ad9361 more than two ip
Question asked by hammerclavier on Feb 20, 2017
Latest reply on Feb 22, 2017 by hammerclavier
I am trying to add 3 axi_ad9361 ip to my Picozed SDR SOM board and so far has been able to do only 2 based on FMCOMMS5 devicetree design, but not 3.
I made sure that hardware is ok as well as PL side to connect the SPI channels. Is there anything on the Linux Kernel rather than devicetree to be modified?
here is a snippet of my device tree:   -------> ad9361-phy-C@2
spi@e0007000 {
compatible = "xlnx,zynq-spi-r1p6";
reg = <0xe0007000 0x1000>;
status = "okay";
interrupt-parent = <0x1>;@@@@@
interrupts = <0x0 0x31 0x4>;
clocks = <0x2 0x1a 0x2 0x23>;
clock-names = "ref_clk", "pclk";
#address-cells = <0x1>;
#size-cells = <0x0>;
ad9361-phy@0 {
#clock-cells = <0x1>;
compatible = "ad9361-2x";
reg = <0x0>;
spi-cpha;
spi-max-frequency = <0x989680>;
clocks = <0x5 0x0>;
clock-names = "ad9361_ext_refclk";
clock-output-names = "rx_sampl_clk", "tx_sampl_clk";
adi,digital-interface-tune-skip-mode = <0x0>;
adi,pp-tx-swap-enable;
adi,pp-rx-swap-enable;
adi,rx-frame-pulse-mode-enable;
adi,lvds-mode-enable;
adi,lvds-bias-mV = <0x96>;
adi,lvds-rx-onchip-termination-enable;
adi,rx-data-delay = <0x4>;
adi,tx-fb-clock-delay = <0x7>;
adi,xo-disable-use-ext-refclk-enable;
adi,2rx-2tx-mode-enable;
adi,frequency-division-duplex-mode-enable;
adi,rx-rf-port-input-select = <0x0>;
adi,tx-rf-port-input-select = <0x0>;
adi,tx-attenuation-mdB = <0x2710>;
adi,rf-rx-bandwidth-hz = <0x4c4b40>;
adi,rf-tx-bandwidth-hz = <0x4c4b40>;
adi,rx-synthesizer-frequency-hz = <0x0 0x6df87740>;
adi,tx-synthesizer-frequency-hz = <0x0 0x6df87740>;
adi,rx-path-clock-frequencies = <0x4c4b4000 0x9896800 0x4c4b400 0x2625a00 0x1312d00 0x1312d00>;
adi,tx-path-clock-frequencies = <0x4c4b4000 0x9896800 0x4c4b400 0x2625a00 0x1312d00 0x1312d00>;
adi,gc-rx1-mode = <0x0>;
adi,gc-rx2-mode = <0x0>;
adi,gc-adc-ovr-sample-size = <0x4>;
adi,gc-adc-small-overload-thresh = <0x2f>;
adi,gc-adc-large-overload-thresh = <0x3a>;
adi,gc-lmt-overload-high-thresh = <0x320>;
adi,gc-lmt-overload-low-thresh = <0x2c0>;
adi,gc-dec-pow-measurement-duration = <0x2000>;
adi,gc-low-power-thresh = <0x18>;
adi,mgc-inc-gain-step = <0x2>;
adi,mgc-dec-gain-step = <0x2>;
adi,mgc-split-table-ctrl-inp-gain-mode = <0x0>;
adi,agc-attack-delay-extra-margin-us = <0x1>;
adi,agc-outer-thresh-high = <0x5>;
adi,agc-outer-thresh-high-dec-steps = <0x2>;
adi,agc-inner-thresh-high = <0xa>;
adi,agc-inner-thresh-high-dec-steps = <0x1>;
adi,agc-inner-thresh-low = <0xc>;
adi,agc-inner-thresh-low-inc-steps = <0x1>;
adi,agc-outer-thresh-low = <0x12>;
adi,agc-outer-thresh-low-inc-steps = <0x2>;
adi,agc-adc-small-overload-exceed-counter = <0xa>;
adi,agc-adc-large-overload-exceed-counter = <0xa>;
adi,agc-adc-large-overload-inc-steps = <0x2>;
adi,agc-lmt-overload-large-exceed-counter = <0xa>;
adi,agc-lmt-overload-small-exceed-counter = <0xa>;
