AD5544 Single Supply Operation
Question asked by t8102 on Oct 6, 2011
Latest reply on Oct 21, 2011 by t8102
The AD5544 is recomended for single supple operation. However the recomended configuration uses an inverting mode op-amp to do the I to V conversion, which means that a negative rail is required for the op-amp; there goes the single supply operation. I believe this configuration is recomended to minimise drift over temperature by using the internal Rfb in the DAC. I could configure the op-amp as non-inverting, but then I would not be using the internal Rfb in the DAC. Is there a recomended method for configuring the AD5544 and its I to V op-amp for use on a single supply?
