AD9958 No Signal
Question asked by Chrispy on May 4, 2017
Latest reply on May 23, 2017 by Chrispy
i want to generate a Sine Wave with AD9958 but receive no output.
The Chip is connected like the Chip on the Evaluation Board, except that i only use the SPi Pins.
SDIO_0 and SDIO_2 are accessable while SDIO_1 and SDIO_0 are pulled to ground.
CS is connected to Ground because i only use one DDS.
The used Code is attached and the few commands i changed are highlighted.
I also attached my schematic, but i stayed as close to the evaluation board as possible for my application so i doubt that there are problems but maybe im wrong.
How can i check if the Chip got damaged while soldering? Is there a possible way to check this?
The Chip seems to trigger the Crystal correctly but as mentioned before i don't see any output.
Thanks for your help
Chris
