array variable has array size + 1 in memory!
Question asked by johnmurray on Oct 6, 2011
Latest reply on Oct 6, 2011 by dsmtoday
I noticed this problem before with a SPI test app but it did not cause me any problems as I could just ignore the extra indexable memory location.
Basically I am declaring an array of size x but when I look at it in Data Memory and the array has a size of x + 1
#define TAPS1 1
#define TAPS2 2
#define TAPS3 3
extern float pm ch_ce2_F0_A[TAPS2];
extern float pm ch_ce2_F0_B[TAPS2+1];
extern float pm ch_ce2_F1_A[TAPS1];
extern float pm ch_ce2_F1_B[TAPS1+1];
extern float pm ch_ce2_F2_A[TAPS2];
extern float pm ch_ce2_F2_B[TAPS2+1];
extern float pm ch_ce2_F3_A[TAPS2];
extern float pm ch_ce2_F3_B[TAPS2+1];
extern float pm ch_ce2_F4_A[TAPS2];
extern float pm ch_ce2_F4_B[TAPS2+1];
extern float pm ch_ce2_F5_A[TAPS1];
extern float pm ch_ce2_F5_B[TAPS1+1];
extern float pm ch_ce2_Fosc;
extern float pm ch_ce2_k;
extern float pm ch_ce2_depth;
extern float pm ch_ce2_G;
So ch_ce2_F2_B should have 3 values but it has 4 values in the memory map!!!!
Same with ch_ce2_F3_B, ch_ce2_F3_B
I have noticed this before in other test apps but it never caused a problem before.
Now I am doing a memcpy over that block of memory, but because two of the arrays have extra space allocated, the memory does not align correctly!
What’s going on!
I tried changing the arrays to sid in dm instead of pm but this did not have any effect.
