Master Control Port Interface read/write i2c
Question asked by op-electronics on Mar 2, 2017
Latest reply on Mar 28, 2017 by op-electronics
i'm using a Microchip 24aa1025 i2c eeprom, i can selfboot programs from it without a problem but i'm having troubles to read/write from master control port interface.
Eeprom datasheet says that:
This device has an internal addressing boundary limitation that is divided into two segments of 512K bits. Block select bit ‘B0’ to control access to each segment.
Read=1
Write=0
Since adau1452 can only selfboot with address 0x50
When i write to eeprom through interface write with address 0x50 the dsp doesn't selfboot on next power-up. I know that adau1452 selfboot happens only at 0x50 so i can't hard set A0 and A1 bits to different values. The other usable address for interface write should be 0x54 (B0=1 which would write to the second 512Kb memory block) but despite the adau1452 selfboots correctly nothing is read from interface read.
I just want to selfboot a program and write/read from interface register from same eeprom.
What do you think? Should i change eeprom type? Did you test the i2c master interface with any particular device?
Thank you for your support
Omar
