the input singal is 1080i@60Hz、1080i@50Hz RGBS(SOG),ADV7181D Gray scale appears high gray-scale saturation.
Question asked by mhqyz on Mar 23, 2017
Latest reply on Apr 7, 2017 by JeyasudhaMuthuPerumal
But the input singal is 720P@60Hz、720P@50Hz、1080i@60Hz、1080i@50Hz RGBS(SOG),Gray scale appears high gray-scale saturation.
normal screen:
but now screen:
the scripts of 1080i@60Hz:
ADV7181D_WriteByte(0x05, 0x01);//PRIM_MODE = 001b COMP
ADV7181D_WriteByte(0x06, 0x0C);//VID_STD for 1080i
ADV7181D_WriteByte(0xC3, 0x31);//ADC1 to Ain5 (R), ADC0 to Ain2 (G),
ADV7181D_WriteByte(0xC4, 0xF2);//ADC2 to Ain3 (B), enables manual override of mux, use SOG
ADV7181D_WriteByte(0x1D, 0x47);//Enable 28MHz Crystal
ADV7181D_WriteByte(0x3A, 0x21);//set latch clock settings to 010b, Power Down ADC3
ADV7181D_WriteByte(0x3B, 0x81);//Enable internal Bias
ADV7181D_WriteByte(0x3C, 0x5D);//PLL_QPUMP to 101b
ADV7181D_WriteByte(0x52, 0x00);//Color Space Conversion from RGB->YCrCb
ADV7181D_WriteByte(0x53, 0x00);//CSC
ADV7181D_WriteByte(0x54, 0x12);//CSC
ADV7181D_WriteByte(0x55, 0x90);//CSC
ADV7181D_WriteByte(0x56, 0x38);//CSC
ADV7181D_WriteByte(0x57, 0x69);//CSC
ADV7181D_WriteByte(0x58, 0x48);//CSC
ADV7181D_WriteByte(0x59, 0x08);//CSC
ADV7181D_WriteByte(0x5A, 0x00);//CSC
ADV7181D_WriteByte(0x5B, 0x75);//CSC
ADV7181D_WriteByte(0x5C, 0x21);//CSC
ADV7181D_WriteByte(0x5D, 0x00);//CSC
ADV7181D_WriteByte(0x5E, 0x1A);//CSC
ADV7181D_WriteByte(0x5F, 0xB8);//CSC
ADV7181D_WriteByte(0x60, 0x08);//CSC
ADV7181D_WriteByte(0x61, 0x00);//CSC
ADV7181D_WriteByte(0x62, 0x20);//CSC
ADV7181D_WriteByte(0x63, 0x03);//CSC
ADV7181D_WriteByte(0x64, 0xD7);//CSC
ADV7181D_WriteByte(0x65, 0x19);//CSC
ADV7181D_WriteByte(0x66, 0x48);//CSC
ADV7181D_WriteByte(0x67, 0x13);//CSC last
ADV7181D_WriteByte(0x6B, 0x81);//20 Bit 422
ADV7181D_WriteByte(0xC9, 0x00);//SDR
ADV7181D_WriteByte(0x73, 0xCF);//Enable Manual Gain and set CH_A gain
ADV7181D_WriteByte(0x74, 0xA3);//Set CH_A and CH_B Gain - 0FAh
ADV7181D_WriteByte(0x75, 0xE8);//Set CH_B and CH_C Gain
ADV7181D_WriteByte(0x76, 0xFA);//Set CH_C Gain
ADV7181D_WriteByte(0x7B, 0x15);//Turn off EAV and SAV Codes. Set BLANK_RGB_SEL. disable the blanking
ADV7181D_WriteByte(0x7C, 0x10);//set HS position & polarity
ADV7181D_WriteByte(0x85, 0x19);//Turn off SSPD and force SOG
ADV7181D_WriteByte(0x86, 0x0B);//Enable stdi_line_count_mode
ADV7181D_WriteByte(0xBF, 0x06);//Blue Screen Free Run Colour
ADV7181D_WriteByte(0xC0, 0x40);//Default color
ADV7181D_WriteByte(0xC1, 0x80);//Default color
ADV7181D_WriteByte(0xC2, 0xF0);//Default color
ADV7181D_WriteByte(0xC5, 0x01);//CP_CLAMP_AVG_FACTOR[1-0] = 00b
ADV7181D_WriteByte(0xF4, 0x3F);//Max Drive Strength
ADV7181D_WriteByte(0x0E, 0x80);//ADI Recommended Setting
ADV7181D_WriteByte(0x52, 0x46);//ADI Recommended Setting
ADV7181D_WriteByte(0x54, 0x80);//ADI Recommended Setting
ADV7181D_WriteByte(0x57, 0x01);//ADI Recommended Setting
ADV7181D_WriteByte(0xF6, 0x3B);//ADI Recommended Setting
ADV7181D_WriteByte(0x0E, 0x00);//ADI Recommended Setting
the scripts of 1080i@50Hz:
ADV7181D_WriteByte(0x7C, 0x1C);//set HS position & polarity
ADV7181D_WriteByte(0x7E, 0xD8);//set HS position
ADV7181D_WriteByte(0x87, 0xEA);//Reprogram pll_div_ratio for 1080i/50Hz = 2640
ADV7181D_WriteByte(0x88, 0x50);//
ADV7181D_WriteByte(0x8F, 0x03);//Reprogram freerun_line_length also to 1018 for 28.636MHz xtal
ADV7181D_WriteByte(0x90, 0xFA);//
I hope that your company's experts can analyze the problem.
Thanks.
