How to get W/LSB  from A/LSB and V/LSB ?
Question asked by Nouredine on Mar 28, 2017
Latest reply on Mar 28, 2017 by Nouredine
I want to do the AD7878a  calibration only with an accurate source.
1-  So my first question is what do you mean by "accurate source" ? and please can you give me an example that I can use.
2-  what is the meaning of LSBs and LSB ? because I'm confused !! sometimes I find LSBs in your formula. and sometimes I find LSB. so I want please to understand the difference in your formula. (it's perfect way that you give me an example with AIRMS or AVRMS).
3- what is the true meaning of this W/LSB constant ? ( Watt for each bit  or what !!!)    and how can I get W/LSB from V/LSB and A/LSB ?
4- I try to understand how can i use those two methods : instantaneous active energy calculation  and line cycle active energy calculation ?
please give me an example for each method and how to use it to get energy true value ?
5-  In my application, I want to use the line cycle active energy calculation, because I see in your forum that it's more recommended. so if it's possible to give in details, what are the steps that I should follow to use this method ?
thanks in advance for your feedback.
Nour
