdmi_dma/m_axis_mm2s_tvalid
connect_bd_net /axi_hdmi_core/vdma_valid /axi_hdmi_dma/m_axis_mm2s_tvalid
INFO: [BD 41-1306] The connection to interface pin /axi_hdmi_dma/m_axis_mm2s_tvalid is being overridden by the user. This pin will not be connected as a part of interface connection M_AXIS_MM2S
#### ad_connect axi_hdmi_core/vdma_data axi_hdmi_dma/m_axis_mm2s_tdata
connect_bd_net /axi_hdmi_core/vdma_data /axi_hdmi_dma/m_axis_mm2s_tdata
INFO: [BD 41-1306] The connection to interface pin /axi_hdmi_dma/m_axis_mm2s_tdata is being overridden by the user. This pin will not be connected as a part of interface connection M_AXIS_MM2S
#### ad_connect axi_hdmi_core/vdma_ready axi_hdmi_dma/m_axis_mm2s_tready
connect_bd_net /axi_hdmi_core/vdma_ready /axi_hdmi_dma/m_axis_mm2s_tready
INFO: [BD 41-1306] The connection to interface pin /axi_hdmi_dma/m_axis_mm2s_tready is being overridden by the user. This pin will not be connected as a part of interface connection M_AXIS_MM2S
#### ad_connect axi_hdmi_core/vdma_fs axi_hdmi_dma/mm2s_fsync
connect_bd_net /axi_hdmi_core/vdma_fs /axi_hdmi_dma/mm2s_fsync
#### ad_connect axi_hdmi_core/vdma_fs axi_hdmi_core/vdma_fs_ret
connect_bd_net /axi_hdmi_core/vdma_fs /axi_hdmi_core/vdma_fs_ret
#### ad_connect sys_cpu_clk axi_spdif_tx_core/DMA_REQ_ACLK
connect_bd_net -net /sys_cpu_clk /axi_spdif_tx_core/DMA_REQ_ACLK
#### ad_connect sys_cpu_clk sys_ps7/DMA0_ACLK
connect_bd_net -net /sys_cpu_clk /sys_ps7/DMA0_ACLK
#### ad_connect sys_cpu_resetn axi_spdif_tx_core/DMA_REQ_RSTN
connect_bd_net -net /sys_cpu_resetn /axi_spdif_tx_core/DMA_REQ_RSTN
#### ad_connect sys_ps7/DMA0_REQ axi_spdif_tx_core/DMA_REQ
connect_bd_intf_net /sys_ps7/DMA0_REQ /axi_spdif_tx_core/DMA_REQ
#### ad_connect sys_ps7/DMA0_ACK axi_spdif_tx_core/DMA_ACK
connect_bd_intf_net /sys_ps7/DMA0_ACK /axi_spdif_tx_core/DMA_ACK
#### ad_connect sys_200m_clk sys_audio_clkgen/clk_in1
connect_bd_net -net /sys_200m_clk /sys_audio_clkgen/clk_in1
#### ad_connect sys_cpu_resetn sys_audio_clkgen/resetn
connect_bd_net -net /sys_cpu_resetn /sys_audio_clkgen/resetn
#### ad_connect sys_audio_clkgen/clk_out1 axi_spdif_tx_core/spdif_data_clk
connect_bd_net /sys_audio_clkgen/clk_out1 /axi_spdif_tx_core/spdif_data_clk
#### ad_connect spdif axi_spdif_tx_core/spdif_tx_o
connect_bd_net /spdif /axi_spdif_tx_core/spdif_tx_o
#### ad_connect sys_concat_intc/dout sys_ps7/IRQ_F2P
connect_bd_net /sys_concat_intc/dout /sys_ps7/IRQ_F2P
#### ad_connect sys_concat_intc/In15 axi_hdmi_dma/mm2s_introut
connect_bd_net /sys_concat_intc/In15 /axi_hdmi_dma/mm2s_introut
#### ad_connect sys_concat_intc/In14 axi_iic_main/iic2intc_irpt
connect_bd_net /sys_concat_intc/In14 /axi_iic_main/iic2intc_irpt
#### ad_connect sys_concat_intc/In13 ps_intr_13
connect_bd_net /sys_concat_intc/In13 /ps_intr_13
#### ad_connect sys_concat_intc/In12 ps_intr_12
connect_bd_net /sys_concat_intc/In12 /ps_intr_12
#### ad_connect sys_concat_intc/In11 ps_intr_11
connect_bd_net /sys_concat_intc/In11 /ps_intr_11
#### ad_connect sys_concat_intc/In10 ps_intr_10
connect_bd_net /sys_concat_intc/In10 /ps_intr_10
#### ad_connect sys_concat_intc/In9 ps_intr_09
connect_bd_net /sys_concat_intc/In9 /ps_intr_09
#### ad_connect sys_concat_intc/In8 ps_intr_08
connect_bd_net /sys_concat_intc/In8 /ps_intr_08
#### ad_connect sys_concat_intc/In7 ps_intr_07
connect_bd_net /sys_concat_intc/In7 /ps_intr_07
#### ad_connect sys_concat_intc/In6 ps_intr_06
connect_bd_net /sys_concat_intc/In6 /ps_intr_06
#### ad_connect sys_concat_intc/In5 ps_intr_05
connect_bd_net /sys_concat_intc/In5 /ps_intr_05
#### ad_connect sys_concat_intc/In4 ps_intr_04
connect_bd_net /sys_concat_intc/In4 /ps_intr_04
#### ad_connect sys_concat_intc/In3 ps_intr_03
connect_bd_net /sys_concat_intc/In3 /ps_intr_03
#### ad_connect sys_concat_intc/In2 ps_intr_02
connect_bd_net /sys_concat_intc/In2 /ps_intr_02
#### ad_connect sys_concat_intc/In1 ps_intr_01
connect_bd_net /sys_concat_intc/In1 /ps_intr_01
#### ad_connect sys_concat_intc/In0 ps_intr_00
connect_bd_net /sys_concat_intc/In0 /ps_intr_00
#### ad_cpu_interconnect 0x41600000 axi_iic_main
connect_bd_net -net /sys_cpu_clk /sys_ps7/M_AXI_GP0_ACLK
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/ACLK
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/S00_ACLK
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/S00_ARESETN
connect_bd_intf_net /axi_cpu_interconnect/S00_AXI /sys_ps7/M_AXI_GP0
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M00_ACLK
connect_bd_net -net /sys_cpu_clk /axi_iic_main/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M00_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_iic_main/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M00_AXI /axi_iic_main/S_AXI
#### ad_cpu_interconnect 0x79000000 axi_hdmi_clkgen
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M01_ACLK
connect_bd_net -net /sys_cpu_clk /axi_hdmi_clkgen/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M01_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_hdmi_clkgen/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M01_AXI /axi_hdmi_clkgen/s_axi
#### ad_cpu_interconnect 0x43000000 axi_hdmi_dma
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M02_ACLK
