AD9957 can not output signal at 1Ghz external clock and some about spi
Question asked by Wmeng on Jun 7, 2017
Latest reply on Jul 5, 2017 by KennyG
Hello!
      I use 1Ghz external clock to driven AD9957,but it couldn't work。So i read the spi return data to check whether the data i write to the confirm regisrer is right (use 3-wire programming,signle tone mode) but the sdo is always high. I check the sync_clk and pdclk,there are still low.Is that mains the chips is broken? i examine the voltage of pin, is all right.
      The register i'm confirmed :
      cfr1: 01 00 00 02
      cfr2: 00 40 08 10
      cfr3: 17 39 40 00
      profile0: 00FF 0000 2E14 7AE1
      I send I/O UPDATE after sending all register data,is this the reason that the register couldn't wirte?
