No outputs from ADV7611
Question asked by Blomman on Sep 30, 2011
Latest reply on Apr 10, 2012 by andreastan
I have big problems to get the ADV7611 circuit to run correct.
We are usin 3 ADV7611 circuits to interface 3 different video sources.
The ADV7611 we are using is without HDCP.
I have confirmed that the device givs ack for each config. command I send.
I'm using a 28.6363 MHz X-tal. The default register settings is 28.6363 MHz so i suppose I don't tp write to that register?
Clock termination is enabled and disable of Tristate pins is enabled.(= The Tx source is transmitting).
I have the LLC clock output running(=Tx source Pixelclock) but there is NO pixel data or sync signals(HS,VS,DE)on the output!
When I set the register in FreeRun (and have no input source) I get sync signals on output so it looks like the HW is allright.
My register settings are:
                                                  Map addresses
                                                  98 F4 80 ; CEC
                                                  98 F5 7C ; INFOFRAME
                                                  98 F8 4C ; DPLL
                                                  98 F9 64 ; KSV
                                                  98 FA 6C ; EDID
                                                  98 FB 68 ; HDMI
                                                  98 FD 44 ; CP
                                                 Register Settings
                                   98 00 05 ; Video input standard 1280x1024@60Hz
                                   98 01 06 ; Prim_Mode =110b HDMI-GR
                                   98 02 F7 ; Auto CSC, RGB out
                                   98 03 40 ; 24 bit SDR 444 Mode 0
                                   98 05 28 ; AV Codes Off
                                   98 0B 44 ; Power up part
                                   98 0C 42 ; Power up part
                                   98 14 7F ; Max Drive Strength
                                   98 15 80 ; Disable Tristate of Pins
                                   44 BA 00 ; Set HDMI NOT FreeRun
                                   68 9B 03 ; ADI recommended setting
                                   68 C1 01 ; ADI recommended setting
                                   68 C2 01 ; ADI recommended setting
                                   68 C3 01 ; ADI recommended setting
                                   68 C4 01 ; ADI recommended setting
                                   68 C5 01 ; ADI recommended setting
                                   68 C6 01 ; ADI recommended setting
                                   68 C7 01 ; ADI recommended setting
                                   68 C8 01 ; ADI recommended setting
                                   68 C9 01 ; ADI recommended setting
                                   68 CA 01 ; ADI recommended setting
                                   68 CB 01 ; ADI recommended setting
                                   68 CC 01 ; ADI recommended setting
                                   68 00 00 ; Set HDMI Input Port A
                                   68 83 FE ; Enable clock terminator for port A
                                   68 6F 0C ; ADI recommended setting
                                   68 85 1F ; ADI recommended setting
                                   68 87 70 ; ADI recommended setting
                                   68 57 DA ; ADI recommended setting
                                   68 58 01 ; ADI recommended setting
All other register settings are kept default. Have I missed something? Is the order of setting up the registers important?
This is VERY,VERY URGENT. We have a dead-line TODAY, so PLEASE someone!!!
Best Regards
Kenneth
KENNETH BLOOM
Electronic Design Engineer
LVI LOW VISION INTERNATIONAL
VERKSTADSG. 5, 352 46 VÄXJÖ, SWEDEN
PHONE: +46 (0)470 72 77 15
WWW.LVI.SE
