Timing SAV EAV H:V:F vs. CEA-861
Question asked by S.Griebsch on Mar 22, 2017
Latest reply on Apr 6, 2017 by S.Griebsch
I was wondering what is the main difference between the timing H:V:F and CEA-861 considering the SAV and EAV data.
Analyzing the sync signals from both I can see, that the timing they appear are just the same.
My test setup was, an eval board with a SDI deserializer that outputs H:V:F and the eval adv7612-7511P with CEA-861.
What I could see, is that the pulse width from for example HSYNC and VSYNC ain't the same to HS and VS.
Can someone explain why I get these results?
The background is as follow. I have an encoder that works fine with H:V:F timing signals. Now I want to use an HDMI receiver instead of an SDI deserializer as video input. The ADV7611 does only output CEA-861. The encoder does handle the incoming video from the ADV, but there is a horizontal and vertical offset. My guess is, that there is a problem with the line blanking.
Thanks for support.