connect_bd_net -net /sys_cpu_clk /axi_hdmi_dma/s_axi_lite_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M02_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_hdmi_dma/axi_resetn
connect_bd_intf_net /axi_cpu_interconnect/M02_AXI /axi_hdmi_dma/S_AXI_LITE
#### ad_cpu_interconnect 0x70e00000 axi_hdmi_core
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M03_ACLK
connect_bd_net -net /sys_cpu_clk /axi_hdmi_core/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M03_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_hdmi_core/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M03_AXI /axi_hdmi_core/s_axi
#### ad_cpu_interconnect 0x75c00000 axi_spdif_tx_core
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M04_ACLK
connect_bd_net -net /sys_cpu_clk /axi_spdif_tx_core/S_AXI_ACLK
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M04_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_spdif_tx_core/S_AXI_ARESETN
connect_bd_intf_net /axi_cpu_interconnect/M04_AXI /axi_spdif_tx_core/S_AXI
#### ad_mem_hp0_interconnect sys_cpu_clk sys_ps7/S_AXI_HP0
connect_bd_net -net /sys_cpu_resetn /axi_hp0_interconnect/ARESETN
connect_bd_net -net /sys_cpu_clk /axi_hp0_interconnect/ACLK
connect_bd_net -net /sys_cpu_resetn /axi_hp0_interconnect/M00_ARESETN
connect_bd_net -net /sys_cpu_clk /axi_hp0_interconnect/M00_ACLK
connect_bd_intf_net /axi_hp0_interconnect/M00_AXI /sys_ps7/S_AXI_HP0
connect_bd_net -net /sys_cpu_clk /sys_ps7/S_AXI_HP0_ACLK
#### ad_mem_hp0_interconnect sys_cpu_clk axi_hdmi_dma/M_AXI_MM2S
connect_bd_net -net /sys_cpu_resetn /axi_hp0_interconnect/S00_ARESETN
connect_bd_net -net /sys_cpu_clk /axi_hp0_interconnect/S00_ACLK
connect_bd_intf_net /axi_hp0_interconnect/S00_AXI /axi_hdmi_dma/M_AXI_MM2S
connect_bd_net -net /sys_cpu_clk /axi_hdmi_dma/m_axi_mm2s_aclk
</sys_ps7/S_AXI_HP0/HP0_DDR_LOWOCM> is being mapped into </axi_hdmi_dma/Data_MM2S> at <0x00000000[ 1G ]>
### source $ad_hdl_dir/projects/common/xilinx/sys_wfifo.tcl
#### proc p_sys_wfifo {p_name m_name adc_data_width dma_data_width} {
#### global ad_hdl_dir
#### set p_instance [get_bd_cells $p_name]
#### set c_instance [current_bd_instance .]
#### current_bd_instance $p_instance
#### set m_instance [create_bd_cell -type hier $m_name]
#### current_bd_instance $m_instance
#### create_bd_pin -dir I adc_rst
#### create_bd_pin -dir I -type clk adc_clk
#### create_bd_pin -dir I adc_wr
#### create_bd_pin -dir I -from [expr ($adc_data_width-1)] -to 0 adc_wdata
#### create_bd_pin -dir O adc_wovf
#### create_bd_pin -dir I -type clk dma_clk
#### create_bd_pin -dir O dma_wr
#### create_bd_pin -dir O -from [expr ($dma_data_width-1)] -to 0 dma_wdata
#### create_bd_pin -dir I dma_wovf
#### set wfifo_ctl [create_bd_cell -type ip -vlnv analog.com:user:util_wfifo:1.0 wfifo_ctl]
#### set_property -dict [list CONFIG.ADC_DATA_WIDTH $adc_data_width] $wfifo_ctl
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH $dma_data_width] $wfifo_ctl
#### set wfifo_mem [create_bd_cell -type ip -vlnv xilinx.com:ip:fifo_generator:12.0 wfifo_mem]
#### set_property -dict [list CONFIG.INTERFACE_TYPE {Native}] $wfifo_mem
#### set_property -dict [list CONFIG.Fifo_Implementation {Independent_Clocks_Block_RAM}] $wfifo_mem
#### set_property -dict [list CONFIG.Input_Data_Width $adc_data_width] $wfifo_mem
#### set_property -dict [list CONFIG.Input_Depth {64}] $wfifo_mem
#### set_property -dict [list CONFIG.Output_Data_Width $dma_data_width] $wfifo_mem
#### set_property -dict [list CONFIG.Overflow_Flag {true}] $wfifo_mem
#### connect_bd_net -net adc_rst [get_bd_pins adc_rst]
#### connect_bd_net -net adc_clk [get_bd_pins adc_clk]
#### connect_bd_net -net dma_clk [get_bd_pins dma_clk]
#### connect_bd_net -net adc_rst [get_bd_pins wfifo_ctl/adc_rst]
#### connect_bd_net -net adc_clk [get_bd_pins wfifo_ctl/adc_clk]
#### connect_bd_net -net dma_clk [get_bd_pins wfifo_ctl/dma_clk]
#### connect_bd_net -net adc_clk [get_bd_pins wfifo_mem/wr_clk]
#### connect_bd_net -net dma_clk [get_bd_pins wfifo_mem/rd_clk]
#### connect_bd_net -net adc_wr [get_bd_pins adc_wr] [get_bd_pins wfifo_ctl/adc_wr]
#### connect_bd_net -net adc_wdata [get_bd_pins adc_wdata] [get_bd_pins wfifo_ctl/adc_wdata]
#### connect_bd_net -net adc_wovf [get_bd_pins adc_wovf] [get_bd_pins wfifo_ctl/adc_wovf]
#### connect_bd_net -net dma_wr [get_bd_pins dma_wr] [get_bd_pins wfifo_ctl/dma_wr]
#### connect_bd_net -net dma_wdata [get_bd_pins dma_wdata] [get_bd_pins wfifo_ctl/dma_wdata]
#### connect_bd_net -net dma_wovf [get_bd_pins dma_wovf] [get_bd_pins wfifo_ctl/dma_wovf]
#### connect_bd_net -net wfifo_ctl_fifo_rst [get_bd_pins wfifo_ctl/fifo_rst] [get_bd_pins wfifo_mem/rst]
#### connect_bd_net -net wfifo_ctl_fifo_wr [get_bd_pins wfifo_ctl/fifo_wr] [get_bd_pins wfifo_mem/wr_en]
#### connect_bd_net -net wfifo_ctl_fifo_wdata [get_bd_pins wfifo_ctl/fifo_wdata] [get_bd_pins wfifo_mem/din]
#### connect_bd_net -net wfifo_ctl_fifo_wovf [get_bd_pins wfifo_ctl/fifo_wovf] [get_bd_pins wfifo_mem/overflow]
#### connect_bd_net -net wfifo_ctl_fifo_rd [get_bd_pins wfifo_ctl/fifo_rd] [get_bd_pins wfifo_mem/rd_en]
#### connect_bd_net -net wfifo_ctl_fifo_rdata [get_bd_pins wfifo_ctl/fifo_rdata] [get_bd_pins wfifo_mem/dout]
#### connect_bd_net -net wfifo_ctl_fifo_rempty [get_bd_pins wfifo_ctl/fifo_rempty] [get_bd_pins wfifo_mem/empty]
#### current_bd_instance $c_instance
### source $ad_hdl_dir/projects/common/xilinx/sys_rfifo.tcl
#### proc p_sys_rfifo {p_name m_name dac_data_width dma_data_width} {
#### create_bd_pin -dir I -type clk dac_clk
#### create_bd_pin -dir I dac_rd
#### create_bd_pin -dir O -from [expr ($dac_data_width-1)] -to 0 dac_rdata
#### create_bd_pin -dir O dac_runf
#### create_bd_pin -dir O dma_rd
#### create_bd_pin -dir I -from [expr ($dma_data_width-1)] -to 0 dma_rdata
#### create_bd_pin -dir I dma_runf
#### set rfifo_ctl [create_bd_cell -type ip -vlnv analog.com:user:util_rfifo:1.0 rfifo_ctl]
#### set_property -dict [list CONFIG.DAC_DATA_WIDTH $dac_data_width] $rfifo_ctl
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH $dma_data_width] $rfifo_ctl
