DAQ2: how to change JESD lane rate
Question asked by Chris449 on Mar 17, 2017
Latest reply on Mar 22, 2017 by Chris449
I made a pcb using a similar setup of daq2 except that I replace AD9144 by AD9136 and AD9680-1000 by AD9680-500.
On the FPGA, I am using your reference design (hdl_2015_r2).
Since the configuration is the same, I can make the DAC to work.
However, for the ADC, since I am using the AD9680-500, I need to change the lane rate compare to your DAQ2.
Here is teh configuration I would like to run:
- DAC_CLK=ADC_CLK=491.52MHz instead of 1GHz
- FMC_DAC_CLK=FMC_ADC_CLK=DAC_CLK/2
- M=2, L=4
It means that the lane rate will not be around 10Gbps anymore but 5Gbps. For the AD9523, I know how to set it up.
Please could you tell me what I have to change in the fpga reference design?
I tried to follow these to threads but was kind of lost.
https://ez.analog.com/message/265076?q=daq2%20lane%20rate
How do you reduce the effective sampling rate of the DAQ2 noOS project for the KCU105 with analog JESD204B?
Thanks a lot.
Best,
Chris
