moreseg
GPIO default status
Discussion created by moreseg Employee on Mar 5, 2017
By default GPIOs are configured as floating (neither input nor output).
 There is no priority between IE and OE registers. This is, if you configure both as enabled, then the input path as well as the output path will be enabled. It is user responsibility to configure pads as required by the application.
