Sample rate AD9361
Question asked by Selwyn on Mar 11, 2017
Latest reply on Mar 20, 2017 by Selwyn
I am working on PicoZed SDR zq7035. I am trying to set the sample rate to my desired rate. the default setting is:
/* BBPLL ADC R2CLK R1CLK CLKRF RSAMPL */
{983040000, 245760000, 122880000, 61440000, 30720000, 30720000},//rx_path_clock_frequencies[6]
/* BBPLL DAC T2CLK T1CLK CLKTF TSAMPL */
{983040000, 122880000, 122880000, 61440000, 30720000, 30720000},//tx_path_clock_frequencies[6]
My desired sample rate I want 30MSPS so I try set it to:
{960000000, 30000000, 30000000, 30000000, 30000000, 30000000},//rx_path_clock_frequencies[6]
{960000000, 30000000, 30000000, 30000000, 30000000, 30000000},//tx_path_clock_frequencies[6]
The console send out a failure error. Is it because I have to set a certain set of BBPLL freq and work out the rest of the sample rate via calculation based on the divider as well as the filter factor? The reason why I set 30Mhz the same for the last 5 is because I want to bypass the digital filter. Is my method of bypassing the filters done correctly?
I am using the bare-metal method.
regards
Selwyn
