Problems with project in technical note EE-268 (Programming Asynchronous Sample Rate Converters on ADSP-2136x) on ADSP-21369.
Question asked by pol on Sep 27, 2011
Latest reply on Oct 27, 2011 by Mitesh
I started project “SRC SPORT0 to SPORT1” on ADSP-21369 (dspblok™ 21369zx). I have changed code for porting on ADSP21369 only by including files. But I have got output values in the negative and added ‘DTYPE1 bit’ in Sport1Init (). There are noises in output signal like this:
View output plot (FsOUT = FsIN)
I have no idea about it. Where is the mistake? Code listing below:
View code in main():
/Function Definitions --------------------------------------------------------------
//Initialize SRC0
void SRC0Init()
            *pSRCCTL0 = SRC0_SMODEIN0 | SRC0_SMODEOUT0 | SRC0_ENABLE ;
//Initialize SPORT0
void Sport0Init()
            *pDIV0 = 0x0018000e;
            *pSPCTL0 |= SPEN_A | SLEN24 | MSTR | OPMODE | SPTRAN;//SPORT0 configuration:
        //Internal clock and word select
        //I2S mode
        //Transmitter
        //Word length 24
//Initialize SPORT1
void Sport1Init()
            *pDIV1 = 0x0018000e;
            *pSPCTL1 |= SPEN_A | MSTR | SLEN24 | OPMODE | DTYPE1;             //SPORT1 configuration:
        //I2S mode
        //Receiver
        //Word length 24
View code in SPORT_0_1 and SRC0.c
// This function will setup the SRU Registers
void InitSRU()
            // Enable pull-up resistors on unused DAI pins
            * (volatile int *)DAI_PIN_PULLUP = 0xfffff;
            //Generating Code for connecting : SPORT0_CLK to SRC0_CLK_IP
            SRU (SPORT0_CLK_O, SRC0_CLK_IP_I);
            //Generating Code for connecting : SPORT0_FS to SRC0_FS_IP
            SRU (SPORT0_FS_O, SRC0_FS_IP_I);
            //Generating Code for connecting : SPORT0_DA to SRC0_DAT_IP
            SRU (SPORT0_DA_O, SRC0_DAT_IP_I);
            //Generating Code for connecting : SPORT1_CLK to SRC0_CLK_OP
            SRU (SPORT1_CLK_O, SRC0_CLK_OP_I);
            //Generating Code for connecting : SPORT1_FS to SRC0_FS_OP
            SRU (SPORT1_FS_O, SRC0_FS_OP_I);
            //Generating Code for connecting : SRC0_DAT_OP to SPORT1_DA
            SRU (SRC0_DAT_OP_O, SPORT1_DA_I);
Excuse me for my bad English.
