AD9265-FMC-125EBZ Schematic
Question asked by marcomercuri on Jun 13, 2017
Latest reply on Aug 4, 2017 by marcomercuri
Hi all,
I just got my AD9265-FMC-125EBZ Eval Card. I have three questions:
1) CLOCK IN
In my application, I need to provide the clock through my FPGA. In doing so I want to use the J201 CLKIN SMA connector. Looking at the board and/or schematic, it seems that the "default" configuration is the "Optional Oscillator" Y200. Can you please help me removing or inserting the proper components to enable the external CLK IN?
If I understood correctly, I should:
- remove R200 to disable Y200;
- remove R18 to disable Y200 path;
Which other "DNI' components should I add?
2) AIN
I'm thinking to use AIN. Can I use as in this initial configuration or should I add some "DNI" components?
3) AIN Dynamic Range
Which is the AIN dynamic range? I mean max input Vpp voltage and input frequency range.
Thanks.
Best Regards,
Marcp