#### set rfifo_mem [create_bd_cell -type ip -vlnv xilinx.com:ip:fifo_generator:12.0 rfifo_mem]
#### set_property -dict [list CONFIG.INTERFACE_TYPE {Native}] $rfifo_mem
#### set_property -dict [list CONFIG.Fifo_Implementation {Independent_Clocks_Block_RAM}] $rfifo_mem
#### set_property -dict [list CONFIG.Input_Data_Width $dma_data_width] $rfifo_mem
#### set_property -dict [list CONFIG.Input_Depth {64}] $rfifo_mem
#### set_property -dict [list CONFIG.Output_Data_Width $dac_data_width] $rfifo_mem
#### set_property -dict [list CONFIG.Underflow_Flag {true}] $rfifo_mem
#### set_property -dict [list CONFIG.Reset_Pin {true}] $rfifo_mem
#### set_property -dict [list CONFIG.Programmable_Full_Type {Single_Programmable_Full_Threshold_Constant}] $rfifo_mem
#### set_property -dict [list CONFIG.Full_Threshold_Assert_Value {50}] $rfifo_mem
#### connect_bd_net -net dac_clk [get_bd_pins dac_clk] [get_bd_pins rfifo_ctl/dac_clk]
#### connect_bd_net -net dma_clk [get_bd_pins dma_clk] [get_bd_pins rfifo_ctl/dma_clk]
#### connect_bd_net -net dma_clk [get_bd_pins rfifo_mem/wr_clk]
#### connect_bd_net -net dac_clk [get_bd_pins rfifo_mem/rd_clk]
#### connect_bd_net -net dac_rd [get_bd_pins dac_rd] [get_bd_pins rfifo_ctl/dac_rd]
#### connect_bd_net -net dac_rdata [get_bd_pins dac_rdata] [get_bd_pins rfifo_ctl/dac_rdata]
#### connect_bd_net -net dac_runf [get_bd_pins dac_runf] [get_bd_pins rfifo_ctl/dac_runf]
#### connect_bd_net -net dma_rd [get_bd_pins dma_rd] [get_bd_pins rfifo_ctl/dma_rd]
#### connect_bd_net -net dma_rdata [get_bd_pins dma_rdata] [get_bd_pins rfifo_ctl/dma_rdata]
#### connect_bd_net -net dma_runf [get_bd_pins dma_runf] [get_bd_pins rfifo_ctl/dma_runf]
#### connect_bd_net -net rfifo_ctl_fifo_rst [get_bd_pins rfifo_ctl/fifo_rst] [get_bd_pins rfifo_mem/rst]
#### connect_bd_net -net rfifo_ctl_fifo_wr [get_bd_pins rfifo_ctl/fifo_wr] [get_bd_pins rfifo_mem/wr_en]
#### connect_bd_net -net rfifo_ctl_fifo_wdata [get_bd_pins rfifo_ctl/fifo_wdata] [get_bd_pins rfifo_mem/din]
#### connect_bd_net -net rfifo_ctl_fifo_wfull [get_bd_pins rfifo_ctl/fifo_wfull] [get_bd_pins rfifo_mem/prog_full]
#### connect_bd_net -net rfifo_ctl_fifo_rd [get_bd_pins rfifo_ctl/fifo_rd] [get_bd_pins rfifo_mem/rd_en]
#### connect_bd_net -net rfifo_ctl_fifo_rdata [get_bd_pins rfifo_ctl/fifo_rdata] [get_bd_pins rfifo_mem/dout]
#### connect_bd_net -net rfifo_ctl_fifo_rempty [get_bd_pins rfifo_ctl/fifo_rempty] [get_bd_pins rfifo_mem/empty]
#### connect_bd_net -net rfifo_ctl_fifo_runf [get_bd_pins rfifo_ctl/fifo_runf] [get_bd_pins rfifo_mem/underflow]
### set_property -dict [list CONFIG.PCW_FPGA2_PERIPHERAL_FREQMHZ {200.0}] $sys_ps7
### ad_connect sys_dma_clk sys_ps7/FCLK_CLK2
create_bd_net sys_dma_clk
connect_bd_net -net /sys_dma_clk /sys_ps7/FCLK_CLK2
### source $ad_hdl_dir/projects/fmcomms5/common/fmcomms5_bd.tcl
#### create_bd_port -dir I rx_clk_in_0_p
#### create_bd_port -dir I rx_clk_in_0_n
#### create_bd_port -dir I rx_frame_in_0_p
#### create_bd_port -dir I rx_frame_in_0_n
#### create_bd_port -dir I -from 5 -to 0 rx_data_in_0_p
#### create_bd_port -dir I -from 5 -to 0 rx_data_in_0_n
#### create_bd_port -dir O tx_clk_out_0_p
#### create_bd_port -dir O tx_clk_out_0_n
#### create_bd_port -dir O tx_frame_out_0_p
#### create_bd_port -dir O tx_frame_out_0_n
#### create_bd_port -dir O -from 5 -to 0 tx_data_out_0_p
#### create_bd_port -dir O -from 5 -to 0 tx_data_out_0_n
#### create_bd_port -dir I rx_clk_in_1_p
#### create_bd_port -dir I rx_clk_in_1_n
#### create_bd_port -dir I rx_frame_in_1_p
#### create_bd_port -dir I rx_frame_in_1_n
#### create_bd_port -dir I -from 5 -to 0 rx_data_in_1_p
#### create_bd_port -dir I -from 5 -to 0 rx_data_in_1_n
#### create_bd_port -dir O tx_clk_out_1_p
#### create_bd_port -dir O tx_clk_out_1_n
#### create_bd_port -dir O tx_frame_out_1_p
#### create_bd_port -dir O tx_frame_out_1_n
#### create_bd_port -dir O -from 5 -to 0 tx_data_out_1_p
#### create_bd_port -dir O -from 5 -to 0 tx_data_out_1_n
#### create_bd_port -dir O sys_100m_resetn
#### set axi_ad9361_0 [create_bd_cell -type ip -vlnv analog.com:user:axi_ad9361:1.0 axi_ad9361_0]
#### set_property -dict [list CONFIG.ID {0}] $axi_ad9361_0
#### set_property -dict [list CONFIG.IO_DELAY_GROUP {dev_0_if_delay_group}] $axi_ad9361_0
#### set axi_ad9361_1 [create_bd_cell -type ip -vlnv analog.com:user:axi_ad9361:1.0 axi_ad9361_1]
#### set_property -dict [list CONFIG.ID {1}] $axi_ad9361_1
#### set_property -dict [list CONFIG.IO_DELAY_GROUP {dev_1_if_delay_group}] $axi_ad9361_1
#### set axi_ad9361_dac_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_ad9361_dac_dma]
#### set_property -dict [list CONFIG.DMA_TYPE_SRC {0}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.DMA_TYPE_DEST {2}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.CYCLIC {1}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.SYNC_TRANSFER_START {0}] $axi_ad9361_dac_dma
WARNING: [BD 41-721] Attempt to set value '0' on disabled parameter 'SYNC_TRANSFER_START' of cell '/axi_ad9361_dac_dma' is ignored
