AD9578 problem
Question asked by cosmolittle on Mar 17, 2017
Latest reply on Apr 4, 2017 by cosmolittle
Dear Steve,
I now have a lot of experience with the AD9578, however I have a programming problem:
The device sometimes fails to lock properly ( unstable frequency a few kHz low) after repeating a programming sequence with the same values. The sequence I use  is:
1/- toggle MR bit
2/- program all registers
3/- read and print all registers
The device is now locked and outputting the correct frequency
Now repeat the above sequence with exactly the same register values
The device is now in the unstable lock mode
The read back of the registers gives identical values.
Repeating the sequence always gives an incorrect lock.
This problem occurs both in rational and fractional modes.
After the master reset, should the device be in exactly the same default  state?
Note that programming after a power on reset gives a correct lock. Also programming a completely new frequency sometimes resets the stuck mode.
best regards
Cosmo Little
