moreseg
IAR CRC configuration
Discussion created by moreseg Employee on Mar 5, 2017
In order to configure properly the CRC on ADuCM4050 within the IAR IDE it is necessary to modify following configurations under the Linker section.
  • Checksum tab (see figure)
  • Linker Checksum tab
    • Fill unused code memory must be checked
    • Fill pattern end address must be 0x7fb
    • "Generate checksum" must be checked
    • Checksum size: 4 bytes
    • Alignment:4
    • Algorithm: CRC32
    • Initial value = 0xFFFFFFFF
    • Use as input must be unchecked
    • Check sum unit size: 32-bit
  • Extra Options tab
    • Use command line options must be checked
    • Add “--keep __checksum"
