AD80066 clocks
Question asked by pixelPhile on Mar 9, 2017
Latest reply on May 5, 2017 by pixelPhile
I'd like to use the AD80066 to digitise the outputs of 4 CCD channels whose maximum clock rate is 1MHz (each).  In many ways the part is perfect if it can run that slowly (ADCLK @ 4MHz).  The datasheet does not indicate any minimum frequency or maximum period, but there are suggestions elsewhere on EZ that there is a minimum frequency that should be observed.  If so, what is it?
If the 80066 is not suitable, can you suggest a part that would be?
I'd really appreciate a definitive answer from an AD staff member!
