ad7192 linux driver: no device0 created
Question asked by jcao on Jan 23, 2017
Latest reply on Sep 1, 2017 by DragosB
I am working on our prototype pcb based on raspberry pi Compute Module 1 with linux kernel rpi-4.4/rpi-4.10(tried both)
I have ad7190 on the pcb.
I have followed the instruction at https://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/ad7192#example_platform_device_initialization
But there is no device created under root:/> cd /sys/bus/iio/devices/
Below is how I did so far(with kernel rpi-4.10):
1)    Added the following into   /usr/src/linux/arch/arm/mach-bcm/board_bcm2835.c as below:
[--snip--]
#include <linux/spi/spi.h>
#include </usr/src/linux/drivers/staging/iio/adc/ad7192.h>
[--snip--]
static struct ad7192_platform_data ad7192_pdata = {
        .vref_mv                = 5000,
        .clock_source_sel       = 2,
        .refin2_en              = false,
        .rej60_en               = true,
        .sinc3_en               = false,
        .chop_en                = true,
        .buf_en                 = true,
        .unipolar_en            = true,
        .burnout_curr_en        = false,
static struct spi_board_info board_spi_board_info[] __initdata = {
   #if defined(CONFIG_AD7192) \
        || defined(CONFIG_AD7192_MODULE)
                .modalias = "ad7192",
                .max_speed_hz = 1000000,     /* max spi clock (SCK) speed in HZ */
                .bus_num = 0,
                .chip_select = 0,            /* CS, change it for your board */
                .platform_data = &ad7192_pdata,
                .mode = SPI_MODE_0,
                .irq = -1,                   /*IRQ_PF6,*/
   #endif
static void __init bcm2835_init(void)
[--snip--]
        spi_register_board_info(board_spi_board_info, ARRAY_SIZE(board_spi_board_info));
[--snip--]
2)    Configure kernel with “make menuconfig”  as below:
Linux Kernel Configuration
   Device Drivers  --->
      [*] Staging drivers  --->
         IIO staging drivers  --->
            Analog to digital converters  --->
               <M>   Analog Devices AD7190 AD7192 AD7195 ADC driver
3)   Rebuild the kernel
4)    Run raspi-config
Set SPI interface disable.
Note: Otherwise after reboot run demsg will show an error:
[    6.939750] spi-bcm2835 20204000.spi: chipselect 0 already in use
[    6.939772] spi_master spi0: spi_device register error /soc/spi@7e204000/spid
5)   reboot,
After reboot check with dmesg showed  no error.
6)    Run modprobe spi-bcm2835 and then modprobe ad7192
Check with dmesg showed a warning only:
[  233.753497] ad7192: module is from the staging directory, the quality is unknown, you have been warned.
Note: I am not sure if modprobe spi-bcm2835 should be run, but it makes no difference in the end.
7)    Run lsmod showed as below
root@sm2:/# lsmod
Module                  Size  Used by
ad7192                  8325  0
ad_sigma_delta          6539  1 ad7192
industrialio_triggered_buffer     2813  1 ad_sigma_delta
kfifo_buf               3751  1 industrialio_triggered_buffer
industrialio           66261  4 ad7192,ad_sigma_delta,industrialio_triggered_buffer,kfifo_buf
spi_bcm2835             7424  0
cfg80211              530171  0
rfkill                 21278  1 cfg80211
joydev                  9386  0
rtc_ds1307             13710  0
hwmon                  10972  1 rtc_ds1307
evdev                  11714  2
hid_multitouch         11179  0
snd_bcm2835            23080  0
snd_pcm                96647  1 snd_bcm2835
snd_timer              22634  1 snd_pcm
snd                    68784  3 snd_timer,snd_bcm2835,snd_pcm
i2c_bcm2835             6369  0
bcm2835_gpiomem         3823  0
uio_pdrv_genirq         3718  0
uio                    10198  1 uio_pdrv_genirq
i2c_dev                 6642  0
ipv6                  386871  24
8)  Found no device0 under cd /sys/bus/iio/devices/
Only found ad7192 folder under /sys/bus/spi/drivers/ as below
root@sm2:/sys/bus/spi/drivers# ls
ad7192  spidev  stmpe-spi
Could anyone please help me?
Thanks in advance.
