FCOMMS4-EBZ+ZC706 no video
Question asked by MTYM on May 5, 2017
Latest reply on May 30, 2017 by charlyelkhoury
I also get no display to the HDMI monitor in my setup with ZC706 and a FMCOMMS4-EBZ.
I followed suggestions in the thread "No HDMI display when SD booting ZC706+ FMCOMMS5", and still have the problem.
I have also been following the steps at Zynq & Altera SoC Quick Start Guide [Analog Devices Wiki]
Synopsis: I downloaded the image for 2016_R1-2016_12_23.img, and installed this on an SDCARD.
On a PC, I mounted the SDCARD card and copied the files
BOOT.BIN
devicetree.dtb
from the zynq-zc706-adv7511-ad9364-fmcomms4
to the root directory of the SDCARD
I also copied the file uImage from zynq_common to the root of the SDCARD.
I also saved the default uEnv.txt file, and replaced it with the one from Larsc:
/barn/mac> od -c uEnv.txt
0000000 u e n v c m d = r u n a d i _
0000020 s d b o o t \n a d i _ s d b o o
0000040 t = e c h o C o p y i n g L
0000060 i n u x f r o m S D t o
0000100 R A M . . . & & f a t l o a
0000120 d m m c 0 0 x 3 0 0 0 0 0
0000140 0 $ { k e r n e l _ i m a g e
0000160 } & & f a t l o a d m m c
0000200 0 0 x 2 A 0 0 0 0 0 $ { d
0000220 e v i c e t r e e _ i m a g e }
0000240 & & i f f a t l o a d m
0000260 m c 0 0 x 2 0 0 0 0 0 0 $
0000300 { r a m d i s k _ i m a g e } ;
0000320 t h e n b o o t m 0 x 3 0
0000340 0 0 0 0 0 0 x 2 0 0 0 0 0 0
0000360 0 x 2 A 0 0 0 0 0 ; e l s e
0000400 b o o t m 0 x 3 0 0 0 0 0 0
0000420 - 0 x 2 A 0 0 0 0 0 ; f i \n
0000440 b o o t a r g s = c o n s o l e
0000460 = t t y P S 0 , 1 1 5 2 0 0 r
0000500 o o t = / d e v / m m c b l k 0
0000520 p 2 r w e a r l y p r i n t
0000540 k r o o t f s t y p e = e x t
0000560 4 r o o t w a i t \n \n
0000574
[2:32pm] [mac@regressions] /barn/mac>
I started the system up; bitstream loaded to the FPGA (Done light), and linux booted on the ARM9 (visible in uart console)
However, Nothing on the HDMI screen.
Looking at the console log shows that an HDMI screen was found; the adv7511 was found, and looking at a ps shows that many X processes are running, and the user analog is logged in.  (see below, highlighted in dark blue)
So I ran sudo adi_update_tools.sh to update the software; and much was done; and after rebooting,
still nothing on the HDMI screen; and still reports of HDMI screens, and X console.
I have three different HDMI screens; all work fine on a PC; none work with the ZC706
I have two ZC706 boards; both have the same symptoms.
Also I ran various iio_info scrpits and the like, and it seems that the FMCOMMS4-EBZ card is there and working (near as I can tell):
root@analog:~# iio_info
Library version: 0.8 (git tag: c48c08a)
Compiled with backends: local xml network
IIO context created with local backend.
Backend version: 0.8 (git tag: c48c08a)
Backend description string: Linux analog 4.6.0-gca4cf2a #21 SMP PREEMPT Mon Nov 21 14:17:49 GMT 2016 armv7l
IIO context has 5 devices:
iio:device0: ad7291
9 channels found:
temp0: (input)
3 channel-specific attributes found:
attr 0: scale value: 250
attr 1: mean_raw value: 125
attr 2: raw value: 125
Here is the boot sequence:
U-Boot 2014.07-dirty (Nov 20 2014 - 17:07:55)
Board: Xilinx Zynq
I2C: ready
DRAM: ECC disabled 1 GiB
MMC: zynq_sdhci: 0
SF: Detected S25FL128S_64K with page size 512 Bytes, erase size 128 KiB, total 32 MiB
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Hit any key to stop autoboot: 0
Device: zynq_sdhci
Manufacturer ID: 3
OEM: 5344
Tran Speed: 25000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uEnv.txt
380 bytes read in 35 ms (9.8 KiB/s)
Loaded environment from uEnv.txt
Importing environment from SD ...