#### set_property -dict [list CONFIG.AXI_SLICE_SRC {0}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.AXI_SLICE_DEST {1}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.DMA_2D_TRANSFER {0}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_DEST {128}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_SRC {128}] $axi_ad9361_dac_dma
#### if {$sys_zynq == 1} {
#### set_property -dict [list CONFIG.DMA_AXI_PROTOCOL_SRC {1}] $axi_ad9361_dac_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_SRC {64}] $axi_ad9361_dac_dma
#### set axi_ad9361_adc_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_ad9361_adc_dma]
#### set_property -dict [list CONFIG.DMA_TYPE_SRC {2}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_TYPE_DEST {0}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.CYCLIC {0}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.SYNC_TRANSFER_START {1}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.AXI_SLICE_SRC {1}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.AXI_SLICE_DEST {0}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_2D_TRANSFER {0}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_DEST {128}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_SRC {128}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_AXI_PROTOCOL_DEST {1}] $axi_ad9361_adc_dma
#### set_property -dict [list CONFIG.DMA_DATA_WIDTH_DEST {64}] $axi_ad9361_adc_dma
#### set util_upack_dac [create_bd_cell -type ip -vlnv analog.com:user:util_upack:1.0 util_upack_dac]
#### set_property -dict [list CONFIG.CHANNEL_DATA_WIDTH {16}] $util_upack_dac
#### set_property -dict [list CONFIG.NUM_OF_CHANNELS {8}] $util_upack_dac
#### set util_cpack_adc [create_bd_cell -type ip -vlnv analog.com:user:util_cpack:1.0 util_cpack_adc]
#### set_property -dict [list CONFIG.CHANNEL_DATA_WIDTH {16}] $util_cpack_adc
#### set_property -dict [list CONFIG.NUM_OF_CHANNELS {8}] $util_cpack_adc
#### set adc_wfifo [create_bd_cell -type ip -vlnv analog.com:user:util_wfifo:1.0 adc_wfifo]
#### set_property -dict [list CONFIG.NUM_OF_CHANNELS {8} ] $adc_wfifo
#### set_property -dict [list CONFIG.DIN_DATA_WIDTH {16} ] $adc_wfifo
#### set_property -dict [list CONFIG.DOUT_DATA_WIDTH {16} ] $adc_wfifo
#### set_property -dict [list CONFIG.DIN_ADDRESS_WIDTH {4}] $adc_wfifo
#### ad_connect sys_200m_clk axi_ad9361_0/delay_clk
connect_bd_net -net /sys_200m_clk /axi_ad9361_0/delay_clk
#### ad_connect sys_200m_clk axi_ad9361_1/delay_clk
connect_bd_net -net /sys_200m_clk /axi_ad9361_1/delay_clk
#### ad_connect axi_ad9361_0_clk axi_ad9361_0/l_clk
create_bd_net axi_ad9361_0_clk
connect_bd_net -net /axi_ad9361_0_clk /axi_ad9361_0/l_clk
#### ad_connect axi_ad9361_1_clk axi_ad9361_1/l_clk
create_bd_net axi_ad9361_1_clk
connect_bd_net -net /axi_ad9361_1_clk /axi_ad9361_1/l_clk
#### ad_connect axi_ad9361_0_clk axi_ad9361_0/clk
connect_bd_net -net /axi_ad9361_0_clk /axi_ad9361_0/clk
#### ad_connect axi_ad9361_0_clk axi_ad9361_1/clk
connect_bd_net -net /axi_ad9361_0_clk /axi_ad9361_1/clk
#### ad_connect axi_ad9361_0/rst adc_wfifo/din_rst
connect_bd_net /axi_ad9361_0/rst /adc_wfifo/din_rst
#### ad_connect axi_ad9361_0_clk adc_wfifo/din_clk
connect_bd_net -net /axi_ad9361_0_clk /adc_wfifo/din_clk
#### ad_connect sys_cpu_clk adc_wfifo/dout_clk
connect_bd_net -net /sys_cpu_clk /adc_wfifo/dout_clk
#### ad_connect sys_cpu_resetn adc_wfifo/dout_rstn
connect_bd_net -net /sys_cpu_resetn /adc_wfifo/dout_rstn
#### ad_connect sys_cpu_clk util_cpack_adc/adc_clk
connect_bd_net -net /sys_cpu_clk /util_cpack_adc/adc_clk
#### ad_connect sys_cpu_clk axi_ad9361_adc_dma/fifo_wr_clk
connect_bd_net -net /sys_cpu_clk /axi_ad9361_adc_dma/fifo_wr_clk
#### ad_connect axi_ad9361_0_clk util_upack_dac/dac_clk
connect_bd_net -net /axi_ad9361_0_clk /util_upack_dac/dac_clk
#### ad_connect axi_ad9361_0_clk axi_ad9361_dac_dma/fifo_rd_clk
connect_bd_net -net /axi_ad9361_0_clk /axi_ad9361_dac_dma/fifo_rd_clk
#### ad_connect sys_cpu_resetn sys_100m_resetn
connect_bd_net -net /sys_cpu_resetn /sys_100m_resetn
#### ad_connect sys_cpu_resetn axi_ad9361_adc_dma/m_dest_axi_aresetn
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_adc_dma/m_dest_axi_aresetn
#### ad_connect sys_cpu_resetn axi_ad9361_dac_dma/m_src_axi_aresetn
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_dac_dma/m_src_axi_aresetn
#### ad_connect sys_cpu_reset util_cpack_adc/adc_rst
connect_bd_net -net /sys_cpu_reset /util_cpack_adc/adc_rst
#### ad_connect axi_ad9361_0_dac_sync axi_ad9361_0/dac_sync_out
create_bd_net axi_ad9361_0_dac_sync
connect_bd_net -net /axi_ad9361_0_dac_sync /axi_ad9361_0/dac_sync_out
#### ad_connect axi_ad9361_0_dac_sync axi_ad9361_0/dac_sync_in
connect_bd_net -net /axi_ad9361_0_dac_sync /axi_ad9361_0/dac_sync_in
