ADV7627 HDMI Compliance Test ID 8-7 failed
Question asked by Sam.S on Jun 23, 2017
Latest reply on Nov 8, 2017 by Hub
Dear Sir,
Our customer are using ADV7627 to develop their product. Currently, their product have enter to HDMI compliance test stage, and found the HDMI CT Test ID 8-7 [Jitter Tolerance] failed.
About 8-7 failed portion is timing
1080P@60Hz (148.5 MHz) Type2: -> DJ=500K,CJ=10M and DJ=1M, CJ=7M failed.
480P@60Hz (27MHz) Type2: DJ=500K, CJ=10M and DJ=1M, CJ=7M failed
PS: DJ is data jitter, CJ is clock jitter
RD are using script v1.2 to set HDMI Rx EQ as below registers value:
58 01 04 ; default=0x00, RXB HBR Setting
58 3D 10 ; default=0x00, ADI Recommended Write
58 3E 69 ; default=0x79, ADI Recommended Write
58 3F 46 ; default=0x63, ADI Recommended Write
58 4E FE ; default=0x7B, ADI Recommended Write
58 4F 08 ; default=0x63, ADI Recommended Write
58 57 A3 ; default=0x30, ADI Recommended Write
58 58 04 ; default=0x01, ADI Recommended Write
58 6C 01 ; default=0xA3, ADI Recommended Write
58 6F 04 ; default=0x40, ADI Recommended Write
58 71 05 ; default=0x00, ADI Recommended Write
58 75 04 ; default=0x00, ADI Recommended Write
58 85 10 ; default=0x16, ADI Recommended Write
58 97 C0 ; default=0x80, ADI Recommended Write
58 9C 10 ; default=0x08, ADI Recommended Write
58 CB 01 ; default=0x00, ADI Recommended Write
And they registration dump value as attached file.
Their power 3.3V ripple is measured under 100mV.
Their product will going to Pre-MP stage, would you please kindly advise about this situation about this issue?
Thank you!
Sam
