What is the supply voltage and pull up voltage for I2C bus SDA and SCL  in EDID EEPROM used in VGA monitors ?
Question asked by tendulkar.selvam on Jan 24, 2017
Latest reply on Jan 24, 2017 by GuenterL
Dear All,
Issue : What is the supply voltage and pull up voltage for I2C bus, SDA and SCL  in EDID EEPROM used in VGA monitors ?
I am designing one VGA input to differential R,G,B signal ouput module, in that I am using one I2C EEPROM to store the EDID information of the VGA monitors.
Some times i write the EDID data to EEPROM using micro controller(another module which is +3.3V compatible outputs) and some times i connect it to directly VGA connector.
Now the issue is, is it ok to use +3.3V pull up & supply voltage or +5V pull up & supply volatage for SDA bus in I2C and Vcc ?
Tendulkar S
