Print profiling informations
Question asked by ChristianH on Sep 22, 2011
Latest reply on Sep 23, 2011 by CraigG
I've used the Linear Profiling for my project with the SHARC ADSP-214xx simulator.
After running my program I can see the cycle counts for the different code lines.
I was searching for a way to print that result but it seems that simply use the Print instruction in the File menu does not work. Also a right-click on the table does not give me an option to print it.
If I save the result (Save profile...) as .txt or .xml I do not get a file that contains the same informations as the result window i.e. cylce count in the left column AND the instruction in the right column.
Is there another way to print it out?
Thanks
Christian