#### ad_connect axi_ad9361_0_dac_sync axi_ad9361_1/dac_sync_in
connect_bd_net -net /axi_ad9361_0_dac_sync /axi_ad9361_1/dac_sync_in
#### ad_connect rx_clk_in_0_p axi_ad9361_0/rx_clk_in_p
connect_bd_net /rx_clk_in_0_p /axi_ad9361_0/rx_clk_in_p
#### ad_connect rx_clk_in_0_n axi_ad9361_0/rx_clk_in_n
connect_bd_net /rx_clk_in_0_n /axi_ad9361_0/rx_clk_in_n
#### ad_connect rx_frame_in_0_p axi_ad9361_0/rx_frame_in_p
connect_bd_net /rx_frame_in_0_p /axi_ad9361_0/rx_frame_in_p
#### ad_connect rx_frame_in_0_n axi_ad9361_0/rx_frame_in_n
connect_bd_net /rx_frame_in_0_n /axi_ad9361_0/rx_frame_in_n
#### ad_connect rx_data_in_0_p axi_ad9361_0/rx_data_in_p
connect_bd_net /rx_data_in_0_p /axi_ad9361_0/rx_data_in_p
#### ad_connect rx_data_in_0_n axi_ad9361_0/rx_data_in_n
connect_bd_net /rx_data_in_0_n /axi_ad9361_0/rx_data_in_n
#### ad_connect tx_clk_out_0_p axi_ad9361_0/tx_clk_out_p
connect_bd_net /tx_clk_out_0_p /axi_ad9361_0/tx_clk_out_p
#### ad_connect tx_clk_out_0_n axi_ad9361_0/tx_clk_out_n
connect_bd_net /tx_clk_out_0_n /axi_ad9361_0/tx_clk_out_n
#### ad_connect tx_frame_out_0_p axi_ad9361_0/tx_frame_out_p
connect_bd_net /tx_frame_out_0_p /axi_ad9361_0/tx_frame_out_p
#### ad_connect tx_frame_out_0_n axi_ad9361_0/tx_frame_out_n
connect_bd_net /tx_frame_out_0_n /axi_ad9361_0/tx_frame_out_n
#### ad_connect tx_data_out_0_p axi_ad9361_0/tx_data_out_p
connect_bd_net /tx_data_out_0_p /axi_ad9361_0/tx_data_out_p
#### ad_connect tx_data_out_0_n axi_ad9361_0/tx_data_out_n
connect_bd_net /tx_data_out_0_n /axi_ad9361_0/tx_data_out_n
#### ad_connect rx_clk_in_1_p axi_ad9361_1/rx_clk_in_p
connect_bd_net /rx_clk_in_1_p /axi_ad9361_1/rx_clk_in_p
#### ad_connect rx_clk_in_1_n axi_ad9361_1/rx_clk_in_n
connect_bd_net /rx_clk_in_1_n /axi_ad9361_1/rx_clk_in_n
#### ad_connect rx_frame_in_1_p axi_ad9361_1/rx_frame_in_p
connect_bd_net /rx_frame_in_1_p /axi_ad9361_1/rx_frame_in_p
#### ad_connect rx_frame_in_1_n axi_ad9361_1/rx_frame_in_n
connect_bd_net /rx_frame_in_1_n /axi_ad9361_1/rx_frame_in_n
#### ad_connect rx_data_in_1_p axi_ad9361_1/rx_data_in_p
connect_bd_net /rx_data_in_1_p /axi_ad9361_1/rx_data_in_p
#### ad_connect rx_data_in_1_n axi_ad9361_1/rx_data_in_n
connect_bd_net /rx_data_in_1_n /axi_ad9361_1/rx_data_in_n
#### ad_connect tx_clk_out_1_p axi_ad9361_1/tx_clk_out_p
connect_bd_net /tx_clk_out_1_p /axi_ad9361_1/tx_clk_out_p
#### ad_connect tx_clk_out_1_n axi_ad9361_1/tx_clk_out_n
connect_bd_net /tx_clk_out_1_n /axi_ad9361_1/tx_clk_out_n
#### ad_connect tx_frame_out_1_p axi_ad9361_1/tx_frame_out_p
connect_bd_net /tx_frame_out_1_p /axi_ad9361_1/tx_frame_out_p
#### ad_connect tx_frame_out_1_n axi_ad9361_1/tx_frame_out_n
connect_bd_net /tx_frame_out_1_n /axi_ad9361_1/tx_frame_out_n
#### ad_connect tx_data_out_1_p axi_ad9361_1/tx_data_out_p
connect_bd_net /tx_data_out_1_p /axi_ad9361_1/tx_data_out_p
#### ad_connect tx_data_out_1_n axi_ad9361_1/tx_data_out_n
connect_bd_net /tx_data_out_1_n /axi_ad9361_1/tx_data_out_n
#### ad_connect axi_ad9361_0/adc_enable_i0 adc_wfifo/din_enable_0
connect_bd_net /axi_ad9361_0/adc_enable_i0 /adc_wfifo/din_enable_0
#### ad_connect axi_ad9361_0/adc_valid_i0 adc_wfifo/din_valid_0
connect_bd_net /axi_ad9361_0/adc_valid_i0 /adc_wfifo/din_valid_0
#### ad_connect axi_ad9361_0/adc_data_i0 adc_wfifo/din_data_0
connect_bd_net /axi_ad9361_0/adc_data_i0 /adc_wfifo/din_data_0
#### ad_connect axi_ad9361_0/adc_enable_q0 adc_wfifo/din_enable_1
connect_bd_net /axi_ad9361_0/adc_enable_q0 /adc_wfifo/din_enable_1
#### ad_connect axi_ad9361_0/adc_valid_q0 adc_wfifo/din_valid_1
connect_bd_net /axi_ad9361_0/adc_valid_q0 /adc_wfifo/din_valid_1
#### ad_connect axi_ad9361_0/adc_data_q0 adc_wfifo/din_data_1
connect_bd_net /axi_ad9361_0/adc_data_q0 /adc_wfifo/din_data_1
#### ad_connect axi_ad9361_0/adc_enable_i1 adc_wfifo/din_enable_2
connect_bd_net /axi_ad9361_0/adc_enable_i1 /adc_wfifo/din_enable_2
#### ad_connect axi_ad9361_0/adc_valid_i1 adc_wfifo/din_valid_2
connect_bd_net /axi_ad9361_0/adc_valid_i1 /adc_wfifo/din_valid_2
#### ad_connect axi_ad9361_0/adc_data_i1 adc_wfifo/din_data_2
connect_bd_net /axi_ad9361_0/adc_data_i1 /adc_wfifo/din_data_2
#### ad_connect axi_ad9361_0/adc_enable_q1 adc_wfifo/din_enable_3
connect_bd_net /axi_ad9361_0/adc_enable_q1 /adc_wfifo/din_enable_3
#### ad_connect axi_ad9361_0/adc_valid_q1 adc_wfifo/din_valid_3
connect_bd_net /axi_ad9361_0/adc_valid_q1 /adc_wfifo/din_valid_3
#### ad_connect axi_ad9361_0/adc_data_q1 adc_wfifo/din_data_3
connect_bd_net /axi_ad9361_0/adc_data_q1 /adc_wfifo/din_data_3
#### ad_connect axi_ad9361_1/adc_enable_i0 adc_wfifo/din_enable_4
connect_bd_net /axi_ad9361_1/adc_enable_i0 /adc_wfifo/din_enable_4
#### ad_connect axi_ad9361_1/adc_valid_i0 adc_wfifo/din_valid_4
connect_bd_net /axi_ad9361_1/adc_valid_i0 /adc_wfifo/din_valid_4
#### ad_connect axi_ad9361_1/adc_data_i0 adc_wfifo/din_data_4
connect_bd_net /axi_ad9361_1/adc_data_i0 /adc_wfifo/din_data_4
#### ad_connect axi_ad9361_1/adc_enable_q0 adc_wfifo/din_enable_5
connect_bd_net /axi_ad9361_1/adc_enable_q0 /adc_wfifo/din_enable_5
#### ad_connect axi_ad9361_1/adc_valid_q0 adc_wfifo/din_valid_5
connect_bd_net /axi_ad9361_1/adc_valid_q0 /adc_wfifo/din_valid_5
#### ad_connect axi_ad9361_1/adc_data_q0 adc_wfifo/din_data_5
connect_bd_net /axi_ad9361_1/adc_data_q0 /adc_wfifo/din_data_5
