AD1974 96kHz Sample Rate setting
Question asked by Osamu on Feb 10, 2017
Latest reply on Feb 16, 2017 by Osamu
Hello.
I want to 96KHz sample rate. But AD1974 doesn't output on the following condition.
 Sampling freq:96kHz
 PLLinputCLK:MCLKI
 MCLKI:12.288MHz
 BCLK:External 6.144MHz
 LRCLK:External 96kHz
 Data Format:stereo I2S:Lch High
PLL and Clock Control 0 : 0x98
PLL and Clock Control 1 : 0x00
AUXPORT Control 0 : 0x00
AUXPORT Control 1 : 0x00
AUXPORT Control 2 : 0x00
ADC Control 0 : 0x60
ADC Control 1 : 0x00
ADC Control 2 : 0x04
At 48KHz sample rate was no problem.
Where is the problem with the setting?
Datasheet P12 CLOCK SIGNALS
"For example, if the AD1974 is programmed in 256 × fS mode, the frequency of the master clock input is 256 × 48 kHz = 12.288 MHz. If the AD1974 is then switched to 96 kHz operation (by writing to the SPI port), the frequency of the master clock should remain at 12.288 MHz (128 × fS)."
I expected to run from the data sheet.
Best regards.