Running uenvcmd ...
Copying Linux from SD to RAM...
reading uImage
3586384 bytes read in 618 ms (5.5 MiB/s)
reading devicetree.dtb
20578 bytes read in 48 ms (418 KiB/s)
reading uramdisk.image.gz
** Unable to read file uramdisk.image.gz **
## Booting kernel from Legacy Image at 03000000 ...
Image Name: Linux-4.6.0-gca4cf2a
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3586320 Bytes = 3.4 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 02a00000
Booting using the fdt blob at 0x2a00000
Loading Kernel Image ... OK
Loading Device Tree to 1fff7000, end 1ffff061 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 4.6.0-gca4cf2a (jenkins@romlx1) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-29) ) #21 SMP PREEMPT Mon Nov 21 14:17:49 GMT 2016
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Xilinx Zynq ZC706
bootconsole [earlycon0] enabled
cma: Reserved 128 MiB at 0x38000000
Memory policy: Data cache writealloc
percpu: Embedded 12 pages/cpu @ef7cd000 s19456 r8192 d21504 u49152
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260608
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 900896K/1048576K available (4800K kernel code, 244K rwdata, 1940K rodata, 248K init, 136K bss, 16608K reserved, 131072K cma-reserved, 131072K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc069d3e8 (6741 kB)
.init : 0xc069e000 - 0xc06dc000 ( 248 kB)
.data : 0xc06dc000 - 0xc07192a0 ( 245 kB)
.bss : 0xc07192a0 - 0xc073b4b0 ( 137 kB)
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
slcr mapped to f0802000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0802100
Zynq clock init
ps_clk frequency not specified, using 33 MHz.
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080a000, irq=17
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x82c0 - 0x8318
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=18 bucket_order=0
bounce: pool size: 64 pages
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Error: Driver 'mwipcore' is already registered, aborting...
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 43000000.axivdma: missing xlnx,flush-fsync property
xilinx-vdma 43000000.axivdma: missing xlnx,addrwidth property
xilinx-vdma 43000000.axivdma: Xilinx AXI VDMA Engine Driver Probed!!
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 143, base_baud = 3125000) is a xuartps
▒console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0872000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi32764.0: found s25fl128s, expected n25q128a11
m25p80 spi32764.0: s25fl128s (32768 Kbytes)
5 ofpart partitions found on MTD device spi32764.0
Creating 5 MTD partitions on "spi32764.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000540000 : "config"
0x000000540000-0x000000fc0000 : "image"
0x000000fc0000-0x000002000000 : "spare"
libphy: XEMACPS mii bus: probed
xemacps e000b000.eth: pdev->id -1, baseaddr 0xe000b000, irq 165
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
e0002000.usb supply vbus not found, using dummy regulator
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
i2c i2c-0: Added multiplexed i2c bus 1
i2c i2c-0: Added multiplexed i2c bus 2
at24 3-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 3
