Unable to connect FMCOMMS1 in gnuradio OOT module
Question asked by daxez12 on May 2, 2017
Latest reply on May 3, 2017 by daxez12
I've created a OOT in gnuradio to make a simple remote transmission from the FMCOMMS1. First I tried to use it without linking libiio from the cmake files so the result was this error:
Traceback (most recent call last):
  File "/gr-fmcomms1/top_block.py", line 164, in <module>
    main()
  File "/gr-fmcomms1/top_block.py", line 152, in main
    tb = top_block_cls(uri=options.uri)
  File "/gr-fmcomms1/top_block.py", line 92, in __init__
    self.fmcomms1_fmcomms1_source_1 = fmcomms1.fmcomms1_source('10.1.135.139')
AttributeError: 'module' object has no attribute 'fmcomms1_source'
Researching I've discovered that it is a problem related to libiio, which is not being found and gnuradio can't create the module so I found that I needed to create a cmake file to search for libiio and link it to the OOT module.
Following those instructions and based on gr-iio module cmake files I finished with a cmake file like this:
INCLUDE(FindPkgConfig)
PKG_CHECK_MODULES(PC_IIO QUIET gnuradio-core)
FIND_PATH(ITPP_INCLUDE_DIRS
   NAMES iio/api.h
   HINTS $ENV{IIO_DIR}/include
      ${PC_IIO_INCLUDE_DIR}
   PATHS ${CMAKE_INSTALL_PREFIX}/include
         /usr/local/include
         /usr/include
FIND_LIBRARY(
   IIO_LIBRARIES
   NAMES gnuradio-iio
   HINTS $ENV{ITPP_DIR}/lib
      ${PC_IIO_LIBDIR}
   PATHS ${CMAKE_INSTALL_PREFIX}/lib
         /usr/local/lib
         /usr/lib
         /usr/
lib64
FIND_PACKAGE_HANDLE_STANDARD_ARGS(IIO DEFAULT_MSG IIO_LIBRARIES IIO_INCLUDE_DIRS)
MARK_AS_ADVANCED(IIO_LIBRARIES IIO_INCLUDE_DIRS)
And in CMakeLists.txt in the root directory of the OOT Module:
Line 104:
# Find gnuradio build dependencies
find_package(CppUnit)
find_package(Doxygen)
# Search for GNU Radio and its components and versions. Add any
# components required to the list of GR_REQUIRED_COMPONENTS (in all
# caps such as FILTER or FFT) and change the version to the minimum
# API compatible version required.
set(GR_REQUIRED_COMPONENTS RUNTIME)
find_package(Gnuradio "3.7.2" REQUIRED)
find_library(IIO_LIBRARIES iio)
find_path(IIO_INCLUDE_DIRS iio.h)
if(NOT CPPUNIT_FOUND)
   message(FATAL_ERROR "CppUnit required to compile fmcomms1")
endif()
if(NOT IIO_FOUND)
   message(FATAL_ERROR "IIO required to compile fmcomms1")
endif()
Line 132:
# Setup the include and linker paths
if(NOT IIO_FOUND)
endif()
include_directories(
   ${CMAKE_SOURCE_DIR}/lib
   ${CMAKE_SOURCE_DIR}/include
   ${CMAKE_BINARY_DIR}/lib
   ${CMAKE_BINARY_DIR}/include
   ${Boost_INCLUDE_DIRS}
   ${CPPUNIT_INCLUDE_DIRS}
   ${IIO_INCLUDE_DIRS}
   ${GNURADIO_ALL_INCLUDE_DIRS}
link_directories(
   ${Boost_LIBRARY_DIRS}
   ${CPPUNIT_LIBRARY_DIRS}
   ${IIO_LIBRARY_DIRS}
   ${GNURADIO_RUNTIME_LIBRARY_DIRS}
And then I tried to make the cmake command from the build directory and the result was:
It's worth to say that when I run the locate command for iio/api.h the result is:
And locate for gnuradio-iio is:
Honestly I think it's fine, but I'm new to the cmake files and linking with gnuradio. So maybe there's something I did it wrong, thanks.
