Inlined method not optimized ideally
Question asked by Haje on Mar 7, 2017
Latest reply on Apr 18, 2017 by kennie
Hi
I have a large method that I would like to break up into smaller methods for reuse. Unfortunately, the resulting code is less efficient (code size).
Basically, the methods are range checks of process values. If a value is out of range, the method shall return with an appropriate code. If I use methods, I add a comparison (if) but I would expect the compiler to be able to merge those comparisons into one but looking at the assembly, it does not.
Here is a condensed example:
// All in one method
int Checks() {
   if (a > b)
      return 1;
   if (c > d)
      return 2;
   ... more checks
   return 0;   // everything ok
// Checks extracted into small methods
inline int CheckAB()
   if (a > b)
      return 1;
   return 0;
int Checks() {
   int returnCode = CheckAB();
   if (returnCode != 0) return returnCode;
   returnCode = CheckCD();
   ... more checks
I attached an example project. It gives following assembly output:
Disassembly with one large method:
    r2=dm(_testVal);
    r1=0x40e00000;
    comp(f1,f2), r0=m5;
    if lt r0=m6;
    r2=pass r0;
Disassembly with inlined method:
    r2=dm(_testVal);
    r1=0x40e00000;
    comp(f1,f2), r0=m5;
    if lt r0=m6;
    r2=pass r0;
    if eq jump (pc, 0x4);
Does anyone know why? Is there a better way to write this code or a compiler setting that would give the same results as when writing one large method?
I'm using VisualDSP++ 5.1.0.0, Target is SHARC 21371.
I appreciate any input.
Thanks!
hans
