BF706 GPIO PINT_INV_SET Use Question
Question asked by Scrappy on Feb 17, 2017
Latest reply on Jul 18, 2017 by Jithul_Janardhanan
I have some questions on using BF706 GPIO operations.
Following is the question about the BF706 GPIO PINT_INV_SET register.
Platform Model : BF706 EZ-KIT-MINI
Requirement : When the PB1 (Button) is pressed, the state of LED0 will be changed.
Problem :
According to the description in the file “BF70x_BlackfinProcessorHardwareReference” downloaded on the ADI website, setting PINT_INV_SET should be able to change the Interrupt trigger mode. And the following code should set the trigger mode to Low Level Trigger.
Then I set a breakpoint before this line “*pREG_PORTC_DATA_TGL | = ADI_GPIO_PIN_3” and pressed the button, the program did not enter this line. But if I released the Button , the program has entered.
So I don’t know if this is the wrong way to set, or my understanding of PINT_INV_SET is not correct?
Please help to advise this question.
Yours sincerely!
Below is the code I used for testing.
int main(void)
   adi_initComponents();
   GPIO_SET();
   GPIO_INTERRUPT_SET();
   while(1){}
void GPIO_SET(void)
   /*LED0*/
   *pREG_PORTC_FER_CLR |= ADI_GPIO_PIN_3;
   *pREG_PORTC_DATA_SET |= ADI_GPIO_PIN_3;
   *pREG_PORTC_DIR_SET |= ADI_GPIO_PIN_3;
   /*PB1*/
   *pREG_PORTC_FER_CLR |= ADI_GPIO_PIN_2;
   *pREG_PINT1_INV_SET |= ADI_GPIO_PIN_2;
   *pREG_PORTC_DIR_CLR = ADI_GPIO_PIN_2;
   *pREG_PORTC_INEN_SET |= ADI_GPIO_PIN_2;
void GPIO_INTERRUPT_SET(void)
   *pREG_PINT1_ASSIGN |= ADI_GPIO_PIN_2;
   *pREG_PINT1_MSK_SET |= ADI_GPIO_PIN_2;
   *pREG_PINT1_EDGE_CLR |= ADI_GPIO_PIN_2;
   adi_int_InstallHandler(INTR_PINT1_BLOCK, GPIO_ISR1, NULL, true);
void GPIO_ISR1(uint32_t iid, void* handlerArg)
   if(*pREG_PORTC_DATA & ADI_GPIO_PIN_2)
      *pREG_PORTC_DATA_TGL |= ADI_GPIO_PIN_3;