#### ad_connect axi_ad9361_1/adc_enable_i1 adc_wfifo/din_enable_6
connect_bd_net /axi_ad9361_1/adc_enable_i1 /adc_wfifo/din_enable_6
#### ad_connect axi_ad9361_1/adc_valid_i1 adc_wfifo/din_valid_6
connect_bd_net /axi_ad9361_1/adc_valid_i1 /adc_wfifo/din_valid_6
#### ad_connect axi_ad9361_1/adc_data_i1 adc_wfifo/din_data_6
connect_bd_net /axi_ad9361_1/adc_data_i1 /adc_wfifo/din_data_6
#### ad_connect axi_ad9361_1/adc_enable_q1 adc_wfifo/din_enable_7
connect_bd_net /axi_ad9361_1/adc_enable_q1 /adc_wfifo/din_enable_7
#### ad_connect axi_ad9361_1/adc_valid_q1 adc_wfifo/din_valid_7
connect_bd_net /axi_ad9361_1/adc_valid_q1 /adc_wfifo/din_valid_7
#### ad_connect axi_ad9361_1/adc_data_q1 adc_wfifo/din_data_7
connect_bd_net /axi_ad9361_1/adc_data_q1 /adc_wfifo/din_data_7
#### ad_connect util_cpack_adc/adc_enable_0 adc_wfifo/dout_enable_0
connect_bd_net /util_cpack_adc/adc_enable_0 /adc_wfifo/dout_enable_0
#### ad_connect util_cpack_adc/adc_valid_0 adc_wfifo/dout_valid_0
connect_bd_net /util_cpack_adc/adc_valid_0 /adc_wfifo/dout_valid_0
#### ad_connect util_cpack_adc/adc_data_0 adc_wfifo/dout_data_0
connect_bd_net /util_cpack_adc/adc_data_0 /adc_wfifo/dout_data_0
#### ad_connect util_cpack_adc/adc_enable_1 adc_wfifo/dout_enable_1
connect_bd_net /util_cpack_adc/adc_enable_1 /adc_wfifo/dout_enable_1
#### ad_connect util_cpack_adc/adc_valid_1 adc_wfifo/dout_valid_1
connect_bd_net /util_cpack_adc/adc_valid_1 /adc_wfifo/dout_valid_1
#### ad_connect util_cpack_adc/adc_data_1 adc_wfifo/dout_data_1
connect_bd_net /util_cpack_adc/adc_data_1 /adc_wfifo/dout_data_1
#### ad_connect util_cpack_adc/adc_enable_2 adc_wfifo/dout_enable_2
connect_bd_net /util_cpack_adc/adc_enable_2 /adc_wfifo/dout_enable_2
#### ad_connect util_cpack_adc/adc_valid_2 adc_wfifo/dout_valid_2
connect_bd_net /util_cpack_adc/adc_valid_2 /adc_wfifo/dout_valid_2
#### ad_connect util_cpack_adc/adc_data_2 adc_wfifo/dout_data_2
connect_bd_net /util_cpack_adc/adc_data_2 /adc_wfifo/dout_data_2
#### ad_connect util_cpack_adc/adc_enable_3 adc_wfifo/dout_enable_3
connect_bd_net /util_cpack_adc/adc_enable_3 /adc_wfifo/dout_enable_3
#### ad_connect util_cpack_adc/adc_valid_3 adc_wfifo/dout_valid_3
connect_bd_net /util_cpack_adc/adc_valid_3 /adc_wfifo/dout_valid_3
#### ad_connect util_cpack_adc/adc_data_3 adc_wfifo/dout_data_3
connect_bd_net /util_cpack_adc/adc_data_3 /adc_wfifo/dout_data_3
#### ad_connect util_cpack_adc/adc_enable_4 adc_wfifo/dout_enable_4
connect_bd_net /util_cpack_adc/adc_enable_4 /adc_wfifo/dout_enable_4
#### ad_connect util_cpack_adc/adc_valid_4 adc_wfifo/dout_valid_4
connect_bd_net /util_cpack_adc/adc_valid_4 /adc_wfifo/dout_valid_4
#### ad_connect util_cpack_adc/adc_data_4 adc_wfifo/dout_data_4
connect_bd_net /util_cpack_adc/adc_data_4 /adc_wfifo/dout_data_4
#### ad_connect util_cpack_adc/adc_enable_5 adc_wfifo/dout_enable_5
connect_bd_net /util_cpack_adc/adc_enable_5 /adc_wfifo/dout_enable_5
#### ad_connect util_cpack_adc/adc_valid_5 adc_wfifo/dout_valid_5
connect_bd_net /util_cpack_adc/adc_valid_5 /adc_wfifo/dout_valid_5
#### ad_connect util_cpack_adc/adc_data_5 adc_wfifo/dout_data_5
connect_bd_net /util_cpack_adc/adc_data_5 /adc_wfifo/dout_data_5
#### ad_connect util_cpack_adc/adc_enable_6 adc_wfifo/dout_enable_6
connect_bd_net /util_cpack_adc/adc_enable_6 /adc_wfifo/dout_enable_6
#### ad_connect util_cpack_adc/adc_valid_6 adc_wfifo/dout_valid_6
connect_bd_net /util_cpack_adc/adc_valid_6 /adc_wfifo/dout_valid_6
#### ad_connect util_cpack_adc/adc_data_6 adc_wfifo/dout_data_6
connect_bd_net /util_cpack_adc/adc_data_6 /adc_wfifo/dout_data_6
#### ad_connect util_cpack_adc/adc_enable_7 adc_wfifo/dout_enable_7
connect_bd_net /util_cpack_adc/adc_enable_7 /adc_wfifo/dout_enable_7
#### ad_connect util_cpack_adc/adc_valid_7 adc_wfifo/dout_valid_7
connect_bd_net /util_cpack_adc/adc_valid_7 /adc_wfifo/dout_valid_7
#### ad_connect util_cpack_adc/adc_data_7 adc_wfifo/dout_data_7
connect_bd_net /util_cpack_adc/adc_data_7 /adc_wfifo/dout_data_7
#### ad_connect util_cpack_adc/adc_valid axi_ad9361_adc_dma/fifo_wr_en
connect_bd_net /util_cpack_adc/adc_valid /axi_ad9361_adc_dma/fifo_wr_en
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_adc_dma/fifo_wr_en is being overridden by the user. This pin will not be connected as a part of interface connection fifo_wr
#### ad_connect util_cpack_adc/adc_sync axi_ad9361_adc_dma/fifo_wr_sync
connect_bd_net /util_cpack_adc/adc_sync /axi_ad9361_adc_dma/fifo_wr_sync
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_adc_dma/fifo_wr_sync is being overridden by the user. This pin will not be connected as a part of interface connection fifo_wr
#### ad_connect util_cpack_adc/adc_data axi_ad9361_adc_dma/fifo_wr_din
connect_bd_net /util_cpack_adc/adc_data /axi_ad9361_adc_dma/fifo_wr_din
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_adc_dma/fifo_wr_din is being overridden by the user. This pin will not be connected as a part of interface connection fifo_wr
#### ad_connect axi_ad9361_0/dac_enable_i0 util_upack_dac/dac_enable_0
connect_bd_net /axi_ad9361_0/dac_enable_i0 /util_upack_dac/dac_enable_0
#### ad_connect axi_ad9361_0/dac_valid_i0 util_upack_dac/dac_valid_0
connect_bd_net /axi_ad9361_0/dac_valid_i0 /util_upack_dac/dac_valid_0
