HDL reference design about AD9361 based on Xilinx FPGA platfrom
Question asked by YosenBian on Jun 1, 2017
Latest reply on Oct 20, 2017 by YosenBian
Hi ,
    I have already build up the HDL reference design based on Xilinx FPGA Zedboard, following the methods on the webpage below.
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/reference_hdl
https://wiki.analog.com/resources/eval/user-guides/ad-fmcomms2-ebz/software/no-os-setup
 I do not set up the Linux OS , and I just use the no-os software on SDK.
My Vivado tool version is 2014.4. So I use the the hdl package "hdl-hdl_2015_r1" which requires Vivado2014.4.1.
After I package all the IPs needed in "./hdl-hdl_2015_r1/library", I source the "system_project.tcl" in "./hdl-hdl_2015_r1.projects/fmcomms2/zed." And then Vivado builds up block design ,Synthesize, implementation, Generate bitstream automatically. And there are no timing and other errors information.
Then I follow the flows in the second webpage.
 And then I program the FPGA and run the application. I analyze the spectrum on frequency analyzer. It's OK.
when I setup the hardware as shown below. I supposed to receive a 1Mhz sine ware in Chipscope.
But I just receive the ware shown below.
siganl is the low 12 bit of the bus whih is captured by ila. and i have already change the radix into signed demical and display as analog signal. so the wave should be cntinuous.
I DO NOT MODIFY THE HDL.
I just insert one line in “main.c”.
#define XILINX_PLATFORM
I do not change any configuration information in the no-OS software reference design.
Do I make any mistakes??
And I have tried the AD9361 test mode. The result is the same. I think something wrong with the rx channel. But I don’t know what problem is.
How could I fix this problem.
Thanks.
