ADV7611 ITU BT.656 limitations
Question asked by acebrian on Oct 13, 2011
Latest reply on Dec 31, 2012 by raymondcarter
We have designed a board that includes an ADV7611 and a MPEG2 encoder.
The MPEG2 encoder has a D1 8-bit parallel with embedded SAV/EAV  video input interface that only supports pixel clock from 27 MHz to 36 MHz. In fact this is PAL 720x576i or NTSC 720x480i ITU BT.656 compatible interface.
To configure the ADV7611 in this mode we are using the script found at http://ez.analog.com/thread/8553
About the ADV7611, which HDMI input modes will be compatible with the ITU BT.646 output format?
We have found at http://ez.analog.com/message/20318 that only 576i and 480i HDMI input will produce the desired ITU BT.646 output.
There is any way to configure (downscaling, dividing pixel clock, tweaking registers...) the ADV7611 in order to accept 576p, 720p, 1080p and 1080i HDMI inputs and produce the desired ITU BT.646 output?
Thanks.
