(leanXcam) BF537 uClinux Error
Question asked by skallabrak on Mar 17, 2017
Latest reply on Apr 11, 2017 by Aaronwu
I have a leanXcam(home · scs/leanXcam Wiki · GitHub , SyslogicSystronics AG  ) with a BF537. I had some leanXcams made and I'm currently in the process of trying to load the bootloader and uClinux in to flash.
I'm no expert and hardly have experience doing this type of thing, so bare with me.
I've successfully managed to load the bootloader into RAM as per https://github.com/scs/leanXcam/wiki/Users-Guide-Using-uClinux#Reload_bootloader_onto_camera and https://docs.blackfin.uclinux.org/doku.php?id=bootloaders:u-boot:loading#wiki-boot_via_the_uart_Bootloaders_U-Boot_loading
Once I've loaded the bootloader in to RAM, and then write it in to flash, I then proceed to load and boot uClinux, and that's where I encounter some issues.
Here's what I see when I boot uClinux, I hope you can point me in the right direction based on this, if not, let me know what else I can include to give you a better idea of what's going on:
## Booting image at 10028000 ...
Image Name: Linux Kernel and ext2
Image Type: Blackfin Linux Kernel Image (gzip compressed)
Data Size: 2915027 Bytes = 2.8 MB
Load Address: 00001000
Entry Point: 001ef28c
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Starting Kernel at = 1ef28c
Linux version 2.6.28.10-ADI-2009R1.1-Git_v2.1 (oscar@oscar) (gcc version 4.1.2 (ADI svn)) #2 PREEMPT Wed Sep 29 08:51:22 CEST 2010
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
fixedcode = 0x00000400-0x00000490
text = 0x00001000-0x00159930
rodata = 0x00159930-0x001bf5b0
bss = 0x001c0000-0x001d36e0
data = 0x001d36e0-0x001e8000
stack = 0x001e6000-0x001e8000
init = 0x001e8000-0x00201000
available = 0x00201000-0x03600000
rootfs = 0x03600000-0x03e00000
DMA Zone = 0x03e00000-0x04000000
Hardware Trace Active and Enabled
Boot Mode: 7
Blackfin support (C) 2004-2009 Analog Devices, Inc.
Compiled for ADSP-BF537 Rev 0.3
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 500 MHz core clock and 125 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
Data Cache Enabled for CPU0 (write-back)
Built 1 zonelists in Zone order, mobility grouping off. Total pages: 13716
Kernel command line: root=/dev/mtdblock0 rw console=ttyBF0,115200
Preemptible RCU implementation.
Configuring Blackfin Priority Driven Interrupts
PID hash table entries: 256 (order: 8, 1024 bytes)
console [ttyBF0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 52676k/65536k RAM, (100k init code, 1378k kernel code, 570k data, 2048k dma, 572k reserved)
Calibrating delay loop... 997.37 BogoMIPS (lpj=1994752)
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (36 KB free)
net_namespace: 288 bytes
NET: Registered protocol family 16
Blackfin DMA Controller
stamp_init(): registering device resources
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler cfq registered
bfin-dma: initialized
timer_latency module loaded
simple-gpio: now handling 48 GPIOs: 0 - 47
Serial: Blackfin serial driver
bfin-uart.1: ttyBF0 at MMIO 0xffc00400 (irq = 18) is a BFIN-UART
brd: module loaded
bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1, mdc_clk=2500000Hz(mdc_div=24)@sclk=125MHz)
bfin_mac bfin_mac.0: Blackfin on-chip Ethernet MAC driver, Version 1.1
Linux video capture interface: v2.00
mt9v032_oscar_init: MT9V032 CMOS-Sensor: Micron I2C driver ready
uclinux[mtd]: RAM probe address=0x3600000 size=0x800000
Creating 1 MTD partitions on "RAM":
0x00000000-0x00800000 : "ROMfs"
Generic platform RAM MTD, (c) 2004 Simtec Electronics
mtd_dataflash spi0.1: AT45DB321x (4224 KBytes) pagesize 528 bytes (OTP)
Creating 4 MTD partitions on "Boot Flash":
0x00000000-0x00020000 : "bootloader, 128k"
mtd: partition "bootloader, 128k" doesn't end on an erase block -- force read-only
0x00020000-0x00024000 : "bootloader environment, 16k"
mtd: partition "bootloader environment, 16k" doesn't start on an erase block boundary -- force read-only
0x00024000-0x00028000 : "bootloader environment redundant, 16k"
mtd: partition "bootloader environment redundant, 16k" doesn't start on an erase block boundary -- force read-only