#### ad_connect axi_ad9361_0/dac_data_i0 util_upack_dac/dac_data_0
connect_bd_net /axi_ad9361_0/dac_data_i0 /util_upack_dac/dac_data_0
#### ad_connect axi_ad9361_0/dac_enable_q0 util_upack_dac/dac_enable_1
connect_bd_net /axi_ad9361_0/dac_enable_q0 /util_upack_dac/dac_enable_1
#### ad_connect axi_ad9361_0/dac_valid_q0 util_upack_dac/dac_valid_1
connect_bd_net /axi_ad9361_0/dac_valid_q0 /util_upack_dac/dac_valid_1
#### ad_connect axi_ad9361_0/dac_data_q0 util_upack_dac/dac_data_1
connect_bd_net /axi_ad9361_0/dac_data_q0 /util_upack_dac/dac_data_1
#### ad_connect axi_ad9361_0/dac_enable_i1 util_upack_dac/dac_enable_2
connect_bd_net /axi_ad9361_0/dac_enable_i1 /util_upack_dac/dac_enable_2
#### ad_connect axi_ad9361_0/dac_valid_i1 util_upack_dac/dac_valid_2
connect_bd_net /axi_ad9361_0/dac_valid_i1 /util_upack_dac/dac_valid_2
#### ad_connect axi_ad9361_0/dac_data_i1 util_upack_dac/dac_data_2
connect_bd_net /axi_ad9361_0/dac_data_i1 /util_upack_dac/dac_data_2
#### ad_connect axi_ad9361_0/dac_enable_q1 util_upack_dac/dac_enable_3
connect_bd_net /axi_ad9361_0/dac_enable_q1 /util_upack_dac/dac_enable_3
#### ad_connect axi_ad9361_0/dac_valid_q1 util_upack_dac/dac_valid_3
connect_bd_net /axi_ad9361_0/dac_valid_q1 /util_upack_dac/dac_valid_3
#### ad_connect axi_ad9361_0/dac_data_q1 util_upack_dac/dac_data_3
connect_bd_net /axi_ad9361_0/dac_data_q1 /util_upack_dac/dac_data_3
#### ad_connect axi_ad9361_1/dac_enable_i0 util_upack_dac/dac_enable_4
connect_bd_net /axi_ad9361_1/dac_enable_i0 /util_upack_dac/dac_enable_4
#### ad_connect axi_ad9361_1/dac_valid_i0 util_upack_dac/dac_valid_4
connect_bd_net /axi_ad9361_1/dac_valid_i0 /util_upack_dac/dac_valid_4
#### ad_connect axi_ad9361_1/dac_data_i0 util_upack_dac/dac_data_4
connect_bd_net /axi_ad9361_1/dac_data_i0 /util_upack_dac/dac_data_4
#### ad_connect axi_ad9361_1/dac_enable_q0 util_upack_dac/dac_enable_5
connect_bd_net /axi_ad9361_1/dac_enable_q0 /util_upack_dac/dac_enable_5
#### ad_connect axi_ad9361_1/dac_valid_q0 util_upack_dac/dac_valid_5
connect_bd_net /axi_ad9361_1/dac_valid_q0 /util_upack_dac/dac_valid_5
#### ad_connect axi_ad9361_1/dac_data_q0 util_upack_dac/dac_data_5
connect_bd_net /axi_ad9361_1/dac_data_q0 /util_upack_dac/dac_data_5
#### ad_connect axi_ad9361_1/dac_enable_i1 util_upack_dac/dac_enable_6
connect_bd_net /axi_ad9361_1/dac_enable_i1 /util_upack_dac/dac_enable_6
#### ad_connect axi_ad9361_1/dac_valid_i1 util_upack_dac/dac_valid_6
connect_bd_net /axi_ad9361_1/dac_valid_i1 /util_upack_dac/dac_valid_6
#### ad_connect axi_ad9361_1/dac_data_i1 util_upack_dac/dac_data_6
connect_bd_net /axi_ad9361_1/dac_data_i1 /util_upack_dac/dac_data_6
#### ad_connect axi_ad9361_1/dac_enable_q1 util_upack_dac/dac_enable_7
connect_bd_net /axi_ad9361_1/dac_enable_q1 /util_upack_dac/dac_enable_7
#### ad_connect axi_ad9361_1/dac_valid_q1 util_upack_dac/dac_valid_7
connect_bd_net /axi_ad9361_1/dac_valid_q1 /util_upack_dac/dac_valid_7
#### ad_connect axi_ad9361_1/dac_data_q1 util_upack_dac/dac_data_7
connect_bd_net /axi_ad9361_1/dac_data_q1 /util_upack_dac/dac_data_7
#### ad_connect util_upack_dac/dac_valid axi_ad9361_dac_dma/fifo_rd_en
connect_bd_net /util_upack_dac/dac_valid /axi_ad9361_dac_dma/fifo_rd_en
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_dac_dma/fifo_rd_en is being overridden by the user. This pin will not be connected as a part of interface connection fifo_rd
#### ad_connect util_upack_dac/dac_data axi_ad9361_dac_dma/fifo_rd_dout
connect_bd_net /util_upack_dac/dac_data /axi_ad9361_dac_dma/fifo_rd_dout
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_dac_dma/fifo_rd_dout is being overridden by the user. This pin will not be connected as a part of interface connection fifo_rd
#### ad_connect axi_ad9361_0/adc_dovf axi_ad9361_adc_dma/fifo_wr_overflow
connect_bd_net /axi_ad9361_0/adc_dovf /axi_ad9361_adc_dma/fifo_wr_overflow
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_adc_dma/fifo_wr_overflow is being overridden by the user. This pin will not be connected as a part of interface connection fifo_wr
#### ad_connect axi_ad9361_0/dac_dunf axi_ad9361_dac_dma/fifo_rd_underflow
connect_bd_net /axi_ad9361_0/dac_dunf /axi_ad9361_dac_dma/fifo_rd_underflow
INFO: [BD 41-1306] The connection to interface pin /axi_ad9361_dac_dma/fifo_rd_underflow is being overridden by the user. This pin will not be connected as a part of interface connection fifo_rd
#### ad_cpu_interconnect 0x79020000 axi_ad9361_0
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M05_ACLK
connect_bd_net -net /sys_cpu_clk /axi_ad9361_0/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M05_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_0/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M05_AXI /axi_ad9361_0/s_axi
#### ad_cpu_interconnect 0x7C420000 axi_ad9361_dac_dma
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M06_ACLK
connect_bd_net -net /sys_cpu_clk /axi_ad9361_dac_dma/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M06_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_dac_dma/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M06_AXI /axi_ad9361_dac_dma/s_axi
#### ad_cpu_interconnect 0x7C400000 axi_ad9361_adc_dma
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M07_ACLK
