ADuC7060 _ADC4 output noise ?
Question asked by Terumasa on Mar 14, 2017
Latest reply on May 4, 2017 by barryzhang
Hello
Please let me know your advice about ADC4 output of ADuC7060.
Our customer uses EVAL-ADuC7060 at below condition.
Problem
Primary channel and Auxiliary channel is measured  alternately.
Output data of Primary channel is OK  ,
but the data of Auxiliary channel is periodically swing about  12274000LSB +- 1000LSB.
When auxiliary channel only is measured ,   ( primary channel is disabled)
above problem is not appeared  and result is about 12274000 LSB +- 100LSB
Question
Is there any limitation of using both primary channel and auxiliary channel ?
If you need measurement data , please let me know your e-mail address because it is cutomer's data.
Measurement sequence
Measured channel is below sequence.
ADC0:1 - > ADC4 - > ADC2-> ADC4 -> ADC3  -> ADC4   - >  ADC0:1  ....
Channel settings
ADC0:1  = RTD
ADC2 and ADC3 : another sensor output voltage
ADC4:   0.88V from reference  voltage generator
ADC5 is connected to AGND.
Board switch setting
dipswS4-1~S4-4:on
Other switch: Open
Register settings of both channel measurement
ADCMDE = 0x81;
ADCMSKI = 0x03;
ADC0CON
ADC0-1: 0x8414
ADC2:   0x8580
ADC3:   0x85C0
ADC1CON
ADC4:   0x8B00
ADCFLT = 0xC0FF;
ADCCFG = 0x0000;
IEXCON = 0x42;
Register settings of auxiliary channel  only measurement
Below change from above settings
ADCMSKI = 0x02;
ADC0CON = 0x0000
Please let me know your advice.
Best Regards,
Terumasa