adi,agc-lmt-overload-large-inc-steps = <0x2>;
adi,agc-gain-update-interval-us = <0x3e8>;
adi,fagc-dec-pow-measurement-duration = <0x40>;
adi,fagc-lp-thresh-increment-steps = <0x1>;
adi,fagc-lp-thresh-increment-time = <0x5>;
adi,fagc-energy-lost-stronger-sig-gain-lock-exit-cnt = <0x8>;
adi,fagc-final-overrange-count = <0x3>;
adi,fagc-gain-index-type-after-exit-rx-mode = <0x0>;
adi,fagc-lmt-final-settling-steps = <0x1>;
adi,fagc-lock-level = <0xa>;
adi,fagc-lock-level-gain-increase-upper-limit = <0x5>;
adi,fagc-lock-level-lmt-gain-increase-enable;
adi,fagc-lpf-final-settling-steps = <0x1>;
adi,fagc-optimized-gain-offset = <0x5>;
adi,fagc-power-measurement-duration-in-state5 = <0x40>;
adi,fagc-rst-gla-engergy-lost-goto-optim-gain-enable;
adi,fagc-rst-gla-engergy-lost-sig-thresh-below-ll = <0xa>;
adi,fagc-rst-gla-engergy-lost-sig-thresh-exceeded-enable;
adi,fagc-rst-gla-if-en-agc-pulled-high-mode = <0x0>;
adi,fagc-rst-gla-large-adc-overload-enable;
adi,fagc-rst-gla-large-lmt-overload-enable;
adi,fagc-rst-gla-stronger-sig-thresh-above-ll = <0xa>;
adi,fagc-rst-gla-stronger-sig-thresh-exceeded-enable;
adi,fagc-state-wait-time-ns = <0x104>;
adi,fagc-use-last-lock-level-for-set-gain-enable;
adi,rssi-restart-mode = <0x3>;
adi,rssi-delay = <0x1>;
adi,rssi-wait = <0x1>;
adi,rssi-duration = <0x3e8>;
adi,ctrl-outs-index = <0x0>;
adi,ctrl-outs-enable-mask = <0xff>;
adi,temp-sense-measurement-interval-ms = <0x3e8>;
adi,temp-sense-offset-signed = <0xce>;
adi,temp-sense-periodic-measurement-enable;
adi,aux-dac-manual-mode-enable;
adi,aux-dac1-default-value-mV = <0x0>;
adi,aux-dac1-rx-delay-us = <0x0>;
adi,aux-dac1-tx-delay-us = <0x0>;
adi,aux-dac2-default-value-mV = <0x0>;
adi,aux-dac2-rx-delay-us = <0x0>;
adi,aux-dac2-tx-delay-us = <0x0>;
en_agc-gpios = <0x6 0x62 0x0>;
sync-gpios = <0x6 0x63 0x0>;
reset-gpios = <0x6 0x64 0x0>;
enable-gpios = <0x6 0x65 0x0>;
txnrx-gpios = <0x6 0x66 0x0>;
linux,phandle = <0xe>;
phandle = <0xe>;
ad9361-phy-B@1 {
compatible = "ad9361";
reg = <0x1>;
spi-cpha;
clocks = <0x5>;
adi,digital-interface-tune-skip-mode = <0x2>;
adi,rx-data-clock-delay = <0x0>;
adi,tx-data-delay = <0x0>;
adi,xo-disable-use-ext-refclk-enable = <0x1>;
adi,rx1-rx2-phase-inversion-enable;
en_agc-gpios = <0x6 0x53 0x0>;
sync-gpios = <0x6 0x54 0x0>;
reset-gpios = <0x6 0x55 0x0>;
enable-gpios = <0x6 0x68 0x0>;
txnrx-gpios = <0x6 0x67 0x0>;
linux,phandle = <0x10>;
phandle = <0x10>;
ad9361-phy-C@2 {
reg = <0x2>;
spi-cpha;
clocks = <0x5>;
adi,rf-rx-bandwidth-hz = <0xf42400>;
adi,rf-tx-bandwidth-hz = <0xf42400>;
adi,rx-path-clock-frequencies = <0x3a980000 0xea60000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
adi,tx-path-clock-frequencies = <0x3a980000 0x7530000 0x7530000 0x3a98000 0x1d4c000 0x1d4c000>;
en_agc-gpios = <0x6 0x6b 0x0>;
reset-gpios = <0x6 0x63 0x0>;
linux,phandle = <0x11>;
phandle = <0x11>;
 larsc mhennerich
