AD9361 UHF Tx/Rx matching
Question asked by rojizor on Feb 21, 2017
Latest reply on Feb 21, 2017 by Vinod
Hello.
I am designing a UHF transceiver. I took the FMComms2 design as reference. Designing the reception chain, reading the UG-570, it said that reception impedance is around 200ohm for 435MHz. The balun for that band (HHM1591D1 - 350-470 MHz) recommended by Analog Devices is 50/100. I found a "bother" of the recommended balun that is perfect for that impendace, 50/200 (HHM1589E1 - 350-470MHz also). Which one should i use?
For transmission, UG-570 said that input impedance is always 50ohm. I couldn't find a balun with that impedance, then i understand that the recommended i probably the better one for that. Is this correct?
Thank you.