pca953x 4-0021: interrupt support not compiled in
i2c i2c-0: Added multiplexed i2c bus 4
rtc-pcf8563 5-0051: chip found, driver version 0.4.4
rtc-pcf8563 5-0051: rtc core: registered rtc-pcf8563 as rtc0
i2c i2c-0: Added multiplexed i2c bus 5
i2c i2c-0: Added multiplexed i2c bus 6
at24 7-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
i2c i2c-0: Added multiplexed i2c bus 7
i2c i2c-0: Added multiplexed i2c bus 8
pca954x 0-0074: registered 8 multiplexed busses for I2C switch pca9548
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
si570 1-005d: registered, current frequency 156250000 Hz
ad9361 spi32766.0: ad9361_probe : enter
mmc0: new SDHC card at address e624
mmcblk0: mmc0:e624 SD08G 7.40 GiB
mmcblk0: p1 p2 p3
usb 1-1: new high-speed USB device number 2 using ci_hdrc
ad9361 spi32766.0: ad9361_probe : AD936x Rev 2 successfully initialized
spi32765.0 supply vcc not found, using dummy regulator
adf4350 spi32765.0: Probe failed (muxout)
spi32765.1 supply vcc not found, using dummy regulator
adf4350 spi32765.1: Probe failed (muxout)
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
cf_axi_dds 79024000.cf-ad9361-dds-core-lpc: Analog Devices CF_AXI_DDS_DDS MASTER (8.00.b) at 0x79024000 mapped to 0xf099c000, probed DDS AD9364
Registering SWP/SWPB emulation handler
Console: switching to colour frame buffer device 240x67
axi-hdmi 70e00000.axi_hdmi: fb0: frame buffer device
[drm] Initialized axi_hdmi_drm 1.0.0 20120930 on minor 0
usb 1-1.3: new low-speed USB device number 3 using ci_hdrc
input: USB Keyboard as /devices/soc0/amba/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1702.0001/input/input0
hid-generic 0003:04D9:1702.0001: input,hidraw0: USB HID v1.10 Keyboard [ USB Keyboard] on usb-ci_hdrc.0-1.3/input0
input: USB Keyboard as /devices/soc0/amba/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1702.0002/input/input1
hid-generic 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Device [ USB Keyboard] on usb-ci_hdrc.0-1.3/input1
usb 1-1.4: new low-speed USB device number 4 using ci_hdrc
input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/soc0/amba/e0002000.usb/ci_hdrc.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0040.0003/input/input2
hid-generic 0003:045E:0040.0003: input,hidraw2: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-ci_hdrc.0-1.4/input0
cf_axi_adc 79020000.cf-ad9361-lpc: ADI AIM (9.00.b) at 0x79020000 mapped to 0xf11c0000, probed ADC AD9361 as MASTER
asoc-simple-card fpga-axi@0:adv7511_hdmi_snd: adv7511 <-> 75c00000.axi-spdif-tx mapping ok
input: gpio_keys as /devices/soc0/gpio_keys/input/input3
rtc-pcf8563 5-0051: setting system clock to 2017-05-05 19:39:50 UTC (1494013190)
ALSA device list:
#0: HDMI monitor
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 248K (c069e000 - c06dc000)
This architecture does not have kernel memory protection.
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
* Setting up X socket directories... le '/lib/modules/4.6.0-gca4cf[ OK ] les.dep.bin'
* STARTDISTCC is set to false in /etc/default/distcc
* /usr/bin/distccd not starting
* Starting IIO Daemon iiod [ OK ]
Last login: Fri May 5 19:24:10 UTC 2017 on tty1
Welcome to Linaro 14.04 (GNU/Linux 4.6.0-gca4cf2a armv7l)
