make error in root folder for HDL library and projects
Question asked by nocturnalpea on Feb 15, 2017
Latest reply on Feb 22, 2017 by nocturnalpea
I'm currently trying to make the hdl repository in the root folder but I'm encounter errors that I'm hoping someone might be able to shed some light.
Hardware details:
Ubuntu 16.04LTS - 64bit
Vivado/XSDK 2015.4 installed with root previliges, changed environment variables as well as changed ownership to superuser for .Xilinx
Directory: /opt/Xilinx/...
Cloned hdl folder from: GitHub - analogdevicesinc/hdl: HDL libraries and projects
and checkout branch _r1 (compatible with 2015.4)
When I ran 'make clean-all' and then 'make all', I encountered the following:
** I'm just copy & pasting a partial of the output stream **
Makefile:117: recipe for target 'fmcjesdadc1_a5gt.sof' failed
make[3]: *** [fmcjesdadc1_a5gt.sof] Error 127
make[3]: Leaving directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/a5gt'
Makefile:10: recipe for target 'all' failed
make[2]: [all] Error 2 (ignored)
make -C a5soc all
make[3]: Entering directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/a5soc'
rm -rf *.log *_INFO.txt *_dump.txt db *.asm.rpt *.done *.eda.rpt *.fit.* *.map.* *.sta.* *.qsf *.qpf *.qws *.sof *.cdf *.sld *.qdf hc_output system_bd hps_isw_handoff hps_sdram_*.csv *ddr3_*.csv incremental_db reconfig_mif *.sopcinfo *.jdi *.pin
quartus_sh --64bit -t system_project.tcl >> fmcjesdadc1_a5soc_quartus.log 2>&1
Makefile:117: recipe for target 'fmcjesdadc1_a5soc.sof' failed
make[3]: *** [fmcjesdadc1_a5soc.sof] Error 127
make[3]: Leaving directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/a5soc'
make -C kc705 all
make[3]: Entering directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/kc705'
make -C ../../../library/axi_ad9250
make[4]: Entering directory '/home/name/repository/analogdevices/hdl/library/axi_ad9250'
rm -rf *.cache *.data *.xpr *.log component.xml *.jou xgui .Xil
vivado -mode batch -source axi_ad9250_ip.tcl >> axi_ad9250_ip.log 2>&1
Makefile:52: recipe for target 'axi_ad9250.xpr' failed
make[4]: *** [axi_ad9250.xpr] Error 1
make[4]: Leaving directory '/home/name/repository/analogdevices/hdl/library/axi_ad9250'
Makefile:68: recipe for target 'lib' failed
make[3]: *** [lib] Error 2
make[3]: Leaving directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/kc705'
make -C vc707 all
make[3]: Entering directory '/home/name/repository/analogdevices/hdl/projects/fmcjesdadc1/vc707'
Thank you.
