Biasing Sequence for GaAs HMC952ALP5GE
Question asked by mobalasmeh on Mar 27, 2017
Latest reply on May 29, 2017 by kkaya
I am trying to design a biasing sequencer which is mentioned in the attached PDF to make sure that it will work with HMC952ALP5GE. However the results that were included in the document shows that the drain voltage will take time to settle down, which will make the drain have positive voltage when the negative voltage source is off. I believe this will not produce the correct sequence. can anyone clarify in this regard.
Thanks