* Documentation: https://wiki.analog.com/ https://ez.analog.com/
New release '16.04.2 LTS' available.
Run 'do-release-upgrade' to upgrade to it.
root@analog:~#
root@analog:~# ps -ef
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 19:39 ? 00:00:03 /sbin/init
root 2 0 0 19:39 ? 00:00:00 [kthreadd]
root 3 2 0 19:39 ? 00:00:00 [ksoftirqd/0]
root 5 2 0 19:39 ? 00:00:00 [kworker/0:0H]
root 7 2 0 19:39 ? 00:00:02 [rcu_preempt]
root 8 2 0 19:39 ? 00:00:00 [rcu_sched]
root 9 2 0 19:39 ? 00:00:00 [rcu_bh]
root 10 2 0 19:39 ? 00:00:00 [migration/0]
root 11 2 0 19:39 ? 00:00:00 [cpuhp/0]
root 12 2 0 19:39 ? 00:00:00 [cpuhp/1]
root 13 2 0 19:39 ? 00:00:00 [migration/1]
root 14 2 0 19:39 ? 00:00:00 [ksoftirqd/1]
root 16 2 0 19:39 ? 00:00:00 [kworker/1:0H]
root 17 2 0 19:39 ? 00:00:00 [kdevtmpfs]
root 94 2 0 19:39 ? 00:00:01 [kworker/u4:2]
root 242 2 0 19:39 ? 00:00:00 [khungtaskd]
root 243 2 0 19:39 ? 00:00:00 [oom_reaper]
root 244 2 0 19:39 ? 00:00:00 [writeback]
root 246 2 0 19:39 ? 00:00:00 [crypto]
root 247 2 0 19:39 ? 00:00:03 [kworker/1:1]
root 248 2 0 19:39 ? 00:00:00 [bioset]
root 250 2 0 19:39 ? 00:00:00 [kblockd]
root 280 2 0 19:39 ? 00:00:00 [edac-poller]
root 292 2 0 19:39 ? 00:00:00 [watchdogd]
root 388 2 0 19:39 ? 00:00:00 [kswapd0]
root 389 2 0 19:39 ? 00:00:00 [vmstat]
root 421 2 0 19:39 ? 00:00:00 [bioset]
root 422 2 0 19:39 ? 00:00:00 [bioset]
root 423 2 0 19:39 ? 00:00:00 [bioset]
root 424 2 0 19:39 ? 00:00:00 [bioset]
root 425 2 0 19:39 ? 00:00:00 [bioset]
root 426 2 0 19:39 ? 00:00:00 [bioset]
root 427 2 0 19:39 ? 00:00:00 [bioset]
root 428 2 0 19:39 ? 00:00:00 [bioset]
root 429 2 0 19:39 ? 00:00:00 [bioset]
root 430 2 0 19:39 ? 00:00:00 [bioset]
root 431 2 0 19:39 ? 00:00:00 [bioset]
root 432 2 0 19:39 ? 00:00:00 [bioset]
root 433 2 0 19:39 ? 00:00:00 [bioset]
root 434 2 0 19:39 ? 00:00:00 [bioset]
root 435 2 0 19:39 ? 00:00:00 [bioset]
root 436 2 0 19:39 ? 00:00:00 [bioset]
root 470 2 0 19:39 ? 00:00:00 [bioset]
root 473 2 0 19:39 ? 00:00:00 [bioset]
root 476 2 0 19:39 ? 00:00:00 [bioset]
root 479 2 0 19:39 ? 00:00:00 [bioset]
root 482 2 0 19:39 ? 00:00:00 [bioset]
root 485 2 0 19:39 ? 00:00:00 [bioset]
root 488 2 0 19:39 ? 00:00:00 [bioset]
root 491 2 0 19:39 ? 00:00:00 [bioset]
root 510 2 0 19:39 ? 00:00:00 [spi32766]
root 513 2 0 19:39 ? 00:00:00 [spi32765]
root 518 2 0 19:39 ? 00:00:00 [spi32764]
root 525 2 0 19:39 ? 00:00:00 [bioset]
root 530 2 0 19:39 ? 00:00:00 [bioset]
root 535 2 0 19:39 ? 00:00:00 [bioset]
root 540 2 0 19:39 ? 00:00:00 [bioset]
root 545 2 0 19:39 ? 00:00:00 [bioset]
root 568 2 0 19:39 ? 00:00:00 [xemacps]
root 594 2 0 19:39 ? 00:00:00 [kpsmoused]
root 599 2 0 19:39 ? 00:00:00 [irq/166-4160000]
root 651 2 0 19:39 ? 00:00:00 [irq/147-mmc0]
root 746 2 0 19:39 ? 00:00:00 [kworker/0:2]
root 762 2 0 19:39 ? 00:00:00 [bioset]
root 764 2 0 19:39 ? 00:00:01 [mmcqd/0]
root 770 2 0 19:39 ? 00:00:00 [kworker/1:2]
root 838 2 0 19:39 ? 00:00:00 [deferwq]
root 869 2 0 19:39 ? 00:00:00 [kworker/u4:3]
root 876 2 0 19:39 ? 00:00:00 [kworker/1:1H]
root 877 2 0 19:39 ? 00:00:00 [jbd2/mmcblk0p2-]
root 878 2 0 19:39 ? 00:00:00 [ext4-rsv-conver]
root 879 2 0 19:39 ? 00:00:00 [kworker/0:1H]
root 962 1 0 19:39 ? 00:00:00 upstart-udev-bridge --daemon
