AD717x continous conversion mode
Question asked by razavimday on Jun 6, 2017
Latest reply on Jun 9, 2017 by razavimday
AD7172-BRUZ
We use continuous conversion mode. we get the data ,and then DOUT/RDY push high
our OS monitor this DOUT/RDY PIN into the low level to trigger the interrupt, but when we finish conversion, the DOUT/RDY PIN has a short delay (t7???) in low level and then push high. Is this right?
ERROR WAVEFORM:(error triggered into interrupt, convert again, 744ns, our ODR=2.5KHz)
CH1 DIN YELLOW 0X44
CH4 SCKL GREEN NOW 8MHz
CH2 DOUT/RDY BLUE
CH3 CS PURPLE
if we add 10us delay(this value must be over 5us) when we finish interrupt, the waveforms and data are ok!
main SCH share to you,
REG share to you,
attention for read format
address:0x28
data:0X0509
We found the issue may called DOUT_REST t7,but we think the t7 in datasheet may use max value(the worse case) .
Could you help us to check this issue? 10us delay we can not endure. the total resource of system is not enough for this delay. Thanks!