connect_bd_net -net /sys_cpu_clk /axi_ad9361_adc_dma/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M07_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_adc_dma/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M07_AXI /axi_ad9361_adc_dma/s_axi
#### ad_cpu_interconnect 0x79040000 axi_ad9361_1
connect_bd_net -net /sys_cpu_clk /axi_cpu_interconnect/M08_ACLK
connect_bd_net -net /sys_cpu_clk /axi_ad9361_1/s_axi_aclk
connect_bd_net -net /sys_cpu_resetn /axi_cpu_interconnect/M08_ARESETN
connect_bd_net -net /sys_cpu_resetn /axi_ad9361_1/s_axi_aresetn
connect_bd_intf_net /axi_cpu_interconnect/M08_AXI /axi_ad9361_1/s_axi
#### ad_mem_hp2_interconnect sys_dma_clk sys_ps7/S_AXI_HP2
connect_bd_net -net /sys_cpu_resetn /axi_hp2_interconnect/ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp2_interconnect/ACLK
connect_bd_net -net /sys_cpu_resetn /axi_hp2_interconnect/M00_ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp2_interconnect/M00_ACLK
connect_bd_intf_net /axi_hp2_interconnect/M00_AXI /sys_ps7/S_AXI_HP2
connect_bd_net -net /sys_dma_clk /sys_ps7/S_AXI_HP2_ACLK
#### ad_mem_hp2_interconnect sys_dma_clk axi_ad9361_adc_dma/m_dest_axi
connect_bd_net -net /sys_cpu_resetn /axi_hp2_interconnect/S00_ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp2_interconnect/S00_ACLK
connect_bd_intf_net /axi_hp2_interconnect/S00_AXI /axi_ad9361_adc_dma/m_dest_axi
connect_bd_net -net /sys_dma_clk /axi_ad9361_adc_dma/m_dest_axi_aclk
</sys_ps7/S_AXI_HP2/HP2_DDR_LOWOCM> is being mapped into </axi_ad9361_adc_dma/m_dest_axi> at <0x00000000[ 1G ]>
#### ad_mem_hp3_interconnect sys_dma_clk sys_ps7/S_AXI_HP3
connect_bd_net -net /sys_cpu_resetn /axi_hp3_interconnect/ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp3_interconnect/ACLK
connect_bd_net -net /sys_cpu_resetn /axi_hp3_interconnect/M00_ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp3_interconnect/M00_ACLK
connect_bd_intf_net /axi_hp3_interconnect/M00_AXI /sys_ps7/S_AXI_HP3
connect_bd_net -net /sys_dma_clk /sys_ps7/S_AXI_HP3_ACLK
#### ad_mem_hp3_interconnect sys_dma_clk axi_ad9361_dac_dma/m_src_axi
connect_bd_net -net /sys_cpu_resetn /axi_hp3_interconnect/S00_ARESETN
connect_bd_net -net /sys_dma_clk /axi_hp3_interconnect/S00_ACLK
connect_bd_intf_net /axi_hp3_interconnect/S00_AXI /axi_ad9361_dac_dma/m_src_axi
connect_bd_net -net /sys_dma_clk /axi_ad9361_dac_dma/m_src_axi_aclk
</sys_ps7/S_AXI_HP3/HP3_DDR_LOWOCM> is being mapped into </axi_ad9361_dac_dma/m_src_axi> at <0x00000000[ 1G ]>
#### ad_cpu_interrupt ps-12 mb-12 axi_ad9361_dac_dma/irq
delete_bd_objs /ps_intr_12_1 /ps_intr_12
connect_bd_net /sys_concat_intc/In12 /axi_ad9361_dac_dma/irq
#### ad_cpu_interrupt ps-13 mb-13 axi_ad9361_adc_dma/irq
delete_bd_objs /ps_intr_13_1 /ps_intr_13
connect_bd_net /sys_concat_intc/In13 /axi_ad9361_adc_dma/irq
### set ad_hdl_dir [pwd]
### set proj_dir $ad_hdl_dir/projects/fmcomms5/zc706
### source $proj_dir/config_prj.tcl
#### create_bd_cell -type ip -vlnv analog.com:user:util_clkdiv:1.0 util_clkdiv_0
#### connect_bd_net -net [get_bd_nets axi_ad9361_0_clk] [get_bd_pins util_clkdiv_0/clk] [get_bd_pins axi_ad9361_0/l_clk]
#### set sys_rstgen1 [create_bd_cell -type ip -vlnv xilinx.com:ip:proc_sys_reset:5.0 proc_sys_reset_0]
#### set_property -dict [list CONFIG.C_EXT_RST_WIDTH {1}] $sys_rstgen1
#### connect_bd_net -net [get_bd_nets sys_ps7_FCLK_RESET0_N] [get_bd_pins proc_sys_reset_0/ext_reset_in] [get_bd_pins sys_ps7/FCLK_RESET0_N]
WARNING: [BD 5-234] No nets matched 'get_bd_nets util_clkdiv_0_clk_out'
#### connect_bd_net -net [get_bd_nets util_clkdiv_0_clk_out] [get_bd_pins proc_sys_reset_0/slowest_sync_clk] [get_bd_pins util_clkdiv_0/clk_out]
#### set_property -dict [list CONFIG.NUM_MI {10}] [get_bd_cells axi_cpu_interconnect]
#### connect_bd_net -net [get_bd_nets util_clkdiv_0_clk_out] [get_bd_pins axi_cpu_interconnect/M09_ACLK] [get_bd_pins util_clkdiv_0/clk_out]
#### connect_bd_net [get_bd_pins proc_sys_reset_0/interconnect_aresetn] [get_bd_pins axi_cpu_interconnect/M09_ARESETN]
### source $ad_hdl_dir/projects/fmcomms5/common/config_rx.tcl
WARNING: [BD 5-235] No pins matched 'get_bd_pins util_adc_pack_0/clk'
#### disconnect_bd_net /axi_ad9361_0_clk [get_bd_pins util_adc_pack_0/clk]
ERROR: [BD 5-158] Please run 'disconnect_bd_net -h'.
ERROR: [Common 17-39] 'disconnect_bd_net' failed due to earlier errors.
while executing
"disconnect_bd_net /axi_ad9361_0_clk [get_bd_pins util_adc_pack_0/clk]"
(file "E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/projects/fmcomms5/common/config_rx.tcl" line 2)
while executing
"source $ad_hdl_dir/projects/fmcomms5/common/config_rx.tcl"
(file "E:/PROJECT/weixin/MathWorks_tools-master/MathWorks_tools-master/targeting_models/ADSB/hdl_prj_ss5/vivado_ip_prj/projects/fmcomms5/zc706/config_rx.tcl" line 5)
while executing
"source $project_dir/$update_tcl"
(procedure "adi_project_create" line 108)
invoked from within
"adi_project_create fmcomms5_zc706 $proj_dir config_rx.tcl"
(file "vivado_custom_block_design.tcl" line 8)
while executing
"source vivado_custom_block_design.tcl"
(file "vivado_create_prj.tcl" line 14)
INFO: [Common 17-206] Exiting Vivado at Tue Jun 27 10:18:58 2017...
Elapsed time is 95.4251 seconds.
who can tell me why?