root 971 1 0 19:39 ? 00:00:00 /lib/systemd/systemd-udevd --daemon
message+ 1369 1 0 19:39 ? 00:00:01 dbus-daemon --system --fork
syslog 1415 1 0 19:39 ? 00:00:00 rsyslogd
avahi 1443 1 0 19:39 ? 00:00:00 avahi-daemon: running [analog.local]
root 1449 1 0 19:39 ? 00:00:00 /lib/systemd/systemd-logind
avahi 1450 1443 0 19:39 ? 00:00:00 avahi-daemon: chroot helper
root 1484 1 0 19:39 ? 00:00:00 smbd -F
root 1591 1 0 19:39 ? 00:00:00 upstart-socket-bridge --daemon
root 1594 1 0 19:39 ? 00:00:00 upstart-file-bridge --daemon
root 1624 1 0 19:39 tty4 00:00:00 /sbin/getty -8 38400 tty4
root 1627 1 0 19:39 tty5 00:00:00 /sbin/getty -8 38400 tty5
root 1631 1 0 19:39 ? 00:00:00 lightdm
root 1634 1 0 19:39 tty2 00:00:00 /sbin/getty -8 38400 tty2
root 1635 1 0 19:39 tty3 00:00:00 /sbin/getty -8 38400 tty3
root 1638 1 0 19:39 tty6 00:00:00 /sbin/getty -8 38400 tty6
root 1664 1 0 19:39 ? 00:00:00 cron
root 1674 1484 0 19:39 ? 00:00:00 smbd -F
root 1677 1 0 19:39 ? 00:00:01 NetworkManager
root 1682 1 0 19:39 ? 00:00:00 /usr/sbin/sshd -D
whoopsie 1713 1 0 19:39 ? 00:00:00 whoopsie
kernoops 1724 1 0 19:39 ? 00:00:00 /usr/sbin/kerneloops
root 1729 1 0 19:39 ? 00:00:00 /usr/lib/accountsservice/accounts-daemon
root 1733 1 0 19:39 ? 00:00:00 /usr/lib/policykit-1/polkitd --no-debug
root 1767 1 0 19:39 ? 00:00:00 /usr/sbin/iiod -D
root 1787 1 0 19:39 ttyPS0 00:00:00 /bin/login -f
root 1804 1631 0 19:39 tty7 00:00:04 /usr/bin/X -core -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
root 1817 1 0 19:39 tty1 00:00:00 /bin/login -f
root 1880 1787 0 19:39 ttyPS0 00:00:00 -bash
root 1885 1631 0 19:39 ? 00:00:00 lightdm --session-child 12 15
root 1892 1817 0 19:39 tty1 00:00:00 -bash
analog 1924 1885 0 19:39 ? 00:00:00 /bin/sh /etc/xdg/xfce4/xinitrc -- /etc/X11/xinit/xserverrc
analog 1983 1 0 19:40 ? 00:00:00 dbus-launch --autolaunch=dd1dc08445adf2c0d18423ce000014ba --binary-syntax --close-stderr
analog 1984 1924 0 19:40 ? 00:00:00 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch startxfce4
analog 1987 1 0 19:40 ? 00:00:00 /usr/bin/dbus-launch --exit-with-session /usr/bin/im-launch startxfce4
analog 1988 1 0 19:40 ? 00:00:00 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
analog 1989 1 0 19:40 ? 00:00:00 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
analog 2000 1 0 19:40 ? 00:00:00 /usr/bin/ibus-daemon --daemonize --xim
analog 2019 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfsd
analog 2025 2000 0 19:40 ? 00:00:00 /usr/lib/ibus/ibus-dconf
analog 2026 2000 0 19:40 ? 00:00:01 /usr/lib/ibus/ibus-ui-gtk3
analog 2028 1 0 19:40 ? 00:00:00 /usr/lib/ibus/ibus-x11 --kill-daemon
analog 2036 1924 0 19:40 ? 00:00:00 xfce4-session
root 2037 1677 0 19:40 ? 00:00:00 /sbin/dhclient -d -sf /usr/lib/NetworkManager/nm-dhcp-client.action -pf /run/sendsigs.omit.d/network-m
analog 2039 1 0 19:40 ? 00:00:00 /usr/lib/at-spi2-core/at-spi-bus-launcher
analog 2045 2039 0 19:40 ? 00:00:00 /bin/dbus-daemon --config-file=/etc/at-spi2/accessibility.conf --nofork --print-address 3
analog 2049 1 0 19:40 ? 00:00:00 /usr/lib/at-spi2-core/at-spi2-registryd --use-gnome-session
analog 2057 1 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/xfce4/xfconf/xfconfd