0x00028000-0x00400000 : "linux, 4M"
mtd: partition "linux, 4M" doesn't start on an erase block boundary -- force read-only
mtd_dataflash spi0.5: AT45DB321x (4224 KBytes) pagesize 528 bytes (OTP)
Creating 1 MTD partitions on "Application Flash":
0x00000000-0x00400000 : "JFFS2 Application Partition"
mtd: partition "JFFS2 Application Partition" doesn't end on an erase block -- force read-only
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_base@ffc00500, dma channel@7
i2c /dev entries driver
mt9v032_oscar_detect_client: MT9V032 CMOS-Sensor: detecting client on address 0xb8
mt9v032_oscar_init_v4l: MT9V032 CMOS-Sensor: V4L driver Micron CMOS Camera: MT9V032 now ready
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc01400
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
mmc_spi spi0.2: ASSUMING 3.2-3.4 V slot power
mmc_spi spi0.2: SD/MMC host mmc0, no DMA, no WP, no poweroff
mmc_spi spi0.2: requested mode not fully supported
mmc_spi spi0.2: can't change chip-select polarity
TCP cubic registered
VFS: Mounted root (ext2 filesystem).
Freeing unused kernel memory: 100k freed
dma_alloc_init: dma_page @ 0x001fd000 - 512 pages at 0x03e00000
Mounting Application Flash...
jffs2: Flash size not aligned to erasesize, reducing to 4095KiB
JFFS2 flash size adjusted to 4190208KiB
JFFS2 write-buffering enabled buffer (528) erasesize (8448)
Loading Memory DMA kernel module...
bfmdma driver module set up OK
bfin_request_exception (13, ex_dmach1) = 0
bfmdma module init ex_dmach1: 035804c8
Replacing /root with a symlink pointing to /mnt/app.
Waiting for carrier on eth0: 15 s
PHY: 0:01 - Link is Up - 100/Full
jffs2_flush_wbuf(): Write failed with -30
Welcome to: __ __
_ \ \ / /
| | ___ ___ _ __\ \ / /____ ___ _ __ __
| |/ _ \ /_ | / \\ \/ // __ \ /_ | / \/ \
| | |_| |__| | /| |\ /| / \/ __| | /| /| |
| | ___// _ | | | |/ \| | / _ | | | | | |
| | \_/| |_| | | | / /\ \ \__/| |_| | | | | | |
|_|\___/\____|_| |/ / \ \____/\____|_| |_| |_|
/_/ \_\
running on uClinux.
For further information see:
http://www.leanxcam.org/
No or faulty 'syslog_file', using /var/log/log to log
BusyBox v1.13.4 (2010-09-29 08:56:05 CEST) built-in shell (msh)
Enter 'help' for a list of built-in commands.
root:/> Erase at 0x003f8d00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003fae00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003f4b00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003f6c00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003f0900 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003f2a00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003ec700 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003ee800 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003e8500 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003ea600 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003e4300 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003e6400 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003e0100 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003e2200 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003dbf00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003de000 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003d7d00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003d9e00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003d3b00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003d5c00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003cf900 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003d1a00 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003cb700 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003cd800 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003c7500 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003c9600 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003c3300 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003c5400 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003bf100 failed immediately: -EROFS. Is the sector locked?
Erase at 0x003c1200 failed immediately: -EROFS. Is the sector locked?
