IIO library
Question asked by ajaykuruba143@gmail.com on May 19, 2017
Latest reply on May 22, 2017 by larsc
Hi
i am using ADIS16485 IMU with iio.py library and this is the code i am running
import iio
from sys import argv
def main():
    print('Library version: %u.%u (git tag: %s)' % iio.version)
    if len(argv) == 3 and argv[1] == '--uri':
        uri = argv[2]
    else:
        contexts = iio.scan_contexts()
        if len(contexts) > 1:
            print('Multiple contexts found. Please select one using --uri:')
            for index, each in enumerate(contexts):
                print('\t%d: %s [%s]' % (index, contexts[each], each))
            return
        uri = next(iter(contexts), None)
    ctx = iio.Context(uri)
    if uri is not None:
        print('Using auto-detected IIO context at URI \"%s\"' % uri)
    print('IIO context created: ' + ctx.name)
    print('Backend version: %u.%u (git tag: %s)' % ctx.version)
    print('Backend description string: ' + ctx.description)
    if len(ctx.attrs) > 0:
        print('IIO context has %u attributes:' % len(ctx.attrs))
    for attr, value in ctx.attrs.items():
        print('\t' + attr + ': ' + value)
    print('IIO context has %u devices:' % len(ctx.devices))
    for dev in ctx.devices:
        print('\t' + dev.id + ': ' + dev.name)
        if dev is iio.Trigger:
            print('Found trigger! Rate: %u Hz' % dev.frequency)
        print('\t\t%u channels found:' % len(dev.channels))
        for chn in dev.channels:
            print('\t\t\t%s: %s (%s)' % (chn.id, chn.name or "", 'output' if chn.output else 'input'))
            if len(chn.attrs) != 0:
                print('\t\t\t%u channel-specific attributes found:' % len(chn.attrs))
            for attr in chn.attrs:
                try:
                    print('\t\t\t\t' + attr + ', value: ' + chn.attrs[attr].value)
                except OSError as e:
                    print('Unable to read ' + attr + ': ' + e.strerror)
        if len(dev.attrs) != 0:
            print('\t\t%u device-specific attributes found:' % len(dev.attrs))
        for attr in dev.attrs:
            try:
                print('\t\t\t' + attr + ', value: ' + dev.attrs[attr].value)
        if len(dev.debug_attrs) != 0:
            print('\t\t%u debug attributes found:' % len(dev.debug_attrs))
        for attr in dev.debug_attrs:
            try:
                print('\t\t\t' + attr + ', value: ' + dev.debug_attrs[attr].value)
if __name__ == '__main__':
main()
and this is my output
trigger0: adis16485-dev1
0 channls found:
iio:device0: xadc
9 channls found:
iio:device1: adis16485
8 channls found:
can i know the reason why adis16485 is detected as two devices and in
:/sys/bus/iio/devices/iio:device1/trigger$ cat current_trigger
adis16485-dev1
/sys/bus/iio/devices/trigger0$ cat name
adis16485-dev1
and all my 8 channel readings are 0
