libiio slow reading without buffer
Question asked by ycdtosa on May 30, 2017
Latest reply on Nov 29, 2017 by mhennerich
Low-speed reading of device.
This is mostly a libiio question.
I have a iio adc connected via SPI to a beaglebone.
The DTS is working fine, and i can read the data in the iio:device0 tree.
( all the channels are in fact enabled
and reading from the corresponding in_voltage0_raw entries will give me the data i want )
However, when i try to read the data programmatically or even using iio_readev
i always get the same result.
iio_device_create_buffer() fails...
and it does so because iio_device_get_sample_size() always returns Zero, and this might be because after running iio_channel_enable (which might do nothing even if it does not have a return value) when i query if the channel is enabled (iio_channel_is_enabled) i find that it is in fact not enabled.
This is mostly because the driver i am using does not have any scan-elements attributes, and it might have an incomplete implementation of the industrial iio requirements.
I have read that there was a Low-speed reading mode implemented in libiio.
Are these still available through the API?
Is there any way i can read from the device without using a buffer?
Thanks in advance.
