Aardvark programming SigmaDSP without EVAL-ADUSB2EBZ
Question asked by Sinteck on Oct 5, 2011
Burned my programmer EVAL-ADUSB2EBZ, I found the solution to generate the file. HEX for programming with Aadvark or other EEprom programmer.
1- Loading file .dspproj    (schematic)
2- In Hardware configuration:
Selection: USBi programmer
                 I2C 0x68 (104) - ADAU1701 (example)
                 I2C 0xA0 (160) - E2prom
3- Click in Link Compile Download
     A USB communication failure has  occured.  (no problem).
4- In Hardware configuration:
Selection ADAU1701 right mouse click option (Write Lastest Compilation to E2prom)
Generator \IC2 folder in project com E2prom.HEX file.
5- Enter in config - IC2 WinE2PromLoader
Click download file to E2prom
Browser -   \IC2 folder with E2prom.HEX file
Click Display file:
Click in all text and control+C for copy:
Instalation WinHEX   text editor
http://winhex.en.softonic.com/
Selection FILE + NEW    16Kb:
In offset position 00000000 + press control+V
Click OK
Selection ASCII HEX format
Figure final:
   File save name.txt in folder
OPen Flash Center TotalPhase  Aardvark software
Configure your E2prom
Click in load file
Select : name.txt in Load file
Check hex positions values  e write
Done!!!!!!!!!!!!!!!!!!!!!!!