analog 2062 1 0 19:40 ? 00:00:00 gnome-keyring-daemon --start
analog 2065 1 0 19:40 ? 00:00:00 xfwm4 --replace
analog 2070 1 0 19:40 ? 00:00:00 xfce4-panel
analog 2072 1 0 19:40 ? 00:00:00 Thunar --daemon
analog 2076 1 0 19:40 ? 00:00:02 xfdesktop
analog 2085 1 0 19:40 ? 00:00:04 gksudo -u root /usr/local/bin/osc
analog 2089 1 0 19:40 ? 00:00:00 xscreensaver -no-splash
analog 2091 1 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/gconf/gconfd-2
nobody 2094 1677 0 19:40 ? 00:00:00 /usr/sbin/dnsmasq --no-resolv --keep-in-foreground --no-hosts --bind-interfaces --pid-file=/run/sendsi
analog 2097 1 0 19:40 ? 00:00:00 /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
analog 2101 1 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/indicator-power/indicator-power-service
root 2115 2085 0 19:40 ? 00:00:00 /usr/bin/sudo -H -S -p GNOME_SUDO_PASS -u root -- /usr/local/bin/osc
root 2116 1 0 19:40 ? 00:00:00 /usr/lib/upower/upowerd
analog 2126 1 0 19:40 ? 00:00:01 nm-applet
root 2138 2115 0 19:40 ? 00:00:05 /usr/local/bin/osc
analog 2157 1 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/indicator-application/indicator-application-service
analog 2163 1 0 19:40 ? 00:00:00 xfce4-power-manager
analog 2168 1 0 19:40 ? 00:00:00 /usr/bin/pulseaudio --start --log-target=syslog
rtkit 2174 1 0 19:40 ? 00:00:00 /usr/lib/rtkit/rtkit-daemon
analog 2183 1 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/indicator-sound/indicator-sound-service
analog 2188 1 0 19:40 ? 00:00:00 xfce4-volumed
analog 2192 1 0 19:40 ? 00:00:00 update-notifier
analog 2215 1 0 19:40 ? 00:00:00 xfsettingsd
root 2217 2138 0 19:40 ? 00:00:00 /usr/local/bin/osc
analog 2241 2070 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/xfce4/panel/wrapper-1.0 /usr/lib/arm-linux-gnueabihf/xfce4/panel/plugins/
root 2259 1 0 19:40 ? 00:00:00 nmbd -D
analog 2271 2070 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/xfce4/panel/wrapper-1.0 /usr/lib/arm-linux-gnueabihf/xfce4/panel/plugins/
analog 2276 2070 0 19:40 ? 00:00:01 /usr/lib/arm-linux-gnueabihf/xfce4/panel/wrapper-2.0 /usr/lib/arm-linux-gnueabihf/xfce4/panel/plugins/
analog 2336 2000 0 19:40 ? 00:00:00 /usr/lib/ibus/ibus-engine-simple
analog 2379 1 0 19:40 ? 00:00:00 init --user --startup-event indicator-services-start
analog 2386 2379 0 19:40 ? 00:00:00 /usr/lib/arm-linux-gnueabihf/indicator-messages/indicator-messages-service
analog 2485 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfs-udisks2-volume-monitor
root 2488 1 0 19:40 ? 00:00:00 /usr/lib/udisks2/udisksd --no-debug
root 2498 1 0 19:40 ? 00:00:00 dbus-launch --autolaunch=dd1dc08445adf2c0d18423ce000014ba --binary-syntax --close-stderr
root 2499 1 0 19:40 ? 00:00:00 //bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
analog 2504 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfs-gphoto2-volume-monitor
analog 2508 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfs-afc-volume-monitor
analog 2514 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfs-mtp-volume-monitor
analog 2526 1 0 19:40 ? 00:00:00 /usr/lib/gvfs/gvfsd-trash --spawner :1.1 /org/gtk/gvfs/exec_spaw/0
root 2669 2 0 20:34 ? 00:00:00 [kworker/0:1]
root 2680 1880 0 20:43 ttyPS0 00:00:00 ps -ef
root@analog:~#
